Old 11-05-2012, 07:53 PM   #1
skimpreza06
Member#: 304086
Default need help??!!
I was on my way back home today on the highway driving at about 4000 rpms and my check engine started flashing and my engine started shaking like hell. So i pulled over and popped open my hood, i could smell something burning and my turbo was crazy orange it was overheated obviously. Checked my engine oil everything is fine checked my prestone and it was fine also. My car only has 130 000km (81 000 miles). If i turn on the car on idle it shakes a lot! What can it be the up pipe? Is the turbo burnt?
Thanks for the help
skimpreza06 is offline   Reply With Quote
Old 11-05-2012, 08:11 PM   #2
jthatch12
Member#: 321715
03 WRX
Thanks for the help
Your turbo was orange! On man. Is your coolant line still attached to your Turbo?
jthatch12 is offline   Reply With Quote
Old 11-05-2012, 08:14 PM   #3
skimpreza06
Member#: 304086
I dont know but it wasnt leaking. Im thinking maybe the upipe is completly blocked so it causing it to overheat ?
Old 11-05-2012, 08:18 PM   #4
jthatch12
Member#: 321715
03 WRX
That's still crazy. The fact the turbo was glowing hot when you pulled over is really bad news man. Does your car have the stock uppipe?
Old 11-05-2012, 08:25 PM   #5
skimpreza06
Member#: 304086
The car is 100% stock, when i was looking something underneath the turbo was overheated also im thinking its the up pipe but i really have no idea!
Old 11-05-2012, 08:34 PM   #6
jthatch12
Member#: 321715
03 WRX
I wonder if your turbo had begun to ingest your catalytic converter in your uppipe
Old 11-05-2012, 08:57 PM   #7
mhoerath
Member#: 131379
2003 354 ftlb@3k rpm
justablue hatch
your turbo has both coolant and oil lines. There's a screen in the oil line that is infamous for clogging. not good your turbo was red hot. good chance the heat or possible lube void damaged the bearings.
pull the turbo and inspect blades, and if it still turns freely. you prob will need to replace. I replaced mine with a used that worked a-ok.
mhoerath is offline   Reply With Quote
Old 11-05-2012, 09:03 PM   #8
skimpreza06
Member#: 304086
Ok perfect would the line that brings the oil need to be changed also since its clogged?
Old 11-05-2012, 09:05 PM   #9
Chaz2.5
Member#: 168181
2008 3.52 SWP 08 WRX
1999 EJ205'd RS coupe
06+ WRX didn't have a cat in the uppipe.
Chaz2.5 is offline   Reply With Quote
Old 11-05-2012, 09:06 PM   #10
jthatch12
Member#: 321715
03 WRX
I can't see what year his car is from the android nasioc app haha
Old 11-05-2012, 09:08 PM   #11
Chaz2.5
Member#: 168181
Gotcha!
Old 11-05-2012, 09:12 PM   #12
skimpreza06
Member#: 304086
Its an 02 sorry guys forgot
Old 11-05-2012, 10:56 PM   #13
mod maniac
Member#: 300551
2002 DD wgn 6 spd
2.1 kel 272's meth 2.5xtr
It could be any or all of your cats. I would check them all.
Old 11-05-2012, 11:30 PM   #14
Chaz2.5
Member#: 168181
Ohhh, well in that case the uppipe cat my in fact be the culprit
Old 11-06-2012, 01:08 PM   #15
jthatch12
Member#: 321715
03 WRX
Ever figure it out?
Old 11-06-2012, 01:26 PM   #16
skimpreza06
Member#: 304086
Not yet it happened last night so probably taking it to the mechanic tomorrow!
Old 11-06-2012, 01:32 PM   #17
IA Performance
Member#: 25194
2008 Forester XT 5mt
Dark Gray
Keep us updated with the final diagnosis. From the folks here, and what we've seen, the pre cat is most likely damaged/clogged/breaking apart.
Stephen Clark
IA Performance
PO Box 550
Boulder, CO 80306-0550
phone: 520-882-2821
fax: 303-449-4481
www.iaperformance.com
www.facebook.com/iaperformance
IA Performance is online now   Reply With Quote
Old 11-06-2012, 02:35 PM   #18
skimpreza06
Member#: 304086
Perfect ! Thats what im thinking also. Its either the cat or the oil hose. But what i dont understand is why is tbe engine idling so rough when i turn it on?
Old 11-06-2012, 11:46 PM   #19
jthatch12
Member#: 321715
03 WRX
If something in your turbo is working improperly, think about it, what is your main access to your exhaust system? Everything goes through the turbo.
Old 11-07-2012, 12:26 AM   #20
skimpreza06
Member#: 304086
yeah i guess so something is clogged up so the engine is not breathing well thats probably why its idling like that
Old 11-08-2012, 04:50 PM   #21
skimpreza06
Member#: 304086
talked to my mechanic today after he checked it out quickly since he was extremely busy and told me that it was most likely a misfire from one of my cylinders, that's whats causing the shaking and the turbo is overheating because when its misfiring its sending the gas into the turbo. so he told me he was going to check the coil pack and my spark plugs!
Old 11-09-2012, 02:35 PM   #22
jthatch12
Member#: 321715
03 WRX
Interesting, keep us updated
Old 11-09-2012, 02:50 PM   #23
skimpreza06
Member#: 304086
so finally picked it up today spark plugs were top shape. He changed one coil pack from the cylinder that was misfiring. so it idles beautiful no more shaking haha! took it for a little spin and i realized that the turbo makes a lot more noise, and i think that there's a little decrease in power. he told me he didn't think the turbo was burnt, because they are pretty tough. But i'm wondering if the turbo was damaged due to the overheating? and if its going to let go soon? should i change it? they aren't that expensive, but will i need a tune after or is it just bolt on?
thanks
Old 11-09-2012, 02:58 PM   #24
Xx02rexxX
Member#: 331883
04 forester xt 5mt
jbp
im pretty sure if you just bolt up another td04 (stock turbo) you wont need a tune.
Xx02rexxX is offline   Reply With Quote
Old 11-09-2012, 07:30 PM   #25
561wrx
Member#: 166427
03 wrx
thanks
No tuning if u r going to put the same one on. An maybe I'm guess the bearing in the turbo are damage from the over heating. An I'm also guess that cat is probably clogged, but this all guess on the top of my head. So that my theory.
561wrx is offline   Reply With Quote
Message Board Statistics All times are GMT -4. The time now is 05:21 PM.
