Old 11-05-2012, 08:30 PM   #1
Equilibrium Tuning
Member#: 26933
2006 STI
CGM
Default EQ - 05 STI, EQ Built Block, GT35 Rotated, E85 - 473whp
Here is a car we built a while back and the customer just made the switch to E85. We kept the tune on the safe side, peaking at only 26psi, but got some awesome results.
Event: Custom Tune/Dyno
Ambient Temp: 80 degrees Fahrenheit
Elevation: ~100ft above sea level
Car: 2005 Subaru STI
Tuner: ED @ Equilibrium Tuning
Peak HP at RPM: 473whp @ 6300RPM
Peak Torque at RPM: 460ft-lbs @ 5100RPM
Target Boost: 26psi peak
Fuel: E85
Engine/Power Modifications:
EQ Stage 2 Shortblock
EQ Stage 2 Heads (stock cams)
Rotated GT35r .82a/r
Tial EWG
TurboXS FMIC with EQ Modified piping
EQ Tuning Intake
ID2000cc Injectors
Aeromotive Fuel Rails
Aeromotive FPR
Aeromotive 340lph pump with EQ Direct Wire Kit
Tuned with Cobb Speed Density
*** Standard Dyno Chart Disclaimer ***
This dyno reads low and should be compared to the lower reading mustang dynos. Here are some proven numbers and trap speeds for reference:
Stock 02-05 WRX - 155-165whp
Stock 04-07 STI - 215-220whp
Stock 08-11 STI - 190-200whp
265-275whp - 107-108mph traps
300-310whp - 112-113mph traps
325-335whp - 115-116mph traps
350-360whp - 118-120mph traps
Thanks
-- Ed
Equilibrium Tuning is offline   Reply With Quote
Old 11-07-2012, 08:12 AM   #2
rexworx
Member#: 103232
05GD 04XT11WRX2.5XTR
PPG,4.44,LSD,E85,6spdx2
another beast, great job ed!!!
rexworx is offline   Reply With Quote
Old 11-07-2012, 09:45 AM   #3
juanmedina
Member#: 133146
07 FPgreen [email protected]
WRX VF39+E85 12.0, 121mph
What is the redline set at and what is the timing at redline Ed?
It looks really good
Old 11-07-2012, 12:27 PM   #4
medamullet
Member#: 99442
2006 SGM STI
I'm on CORN YO!
I'm interested in your fuel pump setup if you can give more info. I am trying to figure out my fuel pump setup. Hard wire duel walbro in tank or surge tank or what....
medamullet is offline   Reply With Quote
Old 11-07-2012, 01:50 PM   #5
Equilibrium Tuning
Member#: 26933
2006 STI
CGM
Redline is 7300RPM and timing at redline is about 26*
Thanks
-- Ed
Old 11-07-2012, 01:52 PM   #6
renosubby
Member#: 152576
2009 GTR 10.7@ 133
Mayhem Tuning!!!!!
good stuff Ed. looks like it's an amazing street car!
renosubby is offline   Reply With Quote
Old 11-07-2012, 01:52 PM   #7
Equilibrium Tuning
Member#: 26933
2006 STI
CGM
I found that the Aeromotive 340lph does really well once you hard wire it. Without hard wiring, I usually see it max out around 400-420whp on our dyno. With the hardwired kit it seemed to still have plenty of juice at this point.
We just use 10 gauge wire, a breaker, and a relay triggered by the stock pump signal.
-- Ed
Old 11-07-2012, 02:03 PM   #8
medamullet
Member#: 99442
2006 SGM STI
I'm on CORN YO!
-- Ed
Is it a kit you guys a selling?
Old 11-07-2012, 02:11 PM   #9
juanmedina
Member#: 133146
Thanks
-- Ed
So 26* of timing is conservative? I been runing 21.5*, 27psi, at 7500rpm on E85 with my FP black making 490whp VD dynojet and I was thinking about running more timing. I just don't want to have to rebuilt my engine again any time soon lol
Old 11-07-2012, 02:44 PM   #10
Equilibrium Tuning
Member#: 26933
2006 STI
CGM
It all depends on the engine and setup. This engine is fully built and it actually took more timing than that with no problem but I backed it off a couple degrees. As long as there is no knock on many back to back pulls and as long as the additional timing keeps making power, there's nothing wrong with running it. I also tend to use EGT quite a bit when tuning timing on E85. If adding timing makes more power and lowers EGT's, you're still approaching MBT.
-- Ed
Old 11-07-2012, 02:45 PM   #11
Equilibrium Tuning
Member#: 26933
2006 STI
CGM
So far we've just been putting these together for in house projects. I think Aeromotive offers a similar kit as well.
-- Ed
Old 11-07-2012, 03:05 PM   #12
medamullet
Member#: 99442
2006 SGM STI
I'm on CORN YO!
I know deatschwerks does. Their kit sounds like it's the same. I all ready have the dw300 and was debating running either that pump hard wired or double dw200. I just don't want to do it twice. My build is very close to yours except I have gsc stage 1 cams and +1 valves. I am hoping for similar numbers as you.
