Old 11-05-2012, 09:36 PM   #1
illest2.5i
Member#: 317393
07 impreza 2.5i
blue
Default cruise light flashing?
On my home from work today had cruise set at 57 and all of a sudden cruise shut off the cruise light started flashing and check engine light came on any suggestions
illest2.5i is offline   Reply With Quote
Old 11-05-2012, 09:36 PM   #2
illest2.5i
Member#: 317393
07 impreza 2.5i
blue
Ohh ya I have an 07 impreza sedan 2.5I 48000 miles
Old 11-05-2012, 10:00 PM   #3
impreza09af
Member#: 241754
2009 2.5i premium
newport pearl blue
When you get a check engine light you loose cruise control. Get a CEL reader to check what P code pops up.
impreza09af is offline   Reply With Quote
Old 11-05-2012, 10:16 PM   #4
blk6s
Member#: 200057
2013 Impreza 2.0i
RalliSported RomRaided
This^^^
It was probably just a coincidence that you happend to be using the cruise when the cell was triggered.
blk6s is offline   Reply With Quote
Old 11-05-2012, 10:20 PM   #5
illest2.5i
Member#: 317393
07 impreza 2.5i
blue
Ahhh ok thanks guys
Old 11-05-2012, 10:39 PM   #6
GrundleJuice
Member#: 165749
The cruise flashing along with the CEL means it's an emissions related DTC like an evap leak or an O2 sensor code. Cruise control is disabled while the DTC is triggered.
Old 11-06-2012, 01:56 AM   #7
Eyedoc Orlando
Member#: 146216
2007 Impreza 2.5i SE
Newport Blue Metallic
once you check the code you'll find it's most likely an evap leak which is a loose gas cap. Retighten the fuel cap and reset the code, see if it ever comes back
Eyedoc Orlando is offline   Reply With Quote
Old 11-09-2012, 07:55 PM   #8
Imprezz2.5
Member#: 337472
I had the same thing happen to my car. The code that came up was for an o2 sensor... Replaced them, still had the code. Turns out I needed to replace my ECM.. luckily I got a used one for pretty reasonable. Car is running great now!!
Imprezz2.5 is offline   Reply With Quote
Old 11-14-2012, 06:49 PM   #9
illest2.5i
Member#: 317393
07 impreza 2.5i
blue
So after checking the cap and re setting the code it still comes on I do have an after market heart with no cat is it pertinent that I get a cat
Old 11-14-2012, 07:02 PM   #10
GrundleJuice
Member#: 165749
What is/are the triggered dtc's?
Old 11-14-2012, 08:45 PM   #11
kevwill
Member#: 228389
pearl white
had the same thing found out I punctured the carbon canister installing a sub
kevwill is offline   Reply With Quote
Old 11-14-2012, 10:32 PM   #12
illest2.5i
Member#: 317393
07 impreza 2.5i
blue
P0420 and the same code pending
Old 11-15-2012, 01:45 AM   #13
GrundleJuice
Member#: 165749
Your cat/header are almost certainly to blame. Replacing the cat is not likely to solve the problem. How many miles on the current header /cat combination?
Old 11-15-2012, 01:41 PM   #14
V8Slayer
Member#: 111565
2007 Legacy Spec.B
305hp/280tq EVOIII 16G
A quick and cheap way to avoid the dreaded P0420 is to use 2 spark plug fouler's(http://www.oreillyauto.com/site/c/de...0259&ppt=C0334) to move the rear O2 sensor out of the exhaust stream. Most people seem to have good results with this method(myself included) and only takes a few minutes to do. Just drill out the bottom of 1 fouler so the O2 sensor can fit inside screw them together and then insert back into your exhaust pipe.
V8Slayer is online now   Reply With Quote
Old 11-15-2012, 02:13 PM   #15
illest2.5i
Member#: 317393
07 impreza 2.5i
blue
Its got about 4 to 5 hundred miles on it and I've heard of that there is currently no cat on my car due to the header I'll try the fouler tips thanks guys
Old 11-15-2012, 02:22 PM   #16
GrundleJuice
Member#: 165749
This works on 04 and earlier systems bit in 05 the Efi system changed and doing this will not only screw up your closed loop fueling but it won't get rid of the PO420. If you do this to the Front O2, it will really mess things up.
Old 11-15-2012, 04:06 PM   #17
V8Slayer
Member#: 111565
2007 Legacy Spec.B
My apologies, I was unaware of the problems this would cause on the newer vehicles.
Old 11-15-2012, 04:07 PM   #18
illest2.5i
Member#: 317393
07 impreza 2.5i
blue
Ok is there another option I can do like a universal cat
Old 11-15-2012, 04:35 PM   #19
V8Slayer
Member#: 111565
2007 Legacy Spec.B
Very true, and a po420 is nothing to really worry about. If it bothers you, you can always do like other have said and just buy a cheap OBDII scanner and reset the light when it pops up. Buying a new cat is just throwing money away.
Old 11-15-2012, 08:27 PM   #20
illest2.5i
Member#: 317393
07 impreza 2.5i
blue
Ok cool I have a scan tool but that was what I wasnet sure of is if it would ruin anything
Old 03-17-2013, 02:36 AM   #21
J. Rowdy
Member#: 300192
2009 Impreza
red
My car only did thus after I got command start installed. Everytime I use my command start to start car it throws code.( cel, cruise flashes, traction control off.) I Assumed the idiot that installed it wired something wrong. Cause if I startit with key it's fine but as soon As I command start it. My dash lights up like a Christmas tree. Super frustrating!!! Should I take it back there er what? It literally I ly does it when it's command started.
J. Rowdy is offline   Reply With Quote
Old 03-17-2013, 09:21 AM   #22
GrundleJuice
Member#: 165749
Originally Posted by J. Rowdy View Post
Everytime I use my command start to start car it throws code.( cel, cruise flashes, traction control off. I Assumed the idiot that installed it wired something wrong. Cause if I startit with key it's fine but as soon As I command start it. Should I take it back there er what?
How is this even a question in your mind?
Sell it and get a bicycle.
