Old 11-06-2012, 08:20 AM   #1
97ej22e
Member#: 327710
1999 Impreza OBS
Green
Default legacy transmission into impreza?
Will my 5 speed and rear diff from my 97 Legacy GT fit into a fwd impreza? Of course I will be doing an all wheel drive swap just figure I'll use these parts if I can instead of having to find another transmission and rear diff. Posted this in the transmission forum but apparently nobody there knows the answer.
97ej22e is offline   Reply With Quote
Old 11-06-2012, 09:31 AM   #2
suberdave
Member#: 101865
88 GL-10 STi
yes a legacy trans mission will fit in an impreza. just make sure you get the same rear diff ratio and you will be fine.
-=Suberdave=-
suberdave is online now   Reply With Quote
Old 11-06-2012, 10:19 AM   #3
97ej22e
Member#: 327710
1999 Impreza OBS
Green
perfect, I'll also be using the rear diff out of the legacy. Thanks!
Message Board Statistics All times are GMT -4. The time now is 09:52 AM.
