Old 11-12-2012, 05:10 PM   #1
bugeye105
Member#: 319753
---> @_awd_anthony
Bagged 2002 WRX
Default What would you do ???
delete
bugeye105 is offline   Reply With Quote
Old 11-12-2012, 05:15 PM   #2
Danthrax
Member#: 299368
2014 Impreza 2.0i
Should do the up pipe while you're at it. Quicker spool and save the turbo in the long run.
Danthrax is offline   Reply With Quote
Old 11-12-2012, 05:42 PM   #3
Tonyturkey716
Member#: 307879
2013 WRX Hatch
Now I'm no pro and just giving my opinion as you asked but I would go with choice number two with the UP. While the PW is a great piece, you won't benefit much from it while being in the stock turbo.
Again just my feedback
Edit: once you go for an upgraded turbo then I say PW.
Tonyturkey716 is offline   Reply With Quote
Old 11-12-2012, 06:09 PM   #4
bugeye105
Member#: 319753
---> @_awd_anthony
Bagged 2002 WRX
great, thanks. thats what others have recommended too and i see you point. anyone else?
Old 11-12-2012, 06:30 PM   #5
pimpin24
Member#: 328496
2009 fp red sti
Deffinatly option 2 it'll be the best bang for u buck right now
pimpin24 is offline   Reply With Quote
Old 11-12-2012, 06:34 PM   #6
Napalm3nema
Member#: 263954
2014 EVO X / 05 WRX
Wicked White / Blue
None of the above. Get swaybars + endlinks.
Napalm3nema is offline   Reply With Quote
Old 11-12-2012, 07:10 PM   #7
bugeye105
Member#: 319753
---> @_awd_anthony
Bagged 2002 WRX
whats your reasoning on this
Old 11-12-2012, 07:14 PM   #8
05subysti
Member#: 268190
2005 STi
tomei header and up pipe!
05subysti is offline   Reply With Quote
Old 11-12-2012, 10:25 PM   #9
tommyson01
Member#: 154579
2005 OBXT
Old man blue
Just the up pipe.
Then, spend some on your brakes and do the H6 rear up grade. I have to ask though, what are you goals for the car?
tommyson01 is offline   Reply With Quote
Old 11-12-2012, 10:41 PM   #10
SparkSilver10NM
Member#: 302438
10 WRX
SS DMrally tuned!
I vote the UP heat wrap and suspension bits. The reasoning is suspension parts make your car feel more fun, handle better, and are a long life upgrade that don't require tuning
SparkSilver10NM is offline   Reply With Quote
Old 11-12-2012, 11:02 PM   #11
BlackJavaPearl04
Member#: 198522
98 LGT Limited
00 LGT -WRX swap
I would go with EL headers...i made 30 more whp and tq with them
BlackJavaPearl04 is offline   Reply With Quote
Old 11-12-2012, 11:40 PM   #12
Badler
Member#: 133597
This or maintenance. 10 year old cars could use a refresh. Ie: bushings, belts, fluids, hoses, etc...
Badler is offline   Reply With Quote
Old 11-13-2012, 12:02 AM   #13
SubieLuvin
Member#: 248202
2013 WRX Sedan
Honestly at your power level your not going to benefit that much from an aftermarket exhaust manifold. If I were you I would screw the process west tmic and just find a lightly used Sti one and with the money you save from over paying for the process west find a cheap cat less up pipe and Sti injectors as well... Then turn up the boost a bit. Sti intercoolers can handle more power than your stock block can. You can achieve all of this with under a grand if you play your cards right.
Most importantly before adding anymore power make sure the upkeep on the vehicle is up to date. People who chose a new turbo over a timing belt are retarded.
SubieLuvin is offline   Reply With Quote
Old 11-13-2012, 12:19 AM   #14
ChefRacer
Member#: 287000
05 LGT wagon 5mt
I don't think either of those choices make much sense for your current setup ul headers are pretty much always a waste of money, el is the only bang for your buck, but those will push your powerband to the right and you already have a turbo that doesn't have much top end power. I'd say for $1000, get a used vf39, some sti injectors for $100, and an STI tmic... Then hope that you don't blow anything up. Btw, if you have that current setup without a real tune... You need to get one asap
ChefRacer is offline   Reply With Quote
Old 11-13-2012, 12:20 AM   #15
ChefRacer
Member#: 287000
05 LGT wagon 5mt
Also I agree with this guy about the maintenance part
Old 11-13-2012, 12:32 AM   #16
captncal
Member#: 284508
2011 wrx
save that money....
captncal is offline   Reply With Quote
Old 11-13-2012, 12:35 AM   #17
drewvdw
Member#: 255776
2010 LR WRX
MPS powered.
At a minimum do your up pipe. Then do whatever mods you want.
Old 11-13-2012, 03:24 AM   #18
575rider
Member#: 112024
03 hybrid 6spd wgn
Santa Cruz Bronson-Carbon
up pipe and some suspension/ brake upgrades
575rider is offline   Reply With Quote
Old 11-13-2012, 08:38 AM   #19
bugeye105
Member#: 319753
---> @_awd_anthony
Bagged 2002 WRX
wow thanks for all the advice guys ! yeah after some research im finding headers arent really worth all that money is if ANYTHING the grimmspeed cross pipe is a better bang for your buck then spending 700 on headers. i agree i do need an uppipe though so i definitely will have to get one. as for the suspension comments i see your point, the only suspension mod i have are coilovers, i got to up my game in the section
on another note my up keep is very good, i get it regularly checked and it runs very strong for a car made in 2002 and it has pretty low miles (80xxx) and it doesnt go up fast
keep coming with the suggestions i like them! thanks again
Old 11-13-2012, 08:43 AM   #20
EvileyeZ88
Member#: 233501
07AD 337/335SAXWAGON
99 outback sport
Sways and end links, fender braces and bushings. Your car now handles like a roller coaster.
Or the time tested classic:
Hookers and blow...
~Evil
EvileyeZ88 is offline   Reply With Quote
Old 11-13-2012, 10:05 AM   #21
Napalm3nema
Member#: 263954
2014 EVO X / 05 WRX
Wicked White / Blue
So much fun having those on there, I never thought I'd enjoy suspension mods more than power mods but I did in this case.
Old 11-13-2012, 10:16 AM   #22
bugeye105
Member#: 319753
---> @_awd_anthony
Bagged 2002 WRX
do you really feel that much of a difference in sways and endlinks?
Old 11-13-2012, 10:19 AM   #23
ChefRacer
Member#: 287000
05 LGT wagon 5mt
Absolutely
Old 11-13-2012, 10:28 AM   #24
EvileyeZ88
Member#: 233501
99 outback sport
Go under the rear end of your car and grab hold of that little thin metal bar running between your wheels. That's the sway bar, now give her a little tug. See how much it bends?
That's what keeps the body of your car from rolling during turns
A good 22mm sway bar won't ever do that.
An upgraded sway bar will eventually kill the stock end links so that's where after market end links come into play.
~Evil
Old 11-13-2012, 10:44 AM   #25
s2ktosti
Member#: 70151
2011 WRX Limited
Your car is over 10 years old, I'd be saving for repairs or replacement.
s2ktosti is offline   Reply With Quote
