Old 11-20-2012, 03:58 PM   #51
SlverEJ20
Member#: 157158
05 WRX stage 2
You could start swapping the coil packs around to see if the miss fire follows a coil pack. Or ask one if your local forum members if you could borrow there coil packs to see if that fixes the issue
SlverEJ20 is offline   Reply With Quote
Old 11-20-2012, 04:08 PM   #52
tersplat
Member#: 337888
2003 WRX Wagon
World Rally Blue
I am not throwing any codes. How do I know which one is misfiring?
tersplat is offline   Reply With Quote
Old 11-21-2012, 10:45 AM   #53
oOIIJoshIIOo
Member#: 295983
You won't. Just buy a new one and switch it around until problem solved. Unless there is more than one coil bad, but it isn't likely at the same time. Most of the time a bad coil doesn't throw any code at all.
oOIIJoshIIOo is offline   Reply With Quote
Old 11-21-2012, 12:46 PM   #54
simpsonsdotcom
Member#: 269543
2002 2.5RS BRP
2004 WRX WRB
Yeah that's what I ended up doing. I think it will only throw a code once it is really bad or misfiring. Mine sure felt like it was misfiring but never threw a code for one.
simpsonsdotcom is offline   Reply With Quote
Old 11-21-2012, 04:17 PM   #55
tersplat
Member#: 337888
2003 WRX Wagon
World Rally Blue
Alright, Thanks. Are there any known issues with the duralast coils from Autozone? Or should I buy genuine Subaru?
