Mid West Subaru Owners Club
Go Back   NASIOC > NASIOC Chapters > Mid West Subaru Owners Club Forum -- MWSOC
Old 11-06-2012, 09:52 PM   #1
04STiowner84
Member#: 332393
04 WRX STi
Slvr
Exclamation Need Help (Green Connectors under driver dash)
Hey guys so heres the deal. I have an 04 STI and the previous owner decided to "RED NECK" rig a toggle switch up for those 2 green connectors that i so badly need in order to flash or even read my ECU. I have found the RL (red and lavender) wire but the crappy thing is, its been spliced to a black wire to the switch but i also have 2 black an red wires with male ends on them. If its possible could u please take a picture of yr connectors including wire color and locations of both wires so i can determine where this is all leading so i can fix this properly.
04STiowner84 is offline   Reply With Quote
Old 11-06-2012, 10:25 PM   #2
JarHarms
Member#: 138994
06 WRX Ltd
02 Forester S
The green B75 and B76 connectors that mate together -> I see RL to B75 connector (terminal slot 1) and BR to B76 connector (terminal slot 1) on the STI wiring diagram I have for the for the test connector. This wiring diagram is for a 2006-2007 MY but the same circuit colors may have been used on your 2004. Just keep in mind that the B76 circuit colors are different between STI/WRX/2.5i.
RL = red/blue stripe
BR = black/red stripe
I have a photo of the connectors but since its on a WRX the circuit colors are different RL and BY. So maybe not much use for you, sorry.
JarHarms is offline   Reply With Quote
Old 11-08-2012, 08:48 AM   #3
Th3Franz
Member#: 37146
2005 Legacy GT
Stage tree fitty
why not just use the switch they installed? Switch closed = connected
Switch open = disconnected
Th3Franz is offline   Reply With Quote
