Go Back   NASIOC > NASIOC Technical > Factory 2.5L Turbo Powertrain
Old 11-13-2012, 09:34 PM   #26
rymaggi
Member#: 253442
2006 vf39 Wrx Wagon
UGM
Originally Posted by UK-Wagon
Definatly a sound we dont hear quite often, could even be clutch related. Since it doesnt change with RMP its difficult to say its engine internal related at all. Almost sounds like a throw out bearing issue. Ive herd some that sound exactly like that.
Can you hear this noise at idle?
I cannot hear it at idle. Only when my foot touches the pedal. I can completely control with the gas pedal.
rymaggi is offline   Reply With Quote
Old 11-27-2012, 04:02 PM   #27
rymaggi
Member#: 253442
2006 vf39 Wrx Wagon
UGM
Had some people suggest, possibly my 3port ticking since its mounted to my strut tower? Any input on that ?
Old 11-27-2012, 04:09 PM   #28
drewvdw
Member#: 255776
2010 LR WRX
MPS and PAR powered.
If it was the 3 port, the frequency wouldn't fluctuate with rpms. Mine in noisy and drove me nuts. Happens whenever my foot is on the gas at all.
drewvdw is offline   Reply With Quote
Old 11-28-2012, 07:57 PM   #29
rymaggi
Member#: 253442
2006 vf39 Wrx Wagon
UGM
I don't think the "frequency" fluctuates. Same sounding tick everytime. Seems to be the same consistent speed.
Old 11-28-2012, 09:04 PM   #30
drewvdw
Member#: 255776
2010 LR WRX
If it has a steady "TPM" (ticks per minute ), then I'd say it's probably the EBCS. If you have a stethoscope, use that to find out for sure.
Old 11-28-2012, 11:10 PM   #31
rymaggi
Member#: 253442
2006 vf39 Wrx Wagon
UGM
Yea it's a steady tick. When the crazy storm is done I'm gonna try n see if I can double sides tape the thing on. It I'm not sure what I can do. Zip tie the sucker to something?
Old 11-28-2012, 11:11 PM   #32
drewvdw
Member#: 255776
2010 LR WRX
Rubber O-ring between the bracket and body
Old 11-29-2012, 03:37 PM   #33
rymaggi
Member#: 253442
2006 vf39 Wrx Wagon
UGM
Oooo. Good call.
Old 12-11-2012, 01:17 AM   #34
Saunders1986
Member#: 303165
2012 WRX
subd, my 2012 makes the same noise!
Saunders1986 is offline   Reply With Quote
Old 12-11-2012, 01:34 AM   #35
drewvdw
Member#: 255776
2010 LR WRX
You subscribed to a thread that already had the problem solved?
Old 12-30-2012, 03:27 PM   #36
rymaggi
Member#: 253442
2006 vf39 Wrx Wagon
UGM
Well not totally!! I had a buddy put his ear up to the 3port. He couldn't hear really anything. My alternator and belts are ridiculously loud. It's bizarre. He can't hear any ticking noise while I rev te engine 2k-2.5k rpms. But in the cabin I can clearly hear it.
I almost want to say it sounds like its coming from somewhere maybe low and not deep into the engine bay.
Old 12-30-2012, 05:04 PM   #37
WaitTheresMore
Member#: 289315
2006 STi
"Frosty"
it could be the oil pickup tube on its last leg.
WaitTheresMore is offline   Reply With Quote
Old 12-30-2012, 09:45 PM   #38
rymaggi
Member#: 253442
2006 vf39 Wrx Wagon
UGM
Can that make noise under load around 2k rpms.
Old 12-30-2012, 10:25 PM   #39
WaitTheresMore
Member#: 289315
2006 STi
"Frosty"
Old 12-31-2012, 12:33 AM   #40
WaterfordRex
Member#: 311224
2011 Impreza WRX
I saw in both posts to check for gold flecks in the oil. Would that be from the bearing breaking down? Sorry for the "dumb question". Im new to this and im just doing the research.
WaterfordRex is offline   Reply With Quote
Old 12-31-2012, 09:12 PM   #41
rymaggi
Member#: 253442
2006 vf39 Wrx Wagon
UGM
Not sure. My oil is clean. Every time I change it.
Old 12-31-2012, 09:12 PM   #42
rymaggi
Member#: 253442
2006 vf39 Wrx Wagon
UGM
My tuner said the pickup tube is very unlikely :/
Old 12-31-2012, 11:42 PM   #43
WaitTheresMore
Member#: 289315
2006 STi
"Frosty"
ahh gotcha also it could be up pipe heat shield.
Old 01-03-2013, 01:56 AM   #44
drnockers
Member#: 323212
I am having the exact same issue on my 2012 wrx with 11,000k. Dealership couldnt/refused to hear the noise. It was suggested by a tech that it may be a loose heat shield but when the car was cool I tried moving them around to see if it was loose at all and didnt seem to be going anywhere. it drives me crazy and my 3 local dealerships wont look into it. So if anyone finds a solution id be so happy! haha
drnockers is offline   Reply With Quote
Old 01-08-2013, 12:25 AM   #45
rymaggi
Member#: 253442
2006 vf39 Wrx Wagon
UGM
yea its quite annoying, it honestly seems like its coming from somewhere close to the firewall, and not something towards the headlight area, maybe somewhere low..... but my damn belts and alternator are ridiculously loud, so its impossible to hear anything while looking into the engine bay. Even when you try and stick your head into crevasses, only way to hear it is in the cabin.
Old 01-08-2013, 10:36 AM   #46
mechatricity
Member#: 290592
2006 WRX Wagon
2004 WRX Wagon
That goes back to a possible trans issue perhaps?
mechatricity is offline   Reply With Quote
Old 01-08-2013, 04:11 PM   #47
rymaggi
Member#: 253442
2006 vf39 Wrx Wagon
UGM
Im not sure how i would be able to look into that. I do have TiC Xmember bushings, Group N tranny mount, Shifter kit bushing, i dont think it started when i put those in.
Tranny has never grinded, and i have never miss shifted it, EVER.
It shifts SUPER smooth, runs 100%. (at least from what i can tell)
Car is vf39'd on a ridiculously smooth tranny "safe" power band, and i still baby it.
Message Board Statistics All times are GMT -4. The time now is 09:12 AM.
