Mid Atlantic Impreza Club
Old 11-18-2012, 09:25 PM   #51
shadowmd
Member#: 193222
05 Wrx 1.5xtr 6spd
2.5 hybrid 367whp/363wtq
Originally Posted by Abnormal View Post
Did you get an IAT sensor or are running the one in the stock MAF sensor?
I had them install an iat sensor. The maf is still there, just not plugged in
shadowmd is offline   Reply With Quote
Old 11-18-2012, 09:27 PM   #52
shadowmd
Member#: 193222
05 Wrx 1.5xtr 6spd
Originally Posted by dumpstercrusher View Post
what makes speed density different? can you tell the difference when driving?
The drivability is soooo much nicer. The best way I can describe it is that when your wot going through the gears, when you shift gears, it almost feels like you're flat foot shifting. Meaning you always seem to land at full boost. There is almost ZERO lag between shifts. Also, throttle response is much improved.
Old 11-19-2012, 09:37 AM   #53
Abnormal
Lil Curious
Member#: 149626
2005 CGM FXT
Rocket Box! :D
Gotcha. That's exactly what I wanted to hear.
Abnormal is offline   Reply With Quote
Old 11-19-2012, 10:03 AM   #54
Abnormal
Lil Curious
Member#: 149626
2005 CGM FXT
Rocket Box! :D
Speed Density is more effective because you're essentially using more sensors, in more important areas, to manage your fueling.
More accurate data == Better combustion control == Better tune
Old 11-19-2012, 10:06 AM   #55
shadowmd
Member#: 193222
05 Wrx 1.5xtr 6spd
Yeah it really is night and day
Old 11-19-2012, 11:49 AM   #56
dumpstercrusher
Member#: 134940
2006 Impreza WRX TR
vf39 ewg tuned ppg gears
thanks for makin it clear for me!
dumpstercrusher is offline   Reply With Quote
Old 11-19-2012, 12:50 PM   #57
shadowmd
Member#: 193222
05 Wrx 1.5xtr 6spd
No problem man, it really is pretty sweet
Old 11-19-2012, 03:07 PM   #58
DavC825
Member#: 201736
12 IS-F..its white
07 Sti Blk
it uses a map sensor for fuel calculation. idle-low load= hi vaccum= low voltage, wot- high load= high voltage. nice thing is, vaccum leaks won't cause issues since the map sensor should see the false air and adjust fuel accordingly.
DavC825 is offline   Reply With Quote
