Old 11-07-2012, 08:31 AM   #1
marcellusreyes
Member#: 316622
2002 Bugeye R.I.P
2007 cgm wrx tr
Default P0171 help!
Hey guys I have a 2002 wrx and I've had a p0171 for a long time. I just got it back from my mechanic yesterday and everything was fine til this morning on the highway the light came back on. My MAF sensor was just replaced and i had a vacuum leak that was fixed.I checked my accessport and it said i have a p0171 again. Any help is appreciated.
marcellusreyes is offline   Reply With Quote
Old 11-07-2012, 09:04 AM   #2
czum09
Member#: 336078
I have the same issue, but I'm positive its a vac leak, spray some soapy water on your fittings, you may have a hairline crack in one of your lines
czum09 is offline   Reply With Quote
Old 11-08-2012, 09:26 AM   #3
ewd199
Member#: 336163
vacuum leaks don't always through codes like this but they can. what up pipe do you have? probably not your problem but my egt sensor was bad on my up pipe and threw this code. so idk it could me a number of things
ewd199 is offline   Reply With Quote
Old 11-14-2012, 10:16 AM   #4
marcellusreyes
Member#: 316622
2002 Bugeye R.I.P
2007 cgm wrx tr
It's all fixed now it ended up going away after I changed my spark plugs
