Old 11-07-2012, 09:02 AM   #1
Daniel_DeWitt
Member#: 325029
2002 Impreza 2.5RS
Midnight Black
Default Surging 2.5rs Mechanics Look Here
So I have been pulling hair out trying to figure out what is going on. My clutch went, and the motor started surging. It's a manual transmission and every time I let off the gas a little to stay at a constant speed, it surges and engine brakes. It isn't throwing any codes as of now, it was throwing a p1507 code, but since then I have replaced the front o2 sensor, and replaced the idle air control valve. If you have ANY insight on to what my problem is, please help me!
Daniel_DeWitt is offline   Reply With Quote
Old 11-08-2012, 10:06 PM   #2
yarrgh
Member#: 80465
2001 2.5RS
Black Diamond Pearl
Did you reset the ECU after installing these parts?
Old 11-08-2012, 10:07 PM   #3
Daniel_DeWitt
Member#: 325029
2002 Impreza 2.5RS
Midnight Black
Of course
Old 11-10-2012, 12:13 PM   #4
yarrgh
Member#: 80465
2001 2.5RS
Black Diamond Pearl
Well, give us more info. Any other recent maintenance done? Does it happen cold/warm? You say the clutch "went", did this problem present itself after clutch replacement? Have you checked/cleaned all electrical connections?
Old 11-10-2012, 02:14 PM   #5
ManualOverAuto
Member#: 304662
2001 Impreza L coupe
Sedona red Pearl
Neutral safety switch?
PCV valve?
I had that code pop up 2 separate times, a while ago, and I never did anything to specifically fix it.
I did, around the same time, replace the PVC valve, and haven't seen it since. Although I think the PCV valve is unrelated.
I'd look into the neutral safety switch, since you've already done the idle air control valve.
ManualOverAuto is offline   Reply With Quote
Old 11-14-2012, 12:34 PM   #6
Daniel_DeWitt
Member#: 325029
2002 Impreza 2.5RS
Midnight Black
Fixed this problem with a new throttle position sensor. Thank god
