Closed Thread
Old 11-07-2012, 02:30 PM   #1
afohlin
Member#: 240629
Default 02 WRX P0171 Problem
I have unfortunately have the dreaded P0171 in my 02 WRX. I've been doing a lot of reading on the issue and there are such a wide array of problems I'm not sure of what to do next. Only mods I have are Perrin crank pully, K&N short ram intake and Invidia turbo-back exhaust.
. My car just just under 150k miles and was running awful, pulsing when I would get on the throttle, and wasn't idling the best. I cleaned the IACV out and put in a new gasket (even though the old one was fine), changed spark plugs since I'm pretty sure they were the originals, and also changed the fuel filter. I have a K&N short ram that has been on the car for at least 6 years and I re-oiled the filter about a month ago. The MAF was really dirty so I clean it with MAF cleaner. When I was changing the spark plugs I noticed two hoses were disconnected either side of the car, so I reconnected and hose clamped them on so they wouldn't come out. I looked into it and they were just the breathers that connect to each other and run through the line in front of the intercooler so that shouldn't have been the source of the problem either. After about 100 miles the CEL came back on and was P0171 still. After all those changes the car was running the best it has in a long time and was driving like there were no issues anymore.
I was wondering what my next course of action should be. I checked to make sure no lines were blatantly unhooked but didn't see any except for the breather hoses. Is there a diagram or even a checklist of all vacuum lines to check? Would it be a good idea to pull the intercooler and check all of the lines for leaks? I don't know anyone who could swap MAF's for a day but should i just buy a new one and if the code doesn't go away return it? Another idea I had to was put the stock air box setup back in, even though the car has been running great for years with the K&N setup. Also, to check the front O2 sensor could I do the CEL fix and put a resistor where the plug is and see if it goes away? Any and all help is appreciated, thanks!
afohlin is offline
Old 11-07-2012, 03:09 PM   #2
AkSooby
Member#: 335923
02 Impreza Wrx
I think that with those mods you should have some kind of Engine Management ..I just installed a short ram intake on my 02 wagon and after driving for 20 min i got the p0171 ..I guess my car didnt like it..
AkSooby is offline
Old 11-07-2012, 03:53 PM   #3
super_usdm
Member#: 286211
2003 WRX
1993 Legacy SS
Smoke test to check for more vaccum leaks. Those unhooked breathers were not so good. That's a post maf vaccum leak meaning you were pulling unmetered air into the turbo while those lines were open.
super_usdm is offline
Old 11-07-2012, 11:45 PM   #4
filmsquad
Member#: 264711
U check ur gaskets on the turbo back exhaust u might need to get thicker gaskets from grimmspeed. Ur maf did u clean the smaller diodes this is something i did not see the only diode i saw was the big one until i saw the two smaller ones which needed much cleaning and that solved my issue after replacing ,cleaning evrything related to the p0171 code
filmsquad is offline
Old 11-09-2012, 08:51 PM   #5
afohlin
Member#: 240629
Thanks. Ill check the exhaust for leaks and put new gaskets in. My buddy has a vacuum tester I will try also
afohlin is offline
Old 11-09-2012, 09:41 PM   #6
Jackie leggs
Member#: 249794
02 WRX wagon
atomic orange pearl
If you do go the route of replacing the MAF, don't skimp out and get one at a parts store. get an OEM. I got one from NAPA and it would max out in the cold air and throw the CEL daily till i swapped back to one from Subaru.
Jackie leggs is offline
Old 11-15-2012, 03:36 PM   #7
afohlin
Member#: 240629
I didn't take the exhaust off but i checked everything out and it doesn't look like there is an exhaust leak. The car also doesn't act like their is one. I checked the vacuum hoses again and the passenger side valve cover breather hose came off again. I sent to Subaru and got a new hose but I can't get the old one out. It snakes through a bunch of stuff. Does anyone know what I have to take off to get that hose out and get a new one in? Thanks
Also I feel like the car is running the best run in a long time. Really getting on my nerves that it still is throwing the code.
afohlin is offline
Old 11-15-2012, 04:57 PM   #8
rdowner22
Member#: 329284
02 WRX Sport Wagon
I'm sure it's probably that your MAF sensor is bad... Do you have any local tuning shops? Being a friendly shop would help, but see if they can throw one on their and then see how she's running.
rdowner22 is offline
Old 11-15-2012, 05:41 PM   #9
WRX2EVOX
Member#: 203011
04 WRX
Intake manifold/tgv gaskets are also a cause. Look for oil residue on the top of the heads
WRX2EVOX is offline
Old 11-15-2012, 05:53 PM   #10
BugeyedBandit
Member#: 335225
2002 Stage 2 WRX
^ If you have oil on top of the heads directly underneath the intake manifold, is that a sure sign of bad IM or TGV gaskets? I have 2 small pools of oil there and get the P0171 code once in a while. I haven't gotten it lately though
BugeyedBandit is offline
Old 11-15-2012, 06:24 PM   #11
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
no wonder so many of these cars get blowed sky high....
Uncle Scotty is offline
Old 11-15-2012, 06:34 PM   #12
HinshawWRX
Medium Frank
Member#: 140114
2014 Porsche
GT3 (Currently on Fire)
HinshawWRX is offline
Closed Thread
