#1 |
Member#: 301247
Vehicle:09 Impreza 2.5i AT White |
my ATF level is over 3/4 of an inches above the hot full marker on the dipstick when car is warm. is this ok?
#2 |
Member#: 294461
NWIC
Vehicle:1997 Outback Sport Acadia Green Metallic |
Are you checking it with the car running? That makes a difference.
http://www.carcarekiosk.com/video/20...ck_fluid_level |
#3 |
Member#: 301247
no the car is off. i checked it after it was off for about 5min
#4 |
Member#: 294461
NWIC
There ya go. The car needs to be running so the pump can fill the tq converter and all the other mysterious gizmos in a 4EAT. Typically the level will be 3/4" to 1" over the fill line with the car off (In my experience)
#5 |
Member#: 301247
thank you very much i will try this tomorrow morning and report back!
#6 |
Member#: 165749
South East
Vehicle:2007 No YELLING on the bus! |
The owners manual had the procedure to chk the level. If my memory servers me it should be with Engine running in "park" and up to normal temp.
#7 |
Member#: 151079
Vehicle:2005 2.5RS RBP s-techs mad tyte yo |
^ I just looked at it earlier today. In addition to being up to temp, it said shift through all the gears first, then leave it in park, let it idle for a minute or two, and then give her a check.
