Old 03-19-2016, 12:21 AM   #1
STUDAndring
Member#: 61891
04 WRX
Pearl Blue
Default Before and After results
Ok so I have a 2008 STI and the point of this post is to get info and share info on my car before and after my upgrades. Right now as my car sits these are my upgrades.
AEM intake cold air
X-force 3 inch catless turbo back exhaust
cobb acessport with stage to map on it
DW65c fuel pump
Im going to take my car to the track next weekend and see what I run in the 1/4 before I install my new parts. New part list.
Grimmspeed uppipe with 44mm dump tube
tial 44mm Wastegate
blouch TD06-20G turbo 10cm
1000cc ID
fuel stumble kit
grimmspeed 3 port boost controller
protune by surgeline Portland
I will be doing my part install just after the track day. I have a dyno tune scheduled for the 22nd of April. Then I will run my car again at the track. What do you think my 1/4 miles times will before and after the install as well as whp numbers with a tune. BTW all tunes with be done with 92oct. I will post when I have more info and my 1/4 time slips as well and install pictures
STUDAndring is offline   Reply With Quote
Old 03-19-2016, 12:35 AM   #2
cjs06
Member#: 317489
2012 STi
Well surgeline uses a mustang dyno which typically shows very conservative results compared to other dynos. I'm guessing you'll see close to 350whp with those new parts, depending on how much boost/ timing your tuner goes with on 92 octane. If you have E85 in your area, I recommend it.
cjs06 is offline   Reply With Quote
Old 03-19-2016, 02:14 AM   #3
user1029
Member#: 57064
2008 STi IAG built
HTA86, Meth, 272s, Cos IM
350whp 12.1s
user1029 is offline   Reply With Quote
Old 03-19-2016, 06:21 PM   #4
pooster.online
Member#: 120461
2004 WRX STi JBP
any plans for an upgraded TMIC or FMIC?
pooster.online is offline   Reply With Quote
Old 03-19-2016, 10:58 PM   #5
STUDAndring
Member#: 61891
04 WRX
Pearl Blue
I know my weak spot is going to be octane and TMIC. After I get the car tuned Im going to keep it that way for the summer. My plan is to get a upgraded top mount and go e85. I dont know what my numbers will be but I hope around 375 to 400whp with e85. I dont want to go FMIC I like the functional top scoop. What is the best top mount upgrade.
Old 03-19-2016, 11:11 PM   #6
cjs06
Member#: 317489
2012 STi
Personally I recommend Grimmspeed's TMIC. I reclocated an IAT sensor in it and my intake temperatures have been on point.
Old 03-19-2016, 11:59 PM   #7
motorbykemike
Member#: 273868
or process west or spearco
motorbykemike is offline   Reply With Quote
