Old 04-22-2013, 07:27 AM   #226
02h20
Member#: 130079
2006 STI [email protected]
[email protected]
Looks nice
02h20 is offline   Reply With Quote
Old 04-22-2013, 07:56 AM   #227
Zee Biker
Member#: 166005
2005 Saab 92x
Beaten Silver
It's about time. You may have been the last power hungry soul to finally convert from a top mount, iwg, stock location setup!
Can't wait to see results even if they're cast rated down low! Remind me why you don't spin to 8 again; you're heads are semi built?!
Zee Biker is offline   Reply With Quote
Old 04-22-2013, 08:15 AM   #228
juanmedina
Member#: 133146
07 FPgreen [email protected]
WRX VF39+E85 12.0, 121mph
stock rods and stock valve train....
I bet I can spin it to 8k a couple of times but I don't want to risk it. I plan on build another block soon that I should be able to spin to 8k easy... but for now I will enjoy the car until it breaks.
Old 04-22-2013, 08:18 AM   #229
manitou
Member#: 193757
2006 XTI Limited
OBP, Junior tuned 573WHP
I bet I can spin it to 8k a couple of times but I don't want to risk it. I plant on build another block soon that I should be able to spin to 8k easy... but for now I will enjoy the car until it breaks.
Ate you tuning it or is Phatron tuning this build? Looking forward to see the new big powa!
Old 04-22-2013, 08:22 AM   #230
juanmedina
Member#: 133146
Mr Ron is doing the tuning
Old 04-22-2013, 08:26 AM   #231
manitou
Member#: 193757
2006 XTI Limited
How's it feel, did you do a test drive yet?
Old 04-22-2013, 09:52 AM   #232
juanmedina
Member#: 133146
Yeah it drives great. It it just loud.. I need to fix my exhaust leak. Hopefully I will be boosting soon. The is a local 1/8th of a mile even next week. I wish I could make it
Old 04-22-2013, 10:59 AM   #233
SW00P_G
Member#: 5591
EJ257 Gt35r
Get some low boost VD on here so we can see your spool!
That's the turbo I WANT!!
Which exhaust housing is it?
SW00P_G is offline   Reply With Quote
Old 04-22-2013, 11:10 AM   #234
C J
Member#: 132587
2006 JrTuned STi
[email protected]
Post up a under hood picture, I'm curious to see the fitment/turbo placement.
C J is offline   Reply With Quote
Old 04-22-2013, 11:20 AM   #235
manitou
Member#: 193757
2006 XTI Limited
Have you found the leak? It must be at the header/up flange or DP/Exh flange with the vbands on both ends of the turbine housing, you almost can't have leaks there if the vband clamp is on and tight!
What spring do you have in the gate...1bar?
I think we all want to see how this big boy spools. You have the vband .86AR HS right?
That's a big jump Juan 68 lb. to 90 lb.
Old 04-22-2013, 11:45 AM   #236
manitou
Member#: 193757
2006 XTI Limited
Did you plumb the gate correctly? Is it open!
Old 04-22-2013, 12:03 PM   #237
juanmedina
Member#: 133146
.82 AR v-band in/out
I will post some pics tonight...
yeah it was a big jump... I thought about getting the 6266 but I just decided to go big.
Yes I am running 1 bar springs on the wategate.
So after talking to Ben it seems that my leak is on the uppipe/watesgate. I didn't install the fire ring.... .
Old 04-22-2013, 12:07 PM   #238
manitou
Member#: 193757
2006 XTI Limited
Yeah, that'll do it. It should spool better also!
Easy to do when you're trying to get things done!!
Old 04-22-2013, 08:34 PM   #239
Corinator
Member#: 211974
2004 WRX STi PTE6466
2002 Sentra SE-R Spec V
You'll love that PTE6466. I special ordered the AMS 900x rotated kit with the PTE6466 and I love it. Right now I'm making 440whp on 18psi right now. Full spool at 4600rpm.
Corinator is offline   Reply With Quote
Old 04-23-2013, 06:51 PM   #240
Slimsti
Member#: 155696
2007 BLK STI Dom3XTR
415/405 Precision Tuning
I couldn't imagine making 440 at 18psi. That's so nasty. I need to go rotated like yesterday. Lol
Slimsti is offline   Reply With Quote
Old 04-24-2013, 12:42 AM   #241
Corinator
Member#: 211974
It's almost comical how easily my car makes power. It was making 400 whp on 16 psi, which is wastegate pressure. Right now at 18 psi on e85 not even pushing the car, exhaust gas temps are 1300* Fahrenheit. I run the same EGTs curising on the highway as I do when I'm on the car AND I just ordered my 07 2.5i NA intake manifold which will further improve efficiency. Once I get that in and my FPR, it's time to bring on the 40+ psi. I <3 big rotated turbos.
Old 04-24-2013, 06:17 PM   #242
juanmedina
Member#: 133146
Was the 440whp on 4th gear?
40psi + .... nice!
I can't wait to see your results. What is your motor setup?
Old 04-25-2013, 01:16 AM   #243
Corinator
Member#: 211974
40psi + .... nice!
Just waiting on my 07 2.5i Impreza intake manifold. Build done by Goodspeed Performance here in Scottsdale and all tuning done by Clark Turner. Can't believe how smooth and strong the car is at the same time.
Engine (think this is everything haha):
Sleeved EJ257 done by LA Sleeve
Cosworth pistons
Cosworth rods
Cosworth oil pump
08+ nitrided crank
ARP case bolts etc
ACL bearings
MAPerformance H11 head studs
Hand ported/polished heads
Ferrea stock size valves
SuperTech 82lb springs/titanium retainers
GSC S3 282 cams
AMR UEL big tube header
AMS 900x V-band rotated kit
Precision PTE6466
Tial MV-R 44mm EWG
Tial Q 50mm BOV
APS DR525 FMIC
Boomba Racing top feed fuel rails
TiC composite TGV housings
FIC 2150cc injectors
-8 feed fuel line
Aeromotive FPR
Walbro 460lph fuel pump hardwired
Megan Racing catback exhaust
Cusco catch can
Please excuse the shaky cam and my stupid intro, but at least it gives an idea of how aggressive these cams are:
Old 04-25-2013, 08:33 AM   #244
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
I think everyone with a custom setup needs to ditch the clockwise FMIC piping. It just makes no sense! If you're rotated you can run the pipe right off the compressor and under the intake manifold.
xluben is offline   Reply With Quote
Old 04-25-2013, 10:30 PM   #245
Slimsti
Member#: 155696
Oh yeah if ur custom there's no need for the clockwise routing
Old 04-26-2013, 01:17 AM   #246
Corinator
Member#: 211974
I say why complicate it and what am I really going to gain out of it? like 50 rpm of perceived spool? This isn't a stock turbo...
Old 04-26-2013, 08:29 AM   #247
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
It's about managing heat, not about shorter pipes. Even with a blanket your turbo will still get hot. And running the post intercooler pipe within an inch of the turbo really doesn't make any sense. Oh well. I'm sure it works, it's just not ideal and there's no reason to do it that way other than convenience (because someone sells pipes like that).
Old 04-26-2013, 08:35 AM   #248
juanmedina
Member#: 133146
I agree with Ben. The pipe over the turbo also makes working on the car more difficult
Old 04-26-2013, 10:43 AM   #249
kellygnsd
Member#: 32669
2007 2.34LR, EFR7670
LINK G4 hybrid STi
Lets see some installed pics Juan.
Old 04-27-2013, 11:45 AM   #250
juanmedina
Member#: 133146
My engine bay has never been the nicest:
I need to get a custom intake.
It seems that I have to take the transmission out... I cannot get the car in gear so is going to be a couple of weeks before I can post any results. So far it made 412whp 3rd gear on wastegate pressure 17.8psi. I also what to swap my bellhousing with an older bellhousing so I can use my speedo.
Does anyone has any experience with ACT 4-puck. I always had issues trying to get into third gear when drag racing. I am currently running the ACT xtreme plate a full face disk. I have used the 6-puck sprung clutch before with my five speed and I wonder if the 4-puck will help me with my third gear shifting issue. I only drive the car like once a week.
