Welcome to the North American Subaru Impreza Owners Club Sunday December 11, 2016
Old 01-07-2013, 08:50 AM   #51
juanmedina
Member#: 133146
07 FPgreen [email protected]
WRX VF39+E85 12.0, 121mph
Originally Posted by WhatTurboLag? View Post
which compressor housing? 2.4 or 3 inch?
I want videos!!!
3.4" compressor
Old 01-07-2013, 09:07 AM   #52
Zee Biker
Member#: 166005
2005 Saab 92x
Beaten Silver
Originally Posted by Zee Biker View Post
FMIC and EWG.
EDIT: I was pressed for time but wanted to get my words in, if only to revisit them later. The FMIC will allow you to run safer, repeatedly. If you're seeing the power drop on a pull, I'm willing to bet its from post intercooler IAT's. Fix that.
EWG is also just eliminating a bottleneck in the system. I know you ported your Green out, but an EWG skips it altogether. It does not get better than that.
All that said, you're still on thin ice with those rods and the above parts or deeper tuning will more than likely spell the end.
Originally Posted by juanmedina View Post
3.4" compressor
To make sure I'm heard in full. Also, since Crystel hits 27# at 4400 with a HTA86 and a FMIC, take some notes from him.
Zee Biker is offline   Reply With Quote
Old 01-07-2013, 05:28 PM   #53
Slimsti
Member#: 155696
2007 BLK STI Dom3XTR
415/405 Precision Tuning
Yeah a fmic doesn't add that much lag like people claim. I have 27psi on my dom 3 at 3950. Granted its no ht86 but still that's damn good for 55lbs/min
Slimsti is offline   Reply With Quote
Old 01-09-2013, 07:29 PM   #54
amalgrover
Member#: 183480
2011 Audi A3 Quattro
2009 Forester XT
UPDATE
The car is still running strong no issues at all. It has been about 10 months since I installed the engine.
I lowered the timing at peak torque like Crystal suggested for safety of the stock 09 STi rods and increased the timing by one degree at redline. 12* at peak torque and 22.5* at redline 7500.
I lost some mid range but It gained about 10whp from 6000rpm to redline. The TMIC is getting head socked as you can see... second pull . I am still running fairly rich 10.9-11.3 AFR from 4000rpm to redline.
So, what should I do next? This is a 68lb/min turbo it should be capable of making quite a lot more power. What should give me the biggest gains?
juan, my first and most important recommendation is you need to pick up a fmic...even a cheap one would be better than your tmic. i mean, my ssac fmic held up and performed just fine, and it was only $300.
second thing is your afr. i would recommend playing with leaning it out and see if you pick up any power. i made the most power on my setup by leaning it out to about 12.2. unfortunately, i am not really comfortable running that lean daily...so on my daily map i made the best power around 11.7.
third thing is timing. obviously, your peak tq is lower for a reason, but you still have some power on the table up top for sure. you should try adding a few degrees more up top and see if you pick anything up. obviously, if power doesn't come up, then put it back, but I bet you pick up power pretty well with some extra timing.
obviously, there are always better parts or things that are still on the "to-do" list on projects like these, but i just listed the things that would be cheap and easy ways to pick up power and improve things from where you are at right now.
amalgrover is offline   Reply With Quote
Old 01-14-2013, 06:41 PM   #55
MMY MSL
Member#: 335135
2007 WRX
WRC blue
Just curious, does this thing even get run on pump gas? I'm strongly considering an FP black and was wondering what kind of numbers your set up would yield on 91 or 93...
Nice thread so far though, good reading and lots of graphs
MMY MSL is offline   Reply With Quote
Old 01-14-2013, 07:25 PM   #56
CatfaceType-R
Member#: 81102
Probably leaving 40-70whp being absent from e85 to 91oct, little less with 93-94.
CatfaceType-R is offline   Reply With Quote
Old 01-14-2013, 08:35 PM   #57
amalgrover
Member#: 183480
2009 Forester XT
i dunno...it would depend on your location and specific setup...i picked up 125whp switching to E85 vs. 93oct with my FP Red setup, but that is mostly because of my high compression that i run forces me to be pretty conservative with boost and timing on regular pump gas.
...most NORMAL setups will have a difference right in the range that catface said...probably 50-75whp...
Old 01-18-2013, 10:43 PM   #58
Slimsti
Member#: 155696
I need to get some e85. I'll be damn near 500 at that point. E85 is like magic. Lol
Old 01-22-2013, 08:55 PM   #59
juanmedina
Member#: 133146
Yeah, E85 is awesome.
I am finally going to install my sponsored fiveO 2200cc injectors . Thanks again to Ron at Phatbotti and FiveO. These are going to help a lot so I can push my setup a little more.
I am still looking for a FMIC
Old 01-22-2013, 11:07 PM   #60
Slimsti
Member#: 155696
The turbo xs one is cheap and does the job. Those Injectors will be the icing on the cake. I can't wait to see them installed and ur new dyno
Old 01-22-2013, 11:20 PM   #61
amalgrover
Member#: 183480
2009 Forester XT
^ i agree. the turboxs fmic does a great job at a nice price. i ran the ssac knock off version of it on my budget build bugeye.
Old 01-22-2013, 11:22 PM   #62
CatfaceType-R
Member#: 81102
4" ets with a garett core option.
Old 01-23-2013, 03:06 AM   #63
rexblake
Member#: 178426
2010 S4
Gray
I know I'm late chiming in, but my fmic added almost no lag to my setup. It certainly wasn't noticeable on the street and the dyno was extremely close to my tmic, maybe 200rpm off. The big kicker was how the boost came on. With the tmic it was a very steady build up, with the fmic it was nothing nothing full boost. So, lag was almost non existent, transition response was noticeable. I'm sure with a good fmic you will pick up some serious gains though, particularly with that turbo. I'd expect a good 40-50whp, but that's pure guestimation.
rexblake is offline   Reply With Quote
Old 01-23-2013, 08:20 AM   #64
juanmedina
Member#: 133146
Yeah but the piping will not work with my APS 70mm CAI
The only piping that will works is the APS or Perrin
From my research the 4" ETS FMIC has thier own core, the garrett core that Buschur and others uses is the garrett 3.8" core. One thing that I found interesting is that the APS/ Treadstone core is 4.5" deep . I don't know how efficient is the core vs the garrett or who makes their core.
If I gain 10-20whp with the same settings (timing, boost, afrs) I would be super happy. I would not mind 200rpm if I gain power. As of right now if I decided to keep my APS CAI, that some how is not maxout .... I have to get the APS DR 725, The APS piping with the treadstone core or the perrin FMIC. I like the APS, treadstone the best but I heard that the core alone weights 30lbs.
Old 01-23-2013, 08:42 AM   #65
rexblake
Member#: 178426
2010 S4
Gray
Yeah, I was guessing that with tuning adjustments. I'm sure you could run more timing with a fmic. Probably quite a bit more if you want.
I loved my APS 525, great stuff if you can find them anyway.
Old 01-23-2013, 08:42 AM   #66
rexblake
Member#: 178426
2010 S4
Gray
Double
Old 01-23-2013, 08:48 AM   #67
achavez
Member#: 139320
2006 RA 1-4 5mt
wrx obp needs a e85 tune
im no tuner but im shocked the 70mm intake isnt maxed out with that turbo and power level
achavez is offline   Reply With Quote
Old 01-23-2013, 09:50 AM   #68
Slimsti
Member#: 155696
Oh yeah i just noticed you have the aps 70mm. I had the same and after buying the the turbo xs fmic and realising it didnt fit i just ditched it and went speed density. No more worries about maxing out the maf.
Old 01-23-2013, 10:11 AM   #69
Phatron
Member#: 36033
CEO PhatBottiTuning
2006 STi GTX3582 + Meth
are you sure your intake isnt maxed out? what are your MAFv?
my dom4xtr was pegging at 5 volts at 20psi spring pressure by ~5000rpm.
pretty much the only way you're not maxed out is if you have a massive post maf pre turbo leak.....so you're sucking air not being measured by the maf.
Old 01-23-2013, 10:28 AM   #70
juanmedina
Member#: 133146
I don't think so... it hits around 4.6-4.4V and it peggs at 400grams. If I were maxed out It would go lean, correct? My AFRs are on target. Since I am fixing that transmission leak that I told you, I had to pull my turbo so we will see if anything changes.
Old 01-23-2013, 10:29 AM   #71
juanmedina
Member#: 133146
I have to get a Kstech intake or something. Maybe I can go to speed density if Ron desires. Do you gained anything by going to speed density? what do I need to go to speed density? I don't feel like searching haha
Old 01-23-2013, 10:55 AM   #72
Phatron
Member#: 36033
CEO PhatBottiTuning
4.6 MAFv is way too low for what your power is saying. Your green was at 4.6 volts at 20.5 psi at redline.....so this black better be higher than that at 26psi.
Old 01-23-2013, 11:01 AM   #73
juanmedina
Member#: 133146
4.6 MAFv is way too low for what your power is saying. Your green was at 4.6 volts at 20.5 psi at redline.....so this black better be higher than that at 24psi.
I guess or something is going on. I was fine with the green also.
Old 01-23-2013, 11:09 AM   #74
Phatron
Member#: 36033
CEO PhatBottiTuning
if i had to guess, i'd say the turbo inlet is falling off the turbo. thats the most common place to leak between teh MAF and turbo.
and looking at the afr plot in post 28, something is definately up with the fueling.
Old 01-23-2013, 11:35 AM   #75
juanmedina
Member#: 133146
I should be able to have my car up and running in two days. I am going to make sure that the turbo inlet is secured.
