Old 01-23-2013, 12:45 PM   #76
Nuke209
Member#: 108089
2003 WRX
NF Performance
Go SD with the FMIC
Nuke209 is offline   Reply With Quote
Old 01-23-2013, 01:14 PM   #77
bebesito21
Member#: 176128
5862 ...baby boosted
Originally Posted by juanmedina View Post
I have to get a Kstech intake or something. Maybe I can go to speed density if Ron desires. Do you gained anything by going to speed density? what do I need to go to speed density? I don't feel like searching haha
you need an IAT sensor post intercooler. you have an 07wrx right? i dont think there is a speed density rom available for it (32bit ecu), so you would need the Cobb AP to switch or some other stand alone
bebesito21 is offline   Reply With Quote
Old 01-23-2013, 03:17 PM   #78
juanmedina
Member#: 133146
07 FPgreen [email protected]
WRX VF39+E85 12.0, 121mph
Originally Posted by Nuke209 View Post
Go SD with the FMIC
Yeah that would be good
I have Cobb so we can do SD.
So which intercooler core is the best? any test?
Old 01-23-2013, 03:32 PM   #79
Slimsti
Member#: 155696
2007 BLK STI Dom3XTR
415/405 Precision Tuning
All i can give you is my first hand experiance switching from a tmic and maf tuning to fmic and speed density. I have a fully built 07 sti with all supporting mods(check my thread in PPB if u wanna see a complete list). With the DOM 3XTR on the tmic and 23psi i was making 368/350. I added a omni 4 bar map sensor,turbo xs fmic and went speed denisty and made 416/405 @ 26.5 tapering to 24 by redline. The way it drives though is just night and day. Its one of the smoothest cars ive ever driven in
Slimsti is offline   Reply With Quote
Old 01-23-2013, 04:02 PM   #80
Phatron
Member#: 36033
CEO PhatBottiTuning
2006 STi GTX3582 + Meth
SD doesnt add power in itself....unless a MAF sensor limit was causing less boost to be run.
And the better drivability of SD increases as the size of the intake increases.
A 65mm VF car and a SD VF car should drive exactly the same and make the same power.
Whereas a 83mm maf car may have some drivability/cruise/idle issues whereas a SD car is less likely to.
I didnt have any drivability issues until i got up to an 89mm MAF. Even then, there was only 1 spot in the powerband that had a slight hesitation. Switching to SD that 1 spot was able to be tuned out.
Old 01-23-2013, 04:11 PM   #81
juanmedina
Member#: 133146
On EVOM they claimed that they gain some power by going to SD because you remove the MAF sensor which creates some flow restriction on the intake track.... but who knows
Old 01-23-2013, 04:21 PM   #82
Slimsti
Member#: 155696
Oh yeah i completely agree. The majority of power gain came from the extra boost i was able run from not having a heat soaked tmic limiting me.
Old 01-23-2013, 04:22 PM   #83
Phatron
Member#: 36033
CEO PhatBottiTuning
i'd say the stock location intake track on a subaru creates more of an obstruction (losses from all the bends) than the little maf sensor.
Old 01-23-2013, 05:39 PM   #84
Zee Biker
Member#: 166005
2005 Saab 92x
Beaten Silver
For an SD car, does intake size matter? For MAF stuff, there is a tangible WHP limit to how much flow a given diameter can support, but does that hold true when you remove the MAF?
Zee Biker is offline   Reply With Quote
Old 01-23-2013, 05:52 PM   #85
Phatron
Member#: 36033
CEO PhatBottiTuning
Its not really a "whp" limit for MAF....its a MAF voltage limit....which can then be correlated to a whp, but that # depends on octane or fuel being used.
The simple answer is yes, intake piping length, bends, filters and diameter can absolutely effect power. Im pretty sure there are plenty of examples out there of people removing the filter on a large turbo setup and picking up 20whp.
Also, you can run hybrid SD/MAF with cobb and utilize a 65mm MAF pipe to dial in idle/cruise and utilize SD in open loop when teh small MAF tube would be maxed out.
Old 01-23-2013, 06:15 PM   #86
slowgenius
Member#: 48350
04 Jackstands
Dirty PSM
does the maf sensor work correctly if its placed after the turbo and compensated for by subtracting the map? i would like to do that with my vipec.
slowgenius is offline   Reply With Quote
Old 01-23-2013, 09:06 PM   #87
Zee Biker
Member#: 166005
2005 Saab 92x
Beaten Silver
I guess I'm just looking for an ultimate carrying capacity for the various intake sizes as if there is a speed the air cannot surpass and it causes a backup or reverse pressure?
Like a red on a 65mm, all SD. Sounds like a terrible idea, kinda.
Old 01-23-2013, 09:31 PM   #88
Phatron
Member#: 36033
CEO PhatBottiTuning
I will give the same basic answer i did about the MAF sensor being in the flow....i really think the bends in the intake tract are more of a hinderance than the diameter. Especially the way most turbo inlets caulk into large stock location turbos....the "effective" cross section area is pretty small.
But to answer your question about pressure backup or reverse pressure....if there is a big restriction in the intake tract and you are running a silicone inlet....you can collapse them. IE the turbo will basically suck the inlet closed.
I would just keep it simple and match the intake to the compressor inlet. The largest stock location comp inlet is 3".....so simply pair it with a 3" turbo inlet and 76mm intake.
The only ones bigger are several of the FP turbos but you need to buy their custom turbo inlet anyway.
You really dont want increases in pipe diameter as you go through the intake. IE you dont want to run a 65mm intake with a 3" turbo inlet. You will get a sudden pressure drop and the flow will slow down.
Old 01-23-2013, 09:38 PM   #89
kellygnsd
Member#: 32669
2007 2.34LR, EFR7670
LINK G4 hybrid STi
The smaller the pipe that harder it will be for the motor to pull mass quantities of air through it. That's a mechanical loss and an efficiency hit which shows up as a loss of power.
Old 01-23-2013, 09:47 PM   #90
Phatron
Member#: 36033
CEO PhatBottiTuning
He's just looking for an exact number. Ie, how much power do u lose on a red going from 83, down to 76, 73, 70, 65....
I doubt anyone has done any testing like that.
Old 01-23-2013, 09:58 PM   #91
Zee Biker
Member#: 166005
2005 Saab 92x
Beaten Silver
If people see choke points on exhaust diameters (evo's), I'm sure there has got to be some research to be mined from simply tuning poorly matched cars.
Old 01-23-2013, 10:06 PM   #92
Slimsti
Member#: 155696
Is there any reason u never went ewg? Seems like u have a really well thought out car and are lacking a mod most higher horpsepower, large turbo setups have? Maybe u stated it already and I missed it, sorry if that's that case
Old 01-23-2013, 11:29 PM   #93
CatfaceType-R
Member#: 81102
Match the compressor inlet to the intake/inlet in sd for best results, fff maf. Imo any more that's not tapered correctly(theory) or just too much past the comp inlet id, can cause what Ron spoke of.
C
CatfaceType-R is offline   Reply With Quote
Old 01-23-2013, 11:46 PM   #94
achavez
Member#: 139320
2006 RA 1-4 5mt
wrx obp needs a e85 tune
All this subie intake talk just makes all my frustration resurface from trying to get the coupler on the turbo and my aps inlet. Subaru definitely did some unnecessarily difficult engineering with turbo and intake placement.
achavez is offline   Reply With Quote
Old 01-24-2013, 07:24 AM   #95
juanmedina
Member#: 133146
I just wanted to keep my setup simple and the EWG is too loud for me. I want to keep my car looking as a sleeper. The weight it sits with the 490whp it should trap 131-132mph, I drive it all the time at this level. I bet I can hit 550whp with the FMIC easy....
Old 01-24-2013, 07:30 AM   #96
Zee Biker
Member#: 166005
2005 Saab 92x
Beaten Silver
C
Simply stuff like the following remarks are what I'm looking for, or something of an explanation as to why it doesn't apply for our platform the same way is what I am after.
http://forums.evolutionm.net/10607382-post20.html
It's pretty widely accepted that hearsay is garbage. EWG and FMIC, step on the tune and hit 600. You're selling it as capable in your hunt for a rotated kit, so prove it!
(I see your STi rods and disregard the tangible limits of them)
Old 01-24-2013, 07:53 AM   #97
juanmedina
Member#: 133146
Patience is a virtude.... is a 68lb/min turbo it should be able to make 600whp.
As for the rods the 08+ STi rods are a little beefier than the older ones. I just need to be careful with keeping the torque as low as possible with smooth transitions.
This is not my final setup, I want to try to break the stock location world record. After whether I succeed or not.... I want to run a PTE 6466 on a different motor setup.
Old 01-25-2013, 09:35 AM   #98
Innovative Tuning
Member#: 67958
MY96 Time Attack
and 06 STI daily
I think we should look at torque at 4000rpm for comparison. Torque is what makes a car feel good and fun.
This is my car on your road dyno, 5sp 3rd gear, FP black 68lb/min stock location.
EQ - 05 STI, EQ Built Block, GT35 Rotated, E85 - 473whp ...65lb/min rotated
EQ - FP Red on E85 - 456whp! 65lb/min stock location
As far as power goes I have no doubt that I will make around the same power if I raise the timing to 26*
you probably hit 300wtq by 5000rpm
Those setups all look like a lot of fun and they do spool and make torque well at 4000-5000 RPM, but I don't see what you're arguing about. I've seen 600 wtq in that range in 3rd gear on a 6 speed.
Innovative Tuning is offline   Reply With Quote
Old 01-25-2013, 09:40 AM   #99
amalgrover
Member#: 183480
2011 Audi A3 Quattro
2009 Forester XT
^ he said that he is purposely keeping torque low to hopefully help prolong his current engine internals life...also, 3rd on a 6sp and 3rd on a 5sp are not exactly the same...especially considering his 5sp setup was an 06 wrx (3.70 vs. 3.90)...i could be wrong about the year of his 5sp, but I am pretty sure that it is 06.
amalgrover is offline   Reply With Quote
Old 01-25-2013, 10:00 AM   #100
Innovative Tuning
Member#: 67958
MY96 Time Attack
and 06 STI daily
If he had an 06 WRX tranny that's a longer gear and longer final drive. Both help his setup spool sooner, not the other way around.
Like I said, it's good setup and I'm not knocking it. I just don't understand why the hubbub over the spool/torque.
I would never knock someone for being safe with their engine. It's a lot more fun to drive your car than have it sit broken, regardless of how much power it makes. I'm running more hp and tq on my stock shortblock, but I'm the first to say I don't recommend it and I don't expect it to last.
