Old 02-05-2013, 08:37 AM   #151
amalgrover
Member#: 183480
2011 Audi A3 Quattro
2009 Forester XT
The air coming out of the crank vent enters after the maf sensor and isn't measured by the maf sensor, so I don't understand why you would say that an maf setup would be required to run back to the inlet. If you could please explain your reasoning on this, I would really appreciate it.
I ran VTA on maf setup for a LONG time on my personal vehicle, and had no issues whatsoever. I also know of quite a few shops that run VTA with maf setups without issue as well.
amalgrover is offline   Reply With Quote
Old 02-05-2013, 08:51 AM   #152
juanmedina
Member#: 133146
07 FPgreen [email protected]
WRX VF39+E85 12.0, 121mph
Originally Posted by Phatron View Post
dual intercoolers ftw
Well my APS CAI doesn't work with the Perrin FMIC. I have Amsoil filter and is too big and hits the tire.
So we are going to Speed Density.
Does anyone have a suggestion or were to install the IAT sensor?
Does it have to be on a straight section?
Old 02-05-2013, 08:59 AM   #153
amalgrover
Member#: 183480
2009 Forester XT
If actually planning to move the sensor, you are going to want it as close to the cylinder as possible because the IAT sensor's whole purpose in speed density is to estimate cylinder charge temps. So, the closer you get it to the actual entry of the cylinder, the more accurate these estimates will be.
Old 02-05-2013, 09:19 AM   #154
manitou
Member#: 193757
2006 XTI Limited
OBP, Junior tuned 573WHP
Place the IAT sensor right in front of the throttle body, use a chunk of stainless steel tubing as its less prone to heat soak than aluminum 321 is better than 304.
Old 02-05-2013, 09:49 AM   #155
kellygnsd
Member#: 32669
2007 2.34LR, EFR7670
LINK G4 hybrid STi
And its already combusted air so it wouldn't need to be metered again.
Old 02-05-2013, 10:36 AM   #156
juanmedina
Member#: 133146
what do you mean by chunk of tubing?
It has to be on that intercooler pipe that connects to the throttle body. I think the Perrin piping is STN STL but I am not sure. The location of the pipe sucks, it goes over the turbo and then besides the coolant filler tank .
Old 02-05-2013, 12:05 PM   #157
manitou
Member#: 193757
2006 XTI Limited
I meant that you should add a chunk of SS for the IAT sensor if the IC piping is all aluminum which I think the Perrin is.
Old 02-05-2013, 12:27 PM   #158
juanmedina
Member#: 133146
yes you are correct the piping is made of aluminum. I guess I can wrap the sensor with gold tape or something.
Old 02-05-2013, 12:43 PM   #159
amalgrover
Member#: 183480
2009 Forester XT
This is what I thought too, which is why I was wondering why it would matter if someone was maf vs SD...figured fastblueufo is a smart guy and may know some secret I don't...
Old 02-05-2013, 12:50 PM   #160
amalgrover
Member#: 183480
2009 Forester XT
You are going to want to be careful mating SS to aluminum...not saying don't, but I would plan this out carefully. SS and aluminum touching each other in an area exposed to the elements and constant heating and cooling cycles are possibly going to see corrosion if it isn't cared for properly.
Also, SS may be less prone to heatsoak, but it is also much harder to cool down once it does. My IC piping is SS instead of aluminum, and it takes much longer to cool it down than similar setups running aluminum piping...it also takes much longer to heat up vs aluminum piping too though. It is a tradeoff...
Old 02-05-2013, 12:53 PM   #161
juanmedina
Member#: 133146
yeap..
how about this guy IAT sensor location?
I ordered the bung and the sensor, hopefully I will have my car up and running soon.
Old 02-05-2013, 03:11 PM   #162
GT35RHybrid
Member#: 223237
According to you graph you made 527whp at 28psi and trapped 136mph . Mine should be somewhat lighter than your, we will see what I trap.
On the dyno 28 psi yes. On the street no...30-31 psi
Quit being skeered.
GT35RHybrid is offline   Reply With Quote
Old 02-05-2013, 03:15 PM   #163
GT35RHybrid
Member#: 223237
Turbo blanket the turbo and relocated the coolant tank = happier temps.
Old 02-05-2013, 04:04 PM   #164
manitou
Member#: 193757
2006 XTI Limited
You are going to have a silicone coupler connecting the aluminum and the SS piping both will hopefully have beaded ends and t-bolt clamps on the coupler! If you're really concerned about galvanic corrosion between the 2 metals then you can coat the aluminum but it should not be necessary. I would take the SS's better resistance to heat conduction over the better cooling properties of the aluminum! JMHO
Regardless get the IAT as close to the TB as possible without picking up heat from the surrounding components.
Old 02-05-2013, 08:45 PM   #165
amalgrover
Member#: 183480
2009 Forester XT
ahhh...I thought you were saying to weld a piece of SS to the aluminum...
Old 02-05-2013, 09:55 PM   #166
manitou
Member#: 193757
2006 XTI Limited
OK, now I see why you were concerned about the galvanic reaction/ corrosion. I would never weld the two!
Old 02-06-2013, 09:30 AM   #167
Subian
Member#: 202804
2002 PSM Sedan
The 2.0L that could
Juan, Here's one way to do it, but it involves taking off the IM.
Subian is offline   Reply With Quote
Old 02-16-2013, 07:09 PM   #168
Slimsti
Member#: 155696
2007 BLK STI Dom3XTR
415/405 Precision Tuning
Any updates?
Slimsti is offline   Reply With Quote
Old 02-17-2013, 07:06 PM   #169
juanmedina
Member#: 133146
Originally Posted by Slimsti View Post
Any updates?
I am on SD .
The car is super smooth and really quiet during cruising vs maf. Ron has done an amazing job with the tune. It seems that I lost about 200rpm of spool but the whp/wtq gains have been significant. I probably will be swapping the 1200cc injectors for the 2200cc injectors very soon.
Old 02-17-2013, 08:04 PM   #170
Slimsti
Member#: 155696
Told u sd was the way to go. What kind of power are u seeing as we speak?
Old 02-17-2013, 10:53 PM   #171
manitou
Member#: 193757
2006 XTI Limited
I am on SD .
SD is the **** with these bigger snails for sure! I'll bet the FMIC. accounts for some of that spool lost. Are you guys sure you can't get more out of the 1200's? You did the re-wire of the pump and you have the big Wally right? What your base at? You could also do a boost a pump!
Old 02-18-2013, 01:24 AM   #172
project_skyline
Member#: 153880
03 Evo VIII
2011 STI
That see's a lot of heat soak though, which makes for a pretty inaccurate signal.
project_skyline is offline   Reply With Quote
Old 02-18-2013, 02:16 AM   #173
Irv Weissmanhowerton
Member#: 278519
30r E85 sti 450+whp
kb'izzle
didnt see anything in his mod list that said fpr, that be a good amount of money to swap his lines/fittings and buy a regulator, if he doesnt have any rails or lines now, even more, could easily spend 350-500 on all of it, sure having the fpr makes adj nice, but im sure he'd rather get new injectors instead
Irv Weissmanhowerton is online now   Reply With Quote
Old 02-18-2013, 08:07 AM   #174
silverwerx
Member#: 81246
. .13 EVO X MR
.03 Cosworth Wrx, 14 Jeep
did you do that pull in 4rd gear? lol
silverwerx is offline   Reply With Quote
Old 02-18-2013, 08:42 AM   #175
manitou
Member#: 193757
2006 XTI Limited
Yeah easy 500 but I would think that Juan would want a FPR anyways and with a higher base pressure, the big pump re-wired he may have enough injector now!
