Old 01-18-2013, 10:21 PM   #126
V8sPFFF06sti
Member#: 236314
2015 WRX
Ahhh cool well good luck.. Great job too
V8sPFFF06sti is offline   Reply With Quote
Old 02-03-2013, 11:42 PM   #127
naked_dave1
Member#: 301692
I stumbled across this If anyone is looking for a semi pre made iPad mini mount. Should be able to make something work with our radio bezel, and it'd save a lot of time.
naked_dave1 is offline   Reply With Quote
Old 04-09-2013, 04:39 PM   #128
Moviemaggot
Member#: 352702
2010 Impreza 2.5i
Wow, this is awesome!!!! I think i might have to try this!
Moviemaggot is offline   Reply With Quote
Old 04-10-2013, 04:12 AM   #129
Bobert0989
Member#: 333876
2002 Impreza WRX
Are there no heat-related issues having it all enclosed?
Bobert0989 is offline   Reply With Quote
Old 04-23-2013, 02:40 AM   #130
naked_dave1
Member#: 301692
Go for it! Lot of work, but worth it!
I've had none so far. I've used the heater in the winter for a 5 hour road trip with the mini as my navigation with Waze and playing music from Pandora.
Old 04-23-2013, 04:25 PM   #131
Not-EWRX
Member#: 158043
2013 Wrx Hatch
What shift knob are you using?
Not-EWRX is offline   Reply With Quote
Old 04-24-2013, 12:13 AM   #132
naked_dave1
Member#: 301692
This knob with bead blasted finish and a custom circuit board engraving I designed.
Old 04-24-2013, 01:18 PM   #133
bpang1
Member#: 67225
2015 Audi S4
Red
Tip 'o the hat to OP...well done man!
bpang1 is offline   Reply With Quote
Old 04-26-2013, 12:22 AM   #134
JStrath
Member#: 318198
2004 WRX
JBP
iPad mini custom mount for car and home from Fifield Fabrications - YouTube
Has anyone attempted using this yet? I really want to try it but know absolutely nothing about fabrication or where to start when trying to form it to fit my dash.
JStrath is offline   Reply With Quote
Old 04-30-2013, 10:34 AM   #135
Tail24
Member#: 355047
What a great idea!
Tail24 is offline   Reply With Quote
Old 04-30-2013, 10:35 AM   #136
Tail24
Member#: 355047
You can probably get it done cheap by a plastic fabricator since you already have created the template which is some of the most expensive part
Old 05-29-2013, 09:30 AM   #137
naked_dave1
Member#: 301692
Made a video of the install to give you guys an overview and some apps I use.
http://youtu.be/gBf-XtPUfCU
Old 05-29-2013, 11:25 AM   #138
W.K.S.
Member#: 314986
Wow thats impressive. Of you dont sell these i will be bombarding you with questions when i do it myself. This idea is just too cool.
W.K.S. is offline   Reply With Quote
Old 06-01-2013, 10:22 PM   #139
1dweeb
Member#: 135470
Awesome job. Thanks for the video. I am very impressed.
1dweeb is offline   Reply With Quote
Old 06-02-2013, 12:07 AM   #140
TurboLag23
Member#: 347343
2004 Outback H6
2008 Acura TL
http://youtu.be/GTgtFeioiE4
Cool vid!!!
Always wanted to do this in my '04 Outback!! Probably going to go with an OG iPad though, since it fits right in the main cutout. Although your idea with the plug and the magnets might be a better method, because then I could slide it in and out when I wanted to take it out when I'm in a bad part of town to retain that OEM look, and maybe even recess the A/C and radio controls behind it. I know it might not apply to my car, but how much free space was there behind your dashboard? About how far could the head unit possibly be pushed towards the firewall from the stock position? Was it especially hard getting everything to fit?
Thanks
TurboLag23 is offline   Reply With Quote
Old 06-09-2013, 11:45 PM   #141
naked_dave1
Member#: 301692
Originally Posted by TurboLag23 View Post
Cool vid!!!
Thanks
Wish the best of luck to you on your install! The radio is recessed about 1.25" back from the stock location, space was very tight and my radio and it's wires JUST fit. It wasn't too hard to get everything to fit, lots of room for me underneath the radio to put all the wires.
Old 06-12-2013, 06:11 PM   #142
Kessel Run
Member#: 253044
2013 WRX Limited
This is an awesome job, but major question, how is it connected to the car to get RPM's etc? Can't simply be USB to the back of the radio can it?
Kessel Run is offline   Reply With Quote
Old 06-12-2013, 09:04 PM   #143
wrxeter
Member#: 134734
2013 WRX SE
Tangerine Orange Peel
Either a wifi or Bluetooth OBDII dongle. You can get them for like 30 bucks on flea bay or amazon.
wrxeter is offline   Reply With Quote
Old 06-12-2013, 09:17 PM   #144
Kessel Run
Member#: 253044
2013 WRX Limited
Awesome, and there is an OBD2 connection in the dash? Or is the WiFi/BT connector just plugged into the one under the steering column? Thanks.
Old 06-23-2013, 09:08 PM   #145
naked_dave1
Member#: 301692
The OBD2 connection port I used for my WiFi dongle to transmit the information to the iPad is under the steering column.
Old 06-23-2013, 11:03 PM   #146
SubSandwich
Member#: 360183
What's the advantage of this over the AppRadios with ARLiberator?
SubSandwich is offline   Reply With Quote
Old 06-26-2013, 10:35 AM   #147
azscooby
Member#: 115297
2002 ej207 vf34
I looked into doing both, and decided on the AppRadio with ARL route.
I like android and all of it's potential.
Go to ARLibertor forums and look at the possibilities....it's endless.
I am going to be running a dedicated device for my AR2, just to cut down on connection hassle. And I will be able to create a complete "Auto" profile on that dedicated device, instead of trying to make it work as both auto and phone.
They are both solutions to the problem of "Why the hell won't a HU manufacturer build what we want?" It has frustrated me to no end. So now when I see someone looking for what took me two years to figure out, I try to point them in either direction.
I also wanted to be able to run Torque Pro (check this out if you haven't already.)
I ended up having to buy a $200 adapter to make it work with my JDM ECU, but I'm almost there and couldn't be happier.
I do own an Ipad 4 so I'm not entirely android biased. You just need to find out what solution works best for you and decide what you actually want out of the end product.
azscooby is offline   Reply With Quote
Old 06-26-2013, 08:49 PM   #148
canstett05
Member#: 360683
Just wanted to say great job on the iPad install. I want to do the same thing but am thinking about keeping the stock radio. You think that you could mount the iPad in front of the stock radio or would it stick out too much and look weird? I know you would have to clear the volume buttons. Just wondering what you think.
canstett05 is offline   Reply With Quote
Old 06-27-2013, 02:36 AM   #149
farukgph
Member#: 360716
your post reply is very helpful for me.
Thanks.
farukgph is offline   Reply With Quote
Old 06-29-2013, 02:21 AM   #150
KRN FED
Member#: 279311
Wow!!!
KRN FED is offline   Reply With Quote
