Old 05-01-2013, 03:06 PM   #1
RallySoob
Member#: 74872
2006 STi
White/Black
Default Plasti dip wheel test
This is my first time using this stuff. I'm glad I chose to play it safe and do just one wheel because I need to re-do it. I learned a lot though. I believe I did too many coats too fast thus not allowing the under coats to dry. My adhesion was sub par at best. Accidentally got that KB43 look going haha
this is about half of the paint, maybe less.
RallySoob is offline   Reply With Quote
Old 05-01-2013, 03:17 PM   #2
slowguy
Member#: 4326
cool!
and wouldnt it have been quicker just to remove the wheel? haha.
slowguy is offline   Reply With Quote
Old 05-01-2013, 03:33 PM   #3
alecb
Member#: 335146
2004 STi
That's what I was about to say. It seems like a lot of taping. For some reason I really dig the green though.
alecb is offline   Reply With Quote
Old 05-01-2013, 06:32 PM   #4
breljohn
Member#: 353835
Love it
breljohn is offline   Reply With Quote
Old 05-01-2013, 07:40 PM   #5
Deadserial
Member#: 344075
2013 Wrx
Satin white pearl
Yes it helps if you remove the wheel then prop them up at a 45 degree angle. First couple coats light then a couple thicker. Just give them like 15 mins between coats.
Deadserial is offline   Reply With Quote
Old 05-01-2013, 09:11 PM   #6
RallySoob
Member#: 74872
2006 STi
White/Black
actually its alot faster to slip a bag through the spokes and wrap the brake than to remove the wheel. the same amount of taping would be required rather wheel is on or off. Im confused....cuz the 1/4 panel? that was less than a minute to do. its waaaay faster this way. not a little either... a lot faster. look it up. unless you have power toolz which I dont :/
It will definitely look better and be easier to paint if you take it off. Which I will do on my final job
This color is blaze yellow... I have blaze green and blaze blue also. I need blaze orange tho. Thinking about doing each wheel a diff color for starters and then pick one and swap out
Old 05-01-2013, 09:13 PM   #7
RallySoob
Member#: 74872
2006 STi
White/Black
this still isnt half of what I got coming on order. I have 13 cans of black coming alone.
Old 05-01-2013, 10:36 PM   #8
russgt
Member#: 256322
Save yourself 10 mins.... Wheels look crap. You choose.
russgt is offline   Reply With Quote
Old 05-01-2013, 11:34 PM   #9
Shipman
Member#: 312847
2006 WRX STi
2008 Legacy/2003 Forester
My opinion is to remove the wheels as well but as for the color I like it a lot, I think it looks way better than black. As long as you do it right I would say stick with the new color
Shipman is offline   Reply With Quote
Old 05-04-2013, 12:00 PM   #10
Daddy_Digital
Member#: 274205
2002 WRX Sport Wagon
World Rally Blue
Blaze yellow looks dope!
Daddy_Digital is offline   Reply With Quote
Old 05-04-2013, 06:21 PM   #11
subyhatch05
Member#: 296700
why do you have alllll that paint coming to plasti dip 4 wheels green?
subyhatch05 is offline   Reply With Quote
Old 05-04-2013, 06:51 PM   #12
easyeatlanta
Member#: 347906
2008 Sti - 6066
looks good i still would take it off then there would bo no taping of lugs and quarter panel, also may i suggest the use of notecards to keep overspray off the tires
easyeatlanta is offline   Reply With Quote
Old 05-04-2013, 11:06 PM   #13
Triff Traff
Member#: 241415
2004 Forest STI
notecards are sooo much easier to use than tape.. and i deff would have taken the wheel off..
Triff Traff is offline   Reply With Quote
Old 05-04-2013, 11:11 PM   #14
Andrew025
Member#: 303408
04 STi
Why do you need power tools to remove the wheels? Would take pretty much the same amount of time to remove manually.
Andrew025 is offline   Reply With Quote
Old 05-04-2013, 11:16 PM   #15
djomlas
Member#: 120050
Looks high school parking lot childish.
djomlas is offline   Reply With Quote
Old 05-05-2013, 12:52 AM   #16
Tomnompom
scammer
Member#: 343232
2012 WRX 5DR
If you removed the wheel, there's no taping required. Spray some tire shine on the tires and start painting. After everything dries, simply take a rag and wipe off the tire.
Tomnompom is offline   Reply With Quote
Old 05-05-2013, 02:44 AM   #17
Spec R
Member#: 187752
99 RS/X5/Volt
yeah, i'm confused. with all the money spent on plastidip, you could have had them done professionally. but eh, you're picking an obnoxious color so of course you'd want something temporary.
Spec R is offline   Reply With Quote
Old 05-05-2013, 03:04 AM   #18
RallySoob
Member#: 74872
2006 STi
White/Black
hatin mfers... I love it. Only on this forum is there more loud mouth d-bags than not
I dipped my sisters jeeps wheels, bmw 535i and brothers lexus. Couldn't have done all that with a pc job. plus I dont remember saying this was cost effective. jackazz. Its called fun
Pretty sure I am going to PC all four neon yellow when I am done with this gig tho
yep, that is exactly what I did. at first I had turtle tire black 4 month stuff on there but anything that gets on the rim lip needs to cleaned off with alcohol. the lip of the rim and lug nut areas are the places that need most attention to adhesion. This stuff comes up easy if not done right. I learned the hard way on the 1st attempt. I got it down now though. I bought some jack stands and proper ratchet for taking the wheels off quick like. And nice hydraulic jack. I guess that stuff is required when you own an STi so may as well get it now.
It comes off the tire very easily. Just use fresh rag and some type of cleaner to scrub away the residual after peeling. Takes a minute per wheel...quicker than time used to mask it all. Save some tape and materials too. I love that about this stuff. It is so temporary which is great for impulsive people like myself. I would much rather have a new color every month than be stuck with something you get sick of. Anything 'New' is fun in itself. Especially wheel colors
Old 05-07-2013, 11:05 AM   #19
13-ReX
Member#: 355674
2013 Subaru WRX
If you plasi-dip your rims just take them off the car and use index cards around the rim to block the over spray. Ill post a few pics so you can see what im talking about. I did it and it worked perfect. Its easier than taping them off or having the over spray.
https://fbcdn-sphotos-f-a.akamaihd.n...67674973_n.jpg
https://fbcdn-sphotos-b-a.akamaihd.n...95724709_n.jpg
13-ReX is offline   Reply With Quote
