Old 11-08-2012, 04:57 PM   #1
4Warned
Member Sales Rating: (7)
Member#: 66092
2011 STi sedan
COBB 20g [email protected]
Default COBB EWG kit w/44mm Tial valve
I have been working with Cobb products since I bought my car in September 2011 When they released their new external wastegate setup I knew it would be a good fit for my path to power.
The kit came neatly boxed and well protected. It included all the parts needed for installation and a separate spring chart for the Tial wastegate valve. Upon inspection I was very impressed with the finish, welds, and flange thickness of the Up-pipe.
Once the car was up in the air, installation took about 6 hours. Granted, we were taking our time and had a break or two in this time period. Installation was pretty straight forward with no major snags. The factory up-pipe was a bit stubborn to remove and took some turning and prying but nothing to frustrating. The Cobb piece fit perfectly and aligned perfectly with the turbo and exhaust manifold. Once in place we fitted the Tial wastegate and dump tube which cleared the Cobb downpipe perfectly. I don't see any reason why the kit would not work well with other aftermarket downpipes either. I used all new exhaust gaskets to ensure there were no exhaust leaks. I also wrapped my up-pipe with "lava wrap" to keep some of the heat in for better turbo spool. I give the kit a 10/10 in terms of quality and fitment!
During a test drive I noticed the turbo lag was definitely reduced...not that the stock turbo is laggy but the EWG setup does help. The car also seems to hold boost better with less "spike" The only thing that takes some getting used to is the sound. You can drive the car around without ever knowing you have a EWG setup until the pedal hits the floor
I have added some photos and videos of the setup for your enjoyment.
PUMP GAS DYNO
E85 DYNO
IN-CAR VIDEO
PUMP GAS DYNO
E85 DYNO
4Warned is offline   Reply With Quote
Old 11-09-2012, 10:50 AM   #2
JSchell1309
Member Sales Rating: (14)
Member#: 321321
2010 Ford SVT Raptor
Tuxedo Black
Great review! I was unaware Cobb had released an EWG kit for 08+. Replying to save this thread, def. want to hear the videos once I'm not at work.
What kind of boost control are you using? EBCS, MBC, or hybrid?
Also why did you choose 44mm over 38mm?
JSchell1309 is offline   Reply With Quote
Old 11-09-2012, 03:26 PM   #3
4Warned
Member#: 66092
2011 STi sedan
Grimmspeed 3-port EBCS
44mm is what the Cobb kit comes with.
Old 11-11-2012, 07:56 PM   #4
jockeygolfs
Member Sales Rating: (3)
Member#: 260868
2011 STI
Where are the photos and video?
jockeygolfs is offline   Reply With Quote
Old 12-01-2012, 07:14 AM   #5
sackytar
Member Sales Rating: (46)
Member#: 149262
03WR Rallycar/FXT/OB
PrimerGrey
Fancy! Your cars way too clean.
sackytar is offline   Reply With Quote
