Old 11-08-2012, 05:34 PM   #1
4Warned
Member Sales Rating: (7)
Member#: 66092
2011 STi sedan
COBB 20g [email protected]
Default Torque Solution TMIC
I had the honor to be one of the first to install the new Torque Solution top mount intercooler kit for the 2008+ STi models
Upon receiving the kit I noted it was very well built...sturdy brackets, nice welds, stiffer than factory IC fins. The unit was quite heavy compared to the factory unit. I also noticed how much deeper and taller the unit was
Installation took roughly 1.5 hours. Most of the time involved was swapping the turbo outlet pipe over to the Torque Solution unit. You will need new gaskets for the Y-pipe and the bypass valve so make sure to get these ahead of time. The TMIC kit uses all of the factory hardware and included a hose and fittings to bypass the vent tube mounted to the factory intercooler.
The fitment was great and only required a couple tries to get the couplers lined up. You will want to leave the throttle body coupler on the throttle body to ease installation. Since the unit is bigger than factory it also helps to remove the drivers side IC bracket before installation.
Once installed, I took the car to get dyno tuned and made record torque numbers on pump and E85. Myself and my tuner (Junior @ P&L) noted the TMIC after a hard dyno pull was cool to the touch on the backside with just a fan blowing on it. Junior was impressed with the quality and performance as was I.
I would certainly recommend this kit to anyone thinking of a TMIC kit for their STi not to mention it won't break the bank at only $600.00
93 OCTANE DYNO
E85 DYNO
4Warned is offline   Reply With Quote
Old 11-15-2012, 10:20 AM   #2
thisisntjared
Member Sales Rating: (3)
Member#: 177891
06 wrx wagon
child seat/tow hitch cgm
it looks very nice! is there any other information on efficiency, pressure drops, etc?
does it just match up to your oem IC ducting and bellows?
thisisntjared is offline   Reply With Quote
Old 11-15-2012, 12:37 PM   #3
IMPORTIMAGE
NASIOC Storefront Vendor
Vendor Sales Rating: (617)
Member#: 79304
CALL 941-257-9618
www.ImportImageRacing.com
looks good, i'm happy i have a few on the shelf
__________________
Open Daily
#1-941-257-9618 AIM= importimagerace
Best Deals on
!!! WE BEAT ALL PRICE QUOTES!!!!!
IMPORTIMAGE is offline   Reply With Quote
Old 11-15-2012, 08:41 PM   #4
The Duke
Member Sales Rating: (19)
Member#: 264877
Is TMIC thier own developed design?
The Duke is offline   Reply With Quote
Old 11-15-2012, 09:13 PM   #5
jthatch12
Member#: 321715
03 Big 16G WRX
Torque Solutions is a great company. I own various products from them and I always recommend them. Intercooler looks awesome man
jthatch12 is offline   Reply With Quote
Old 11-16-2012, 07:59 AM   #6
WRXLTD
Member Sales Rating: (17)
Member#: 136314
2014 Grand Cherokee
Cool...and good price too.
Too bad Torque Solutions didn't design their TMIC to accept the stock vent tubes, or supply the Y pipe & bypass valve gaskets.
Does it come in silver as well?
WRXLTD is offline   Reply With Quote
Old 11-30-2012, 10:33 PM   #7
Grippen
Member#: 329712
2005 Sti
^agreed
Grippen is offline   Reply With Quote
Old 10-10-2014, 03:14 PM   #8
chase1873
Member Sales Rating: (4)
Member#: 382339
2013 STI
Satin White Pearl
Just to be clear the only thing changed was the IC and you made 30hp and 50tq?
Any other variables that changed between the 330/410 run and the 360/460 pull?
I am a noob and rather impressed.
chase1873 is offline   Reply With Quote
Old 01-18-2016, 12:48 PM   #9
XTi24
Member#: 271749
2015 STi Launch Ed.
The only thing that changed between the 330/410 pull and the 360/460 pull was fuel type. The first run was with 93 octane, the second run was with E85. Yes, E85 does give that much of a power increase. Both runs were done with the same TMIC installed.
XTi24 is offline   Reply With Quote
Old 02-05-2016, 03:22 PM   #10
13lank
Member#: 417405
Thanks for the in-depth review with graphs. I might have to look at this setup especially given its price point.
13lank is offline   Reply With Quote
