Welcome to the North American Subaru Impreza Owners Club Thursday April 17, 2014
Old 11-08-2012, 08:02 PM   #1
STiNJ
Member#: 286054
2004 *BUILT* STi WRB
MODDED White bugeye-SOLD
Default RomRaider won't read ECU
I've read everything I can find on any related sites as well as all the FAQs on EcuFlash and RomRaider and can't seem to figure out my isseu.
I'll try not to leave anything out.
I downloaded EcuFlash and RomRaider 2 weeks ago, Read all the info on both sites, read up on all the "getting started" stuff and all the how to I could find. Got the new DEF files then (Before I got my Tactrix) loaded them into the manager and made sure everything was working "As much as it could without being hooked to the car".
I got my Tactrix today, Pluged it into my laptop (Win7) and allowed it to install the device. I see the Tactrix in device manager (COMM4). After that I got the latest DEF files (95) unzipped them opened RomRaider from C: went to the manager, Removed the old and added the new files. I plug the Tactrix into the OBDll plug and hit connect and it reads "Unable to send ECU init" I tried other usb ports (Tactrix still read COMM4), I tried it with and without the Green test mode plug connected. I tried connecting the cable to the car then the laptop, laptop then car and every way I could with no change. I was able to "read from ECU" With EcuFlash but it will not connect to RomRaider
I'm hoping that I am just over thinking the whole process and missing something simple but I'm asking for help "Someone point it out to me plz"
Thank you in advance, I know its a bit of a novel for a small issue and I appreciate your time
STiNJ is offline   Reply With Quote
Old 11-09-2012, 12:44 AM   #2
z
Member#: 41762
04 STi
CT-DE-FL rinse+repeat
Do you already have a protune on your ecu? (ecutek, accessport, etc)
z is offline   Reply With Quote
Old 11-09-2012, 01:05 AM   #3
STiNJ
Member#: 286054
Yes the car was tuned before. I know it had a utech but it was removed by Dyno inc in VA and Im not sure how it was tuned after that
Thanks
Old 11-09-2012, 07:55 AM   #4
quazimoto
Member#: 70395
You need to have the logger definitions as well installed and tell Romraider where they are. Download Learning View from Romraiders site to verify there is not a cable issue. 99% of the time it is user error. If you have Vista or 7 I hope you installed the programs as instructed in the FAQ's you read.
quazimoto is offline   Reply With Quote
Old 11-09-2012, 08:33 AM   #5
STiNJ
Member#: 286054
Thank you, I appreciate the info.
Ill keep the thread up to date
Old 11-09-2012, 01:03 PM   #6
STiNJ
Member#: 286054
NewB mistake.... I had everything setup but when I updated the logging defs I applied them to the ECU defs.
Thank you quazimoto for reminding me to check over that again
Thanks for the help
Old 02-01-2013, 09:35 AM   #7
sheshani
Member#: 345603
2002 STI Impreza 200
I have problem reading ecuflash but I can access data from learning view and romraider logger.
my ecu info(learning view) :
CAL ID:A4SD900B
Description: 01/02 JDM Impreza STi MT/AT
ECU ID:1B04490605
when I try to read rom I got interface closed
green plugs connected.
when I try to pull with 2001/2002 non USDM I get interface close directly
but when I try STI 2004 I get some readings but it stopes
[12:40:40.375] EcuFlash Version 1.44.3719
[12:40:40.375] OS Version Windows 7
[12:40:40.375] Qt Version 4.8.0
[12:40:40.391] 63 memory models read.
[12:40:40.391] scanning for metadata models in C:/Program Files/OpenECU/EcuFlash/rommetadata
[12:40:40.531] 611 ROM metadata models scanned.
[12:40:40.531] checksum module "subarudbw" loaded.
[12:40:40.531] checksum module "mitsucan" loaded.
[12:40:40.531] checksum module "mitsuh8" loaded.
[12:40:40.531] patch module "Subaru CAN Enhanced RAM Parameter Logging" loaded.
[12:40:40.531] patch module "Mitsu CAN RAM Parameter Logging" loaded.
[12:40:40.531] flashing tool "wrx02" loaded.
[12:40:40.531] flashing tool "wrx04" loaded.
[12:40:40.531] flashing tool "sti04" loaded.
[12:40:40.531] flashing tool "sti05" loaded.
[12:40:40.531] flashing tool "mitsukernel" loaded.
[12:40:40.531] flashing tool "mitsukernelocp" loaded.
[12:40:40.531] flashing tool "mitsubootloader" loaded.
[12:40:40.531] flashing tool "shbootmode" loaded.
[12:40:40.531] flashing tool "shaudmode" loaded.
[12:40:40.531] flashing tool "subarucan" loaded.
[12:40:40.531] flashing tool "subarucand" loaded.
[12:40:40.531] flashing tool "mitsucan" loaded.
[12:40:40.562] J2534 API Version: 04.04
[12:40:40.562] J2534 DLL Version: 1.00.3719 Dec 28 2012 23:38:48
[12:40:40.562] Device Firmware Version: 1.12.3688
[12:40:40.562] Device Serial Number: TAKYVQHs
[12:40:40.562] interface close
[12:40:40.593] J2534 API Version: 04.04
[12:40:40.593] J2534 DLL Version: 1.00.3719 Dec 28 2012 23:38:48
[12:40:40.593] Device Firmware Version: 1.12.3688
[12:40:40.593] Device Serial Number: TAKYVQHs
[12:40:40.593] interface close
[12:40:40.625] J2534 API Version: 04.04
[12:40:40.625] J2534 DLL Version: 1.00.3719 Dec 28 2012 23:38:48
[12:40:40.625] Device Firmware Version: 1.12.3688
[12:40:40.625] Device Serial Number: TAKYVQHs
[12:40:40.625] interface close
[12:40:54.774] using metadata XML ID read_sti04 from file C:/Program Files/OpenECU/EcuFlash/rommetadata/read templates/read_sti04.xml
[12:40:54.805] J2534 API Version: 04.04
[12:40:54.805] J2534 DLL Version: 1.00.3719 Dec 28 2012 23:38:48
[12:40:54.805] Device Firmware Version: 1.12.3688
[12:40:54.805] Device Serial Number: TAKYVQHs
[12:41:01.421] kernel get version
[12:41:01.624] interface close
[12:41:01.655] J2534 API Version: 04.04
[12:41:01.655] J2534 DLL Version: 1.00.3719 Dec 28 2012 23:38:48
[12:41:01.655] Device Firmware Version: 1.12.3688
[12:41:01.655] Device Serial Number: TAKYVQHs
[12:41:01.842] interface close
[12:41:01.873] J2534 API Version: 04.04
[12:41:01.873] J2534 DLL Version: 1.00.3719 Dec 28 2012 23:38:48
[12:41:01.873] Device Firmware Version: 1.12.3688
[12:41:01.873] Device Serial Number: TAKYVQHs
[12:41:02.045] SSM2 init
[12:41:02.201] SSM2 ECU ID is 1B04490605
[12:41:04.229] interface close
sheshani is offline   Reply With Quote
Old 02-01-2013, 10:36 AM   #8
quazimoto
Member#: 70395
Are you using a flash block?
Old 02-02-2013, 05:41 AM   #9
sheshani
Member#: 345603
Default not sure what you mean with flash block
not sure what you mean with flash block.
im using open port 2 hardware
Old 02-02-2013, 08:05 AM   #10
quazimoto
Member#: 70395
The 16 bit ECU's require more than just connecting the diagnostic connectors. They require a "flash block". Another jumper. They are on Tactrix's website. You can also make one with. A piece of wire and some spade connectors.
Old 02-02-2013, 11:39 AM   #11
sheshani
Member#: 345603
i connected them and got the image ,,, but I don't know where to start as beginner... a lot of information but now clear path to start
