Old 11-09-2012, 10:28 PM   #1
Acuna989
Member Sales Rating: (1)
Member#: 323493
2003 WRX Hybrid 6sp
Default Beatrush engine and transmission mount review 05 STi
Just installed the beatrush engine mounts and tranmission mount on my 05 STi last week. Did it in my garage on jack stands while jacking the engine up at the oil pan (using a piece of wood to disperse the weight). Used the following thread as a guide for installation (http://www.iwsti.com/forums/how-inst...ne-mounts.html).
The motor mounts are definitely a bitch to get off. I have know idea how people can break the rear bolts with a wrench, I even got the longest 14mm wrench I could find but it still didn't have the leverage to break them loose. I ended up disconnecting the TMIC, pitch stop and both mounts from the subframe so I could lift the engine enough to get to the rear bolts with a flex head ratchet and 14mm socket. (http://www.sears.com/craftsman-3-8-i...&blockType=G11). After I had the new engine mounts installed I grabbed the motor from the top of the engine bay and guided it back into the subframe while lowering the jack down.
Pros:
Car feels much more solid when cornering.
Super smooth gear engagement. 2nd-6th
Increased throttle response.
No torque steer.
Cons: extra cabin noise
Overall I'm very pleased with the upgrade and the quality of the mounts. My best description is that it makes the car feel more like a muscle car. Yes the engine mounts do transfer a lot of noise but the vibration on the other hand was better than I was expecting, it really isn't all that bad. I personally didn't notice any increase in NHV from the transmission at all. I also have a full polyurethane bushing kit and the whine is minimal. I would say the Beatrush transmission mount would be a good upgrade for anybody. The engine mounts might not the best for a stock DD but are definitely a good upgrade if your running a larger turbo and wants to enjoy the extra throttle response.
Not my pics but a good comparison of the two mounts vs the stock units.
Acuna989 is offline   Reply With Quote
Old 11-19-2012, 08:45 PM   #2
Dale2011WRX
Member Sales Rating: (10)
Member#: 304299
2011 WRX, white
2014 Crosstrek, tangerine
Did you actually use the oil pan as a jack point?
Dale2011WRX is offline   Reply With Quote
Old 11-20-2012, 12:30 PM   #3
V8Slayer
Member Sales Rating: (18)
Member#: 111565
2007 Legacy Spec.B
324hp/313tq EVOIII 16G
Quite a lot of people use this as the main jacking point to do motor mounts. Op, how do these compare to the Group N mounts? I like my group n mounts but they are starting to feel "soft" after 2 years of use.
V8Slayer is offline   Reply With Quote
Old 11-20-2012, 02:04 PM   #4
RedOnyx
Member#: 338356
08 WRX
One thing I suggest when using the oil pan as a jack point is to use a block of wood or something wider to dispurse the weight of the motor so that you do not puncture your oil pan.
RedOnyx is offline   Reply With Quote
Old 11-20-2012, 02:05 PM   #5
V8Slayer
Member#: 111565
2007 Legacy Spec.B
Good point, forgot to mention that lol.
Old 11-27-2012, 01:24 PM   #6
sackytar
Member Sales Rating: (46)
Member#: 149262
03WR Rallycar/FXT/OB
PrimerGrey
Yeah I got use to my Group Ns and they feel like jello.
sackytar is offline   Reply With Quote
Old 11-30-2012, 11:27 PM   #7
Grippen
Member Sales Rating: (19)
Member#: 329712
2005 Sti
Group n's ARE jellow lol get a aluminum one with some polyurethane bushings. Like 70+$
Grippen is offline   Reply With Quote
Old 12-01-2012, 08:11 AM   #8
sackytar
Member#: 149262
PrimerGrey
Poly mounts are junk. Destroyed some motor mounts of crappy quality.
Old 01-16-2013, 01:25 AM   #9
Acuna989
Member#: 323493
2003 WRX Hybrid 6sp
Yup. used a piece of wood with no issues, three months later no leaks around the oil pan. I also have a jack with a fairly large jack point.
