Notices
Old 11-12-2012, 08:07 PM   #1
rustyg23
Member#: 277681
05 sti
graphite metallic black
Default sti cam bucket question
Can anyone tell me what clearances they are supposed to be on the cams .05 sti . I have a set of heads and need buckets where can I get them and how do I no what size I need will 2.55 or 2.0 buckets work if they clearance correct?
rustyg23 is offline   Reply With Quote
Old 11-13-2012, 02:28 AM   #2
rustyg23
Member#: 277681
05 sti
Help please
Old 11-13-2012, 03:44 PM   #3
SubieWolfSti
Member#: 331579
2006 Impreza WRX STi
Gray
Your gonna have to install the cam with the current buckets to check the clearance you need to choose the right bucket for your car. I recently did a valve adjustment on my 06 STI, i dont know the spec for you 05 but just as a reference the valve clearance on mine is and the formula to figure out your shim is included. My advice get the service manual because you will need it.
Intake: 0.200.02 mm (0.00790.0008 in)
Exhaust: 0.350.02 mm (0.01380.0008 in)
Intake S = (V + T) - .20
Exhaust S = (V + T) - .35
btw .20 and .35 are in mm.
SubieWolfSti is offline   Reply With Quote
Old 11-13-2012, 10:26 PM   #4
rustyg23
Member#: 277681
05 sti
Thanks man helps but what sucks is I don't have any buckets bc I got the heads with out them could I put Wrx buckets in them to measure they out
Old 11-13-2012, 10:31 PM   #5
the suicidal eggroll
Member#: 51961
2005 STi
2012 WRX
You'll need a set of feeler gauges and a set of good micrometers, but yes, you can put in any of your current buckets that are thin enough to give a decent measurement with the feeler gauge.
Old 11-13-2012, 10:38 PM   #6
rustyg23
Member#: 277681
05 sti
Ok cool and I do do u no how the numbers on the caps work like 505 and 490 like is that any kind of measurement?
Old 11-13-2012, 10:44 PM   #7
SubieWolfSti
Member#: 331579
Gray
The number on the caps are part numbers, however being that they are used you still need to measure them to confirm the actual clearance. for example,
Part No 13228 AB462 is 5.04mm (0.1984 inches)
Old 11-13-2012, 10:47 PM   #8
rustyg23
Member#: 277681
05 sti
Ah thanks guys helps a ton
Old 11-13-2012, 11:32 PM   #9
Member#: 51961
2005 STi
2012 WRX
This is very important, and is why you need a good micrometer. The buckets will thin out over time, you need to use the ACTUAL thickness of the bucket you use to do your measuring, not the specified thickness from the part number. They WILL be different.
Old 11-14-2012, 12:49 PM   #10
rustyg23
Member#: 277681
05 sti
Thank I do understand that just wanted to no that way if I need to get some new ones
