Welcome to the North American Subaru Impreza Owners Club Friday February 12, 2016
Old 11-10-2012, 06:06 PM   #1
Tripintaz
Member Sales Rating: (8)
Member#: 245218
2013 STI Limited
Default ACT HD Street Clutch & Streetlight Flywheel
Just had this combo installed on my 2010 WRX. My stock clutch was abused a little and was suffering from a little bit of over heating.
First impression is the clutch is very grabby. Stalled it twice on the way home from the shop but you just have to adjust your driving style to accommodate. I hardly noticed any chatter at all so I imagine there will be pretty much ZERO chatter once its broken in. The pedal feel is slightly heavier than stock. Strangely enough it felt lighter than stock only because my OEM clutch was abused and had been worn down and over heated from my "spirited driving". My brother also has a 2010 WRX but he still has the OEM clutch and he never abuses his car like I do. So compared to a very low mile OEM clutch, the ACT combo is only slightly heavier. It does bring a ON-OFF like feel of the pedal, but I prefer this over the OEM soft engagement style.
The lightweight flywheel is very noticeable. The engine revs a little quicker and you feel the extra HP/TQ that is making it to the wheels. (For clarification, the LWFW does not make more power, it just allows less power loss between the engine and the wheels making the car a tad bit faster) No CEL, no adjustments needed in my tune. I like this setup way better than the stock clutch.
The ONLY downside I noticed was a slight gear ratted on deceleration. This is normal and I was prepared for it. I only noticed it very faintly in 3rd gear but its probably happening in the other gears. I have my entire drivetrain upgraded to poly mounts as well as my shifter so the gear rattle would be more pronounced on my car than a car with all OEM bushings. I mean the gear rattle is so faint I barely hear it. If the radio is on its not audible. Completely stock WRX's have the gear rattle but you don't hear it because of the soft OEM bushings and heavier stock flywheel.
So my review is 4.75 stars out of 5 for this combo. I took .25 away due to the slight gear rattle. It does not bother me, but if the gear rattle was the same level as OEM I would have given it a 5 of 5. If you stick wit the OEM flywheel you probably wont have any gear rattle noise increase.
I recommend this clutch for anyone looking for a street usable clutch that does not sacrifice much if any daily driveability.
Tripintaz is offline   Reply With Quote
Old 11-28-2012, 02:04 PM   #2
Kirby11WRX
Member Sales Rating: (2)
Member#: 316753
2011 WRX Stage 2
Do you happen to know the part #?
Kirby11WRX is offline   Reply With Quote
Old 11-28-2012, 04:45 PM   #3
Tripintaz
Member#: 245218
2013 STI Limited
Nope, ordered it from Josh @ ImportImagaRacing. He will know that part #'s.
Old 11-28-2012, 05:20 PM   #4
Mike 01Hawk
Member Sales Rating: (3)
Member#: 219162
2011 WRX Sedan Base
http://www.advancedclutch.com/
SB5-HDSS / 600480
Mike 01Hawk is offline   Reply With Quote
Old 11-28-2012, 08:06 PM   #5
IMPORTIMAGE
NASIOC Storefront Vendor
Vendor Sales Rating: (615)
Member#: 79304
CALL 941-257-9618
www.ImportImageRacing.com
thank you, sorry would have chimed in earlier...
it is a nice quality setup, im glad you are enjoying it!
__________________
Open Daily
#1-941-257-9618 AIM= importimagerace
Best Deals on
!!! WE BEAT ALL PRICE QUOTES!!!!!
IMPORTIMAGE is offline   Reply With Quote
Old 11-29-2012, 10:36 AM   #6
Tripintaz
Member#: 245218
2013 STI Limited
P.S. quick update after a bout 700 miles of break in.
Clutch chatter is gone completely unless I try to engage the clutch at to low of an RPM. The gear rattle on deceleration actually got quieter. It's about half as loud as it was right after the LWFW was installed.
I'm a happy customer. Thanks for the great deal and fast shipping Josh!
Old 07-30-2013, 08:20 PM   #7
wrxmike09
Member#: 207536
2009 WRX
OP, how's it going with this clutch setup? I'm looking at getting the same one for my 2009 WRX. How many miles do you have on it now and do you still like it?
wrxmike09 is offline   Reply With Quote
Old 07-31-2013, 12:15 AM   #8
Tripintaz
Member#: 245218
2013 STI Limited
I traded that car in. But I liked the setup. If I could do it again I would have kept the stock weight flywheel.
Old 08-13-2013, 11:23 PM   #9
street carp
Member Sales Rating: (15)
Member#: 216768
2016 STI
HYPER BLUE
i had the street clutch in my 04 wrx and it only lasted a year from some drag launches at the track. it was def stiffer than stock and it held the power. i was running the stock 5 speed and an evo 3 16g with all the supporting mods. i replaced it with a south bend clutch and that was the awesomest clutch i've ever had.
street carp is offline   Reply With Quote
Old 06-10-2014, 05:55 PM   #10
Asharus
Member#: 276300
2015 Ford Mustang GT
Oxford White
my tech recommended this clutch. my stock clutch just started slipping.
so you were happy with it? if you needed to replace your clutch today you would still go with an HDSS + OEM flywheel?
Asharus is offline   Reply With Quote
