Old 11-10-2012, 07:07 PM   #1
leonbmx
Member#: 82864
2005 MPS Wagon HTA35
Domtuned Stage $$$$$
Default Pegasus 4430 Kill Switch ignition cut, which wire?
I have a 2005 STi, the other day I installed a pegassus racing 4430 kill switch , but when I flip the switch, nothing happens and the car just keeps running.
This is the diagram that I used:
For the ignition cut, I used the Main relay wire (Plug B136, wire 7, main switch), under the assumption that if I cut that, the engine would die.
What am I doing wrong? Is there a different wire I should have interrupted instead?
leonbmx is offline   Reply With Quote
Old 11-11-2012, 12:33 PM   #2
Token-Negro
Member#: 81659
2006 STI / 2010 FXT
Aspen White / Silver
I used on the otherside of the weather pack connector two green wires, if my memory servers me correct they were the coil pack power wire green/red and the ignition swtich.
W= Resistor to ground
1 = Just a jumper from main power to car
Z = Ignition coil power wire Green/Red
2 = Ignition switch wire, I believe is also Green base
Token-Negro is offline   Reply With Quote
Old 11-12-2012, 10:04 AM   #3
leonbmx
Member#: 82864
As usual that looks like a work of art
However, now I am even more confused... My impression was that I needed to find a wire, cut it in half and route it through the relay. From your post it sounds like Z and 2 are different wires?
Old 11-18-2012, 02:44 PM   #4
leonbmx
Member#: 82864
bump for confusion still here
Old 11-18-2012, 02:55 PM   #5
Token-Negro
Member#: 81659
2006 STI / 2010 FXT
Ok this makes since to me now, yes the green wire is the coil wire, that goes to the ignition normally, but you connect the Kill switch inline to the ignition. So the Green wire that’s going to the ignition switch now, cut it and have it go to Z then connect another lead from 2 back to the ignition switch.
Old 11-18-2012, 04:05 PM   #6
leonbmx
Member#: 82864
so which pin are we talking about then with the "green coil wire", as right now I used the "main switch" (05 STi ECU Diagram - Plug B136, wire 7, main switch)
Almost sounds like I should be using "B137, Pin 14, Ignition Switch" instead
Old 11-18-2012, 07:14 PM   #7
Token-Negro
Member#: 81659
2006 STI / 2010 FXT
I would look at the diagram for the ignition swtich not at the ECU.
Old 11-18-2012, 07:21 PM   #8
leonbmx
Member#: 82864
Good point! Any leads on where on the interwebs I may find that?
