Welcome to the North American Subaru Impreza Owners Club Saturday September 5, 2015
Old 11-10-2012, 08:56 PM   #1
slava from goshen
Member#: 152176
2001 2xImpreza 2.5RS
BRP/SRP
Default Roll-bar and sun roof delete
I have 2001 RS.
Finally test fitted my autopower race roll bar. I did specify that car has sun roof (I think, it was long time ago)
What are some of my options for delete if I can't make it work? I'm asking in this section because I'd like to take this car out on a road corse next year.
thanks for all the help
-slava
slava from goshen is offline   Reply With Quote
Old 11-11-2012, 02:09 PM   #2
mykrrrr
Member#: 733
'13 Focus ST
So does it fit or does it not fit? You don't really say.
If you're looking to delete the sun roof, you can weld in a blanking plate. If you want to keep the roof, you could cut down the hoop and re-weld the mounting plates.
mykrrrr is offline   Reply With Quote
Old 11-11-2012, 03:06 PM   #3
Rokkit
Member#: 84181
NASA #530 GTS2
Or you could do what I did and rivet a piece of aluminum down to the roof
Rokkit is offline   Reply With Quote
Old 11-12-2012, 07:19 PM   #4
slava from goshen
Member#: 152176
BRP/SRP
It didn't fit, but I didn't try making it fit yet either. I do want to delete all that, thought of a manual pop up option of some sort.
Want to stay away from welding at this point.
Old 11-12-2012, 07:20 PM   #5
slava from goshen
Member#: 152176
BRP/SRP
Rokkit, I like your rs. I want to flare mine but don't know what would be a good wheel size set-up. Don't want to go too heavy. Car will see auto-x and some track. Some weekend driving.
Old 11-13-2012, 10:32 AM   #6
tdrrally
Member#: 91562
1995 impreza,awd
reddish
what form of racing is that car set up for?
tdrrally is offline   Reply With Quote
Old 11-13-2012, 12:21 PM   #7
Rokkit
Member#: 84181
NASA #530 GTS2
I run a 245x40x17 Hoosier or goodyear (Road Race Compound) and I think I'm going to cut those 60mm s240 flares down to 30mm this winter. You could stuff a 275 under those 60mm flare easy.
I also run a +45 enkei with a 15mm spacer... so it's a bit of offset.
(just for some tire reference)
Old 11-13-2012, 01:30 PM   #8
Patrick L
Member#: 634
2000 Impreza 2.5RS
Becasue ITS racecar
I just took the door from the moon roof assemble and bolted in down to the opening. There are studs on the door and body that you can use with a small bracket to hold the door in place.
Patrick L is offline   Reply With Quote
Old 11-13-2012, 09:14 PM   #9
slava from goshen
Member#: 152176
BRP/SRP
Thanks
Patrick: you make brackets to hold the skin down?
I have no idea what type of racing it will be for. This car was swapped and built years ago, back when I was younger and a big dreamer. Now I just want to get it back on the road and enjoy it. Probably will auto-x and hope to go to gingerman raceway a few times.
Old 11-13-2012, 09:15 PM   #10
slava from goshen
Member#: 152176
BRP/SRP
I was thinking of 17x9.5 or 18x9.5 with low offset. Maybe +15 up to +30. With 255 or 265 tire for now.
Old 11-13-2012, 09:25 PM   #11
slava from goshen
Member#: 152176
BRP/SRP
Thinking of 240 flares or trying these:
http://www.aptuning.com/index.php?pa...mart&Itemid=14
Rokkit, how much cutting you do and did you weld in the rear?
Old 11-19-2012, 10:12 PM   #12
Zefy
Member#: 105104
1979 BRAT / 01 RSTI
99 2.5TS (DEAD) / 87 GL
as far as I know most racing series won't let you have a functional moon/sun roof installed. It needs to be blocked off and disabled. So making a spec cage that fit with the moon roof would be odd.
Zefy is offline   Reply With Quote
Old 11-19-2012, 10:21 PM   #13
Rokkit
Member#: 84181
NASA #530 GTS2
Cut about 2" out of the rears, but mostly due to rust. Could get away with about an inch with the way it's lowered now. fronts are a totally different story though
Old 11-25-2012, 03:38 PM   #14
slava from goshen
Member#: 152176
BRP/SRP
What you do to front fenders? I just got an EF2 turbo for it
Old 11-25-2012, 03:38 PM   #15
slava from goshen
Member#: 152176
BRP/SRP
Maybe I'll get L roof and do roof scoop
