Old 11-12-2012, 04:52 PM   #51
tommyson01
Member#: 154579
2005 OBXT
Old man blue
Originally Posted by Fotown View Post
So you are saying that the STI has a drive-train loss of around 80+hp? or almost a 3rd.
Yup. Figure between 20-30% drivetrain loss. You also have to consider that a dyno never reads quite the same run to run.
tommyson01 is offline   Reply With Quote
Old 11-12-2012, 05:01 PM   #52
13_DGM_Hatch
Member#: 331661
2013 Impreza WRX
Dark Grey Metallic
Originally Posted by drewvdw
09+ WRX's and STi's make almost the same power with the same mods. The tranny probably makes the biggest difference.
Not necessarily. Sti's will generally show about 40 more horse with a downpipe and a tune because of the bigger intercooler.
13_DGM_Hatch is offline   Reply With Quote
Old 11-14-2012, 03:16 AM   #53
Nimbus09
Member#: 212399
09 wrx 301hp/328tq
'00 miata blue
^if i can get 40whp more from a marginally bigger tmic, sign me up for a marginally bigger tmic!
oh yeah, you cannot get 40whp more from a marginally bigger tmic.
Nimbus09 is offline   Reply With Quote
Old 11-14-2012, 10:48 AM   #54
SWP n Gold
Member#: 110783
2010 WRX
Satin White Pearl
Unfortunately, that isn't true. While it does provide superior cooling and prevention of heatsoak, if they have the same mods, the STi doesn't always make more power. Here's an example of the exact opposite actually:
It doesn't mention what gas is used, but the WRX dyno took place in August and the STi was in December so it certainly wasn't a humidity issue.
SWP n Gold is offline   Reply With Quote
Old 11-14-2012, 03:16 PM   #55
etothen
Member#: 221885
09 Ivory Tower
Ivory...duh
Originally Posted by redrex009 View Post
I live like right next to surgeline in tigard oregon. ..... just saving up, then thinking about going and seeing those guys
Talk to Tim, great guy, will not steer you wrong or push product you do not or don't need, bets tuner in the business.
60-70, yes.
Nope, they read the same, the engines/timics are the same untill you push the stock WRX timic above 19-20psi, then the aluminum flanges start to bend out against the plastic end tanks and they can pop, the STI does have this problem.
The real advantages in the STI are all non engine related, DCCD, Brembos, 6mt, 114mm wheel bearings, stiffer suspension, the 2009-2010 make the same power with the same mods though, about 300 at the crank just like the STI and from there it is essentially the same engine. From 2011 on they seemed to have dialed out the stock tune to give the STI more of an advantage, but that is just tune.
Check out the COBB Dyno Database, it is quite informative.
etothen is online now   Reply With Quote
Old 11-14-2012, 04:12 PM   #56
zUnRealistiCz
Member#: 337517
2010 WRX Limited
Dark Grey
i see alot of downsides to the 09.. anyone having issues with their 2010 wrx hatch?? i'm new to the subi world and can always use some facts and opinions
zUnRealistiCz is offline   Reply With Quote
Old 11-14-2012, 04:34 PM   #57
drewvdw
Member#: 255776
2010 LR WRX
MPS powered.
Essentially the same thing, if I remember correctly, the early 09 cars had weaker pistons, I assume that's what you're talking about? I've got a 2010 WRX hatch as well. My motor is out right now, likely busted ringlands. That's the main problem with any turbo Subaru, especially when you start pushing the power like I am.
drewvdw is offline   Reply With Quote
Old 11-14-2012, 05:24 PM   #58
Freep
Member#: 238640
2007 WRX STi
Built wrb (Sold)
Tim does not tune any more. Check with Lucas at Surgeline he is great.
Freep is offline   Reply With Quote
Old 11-14-2012, 05:34 PM   #59
redrex009
Member#: 337456
2009 wrx
lightning red
Cool thanks man
redrex009 is offline   Reply With Quote
Old 11-15-2012, 02:11 AM   #60
Nimbus09
Member#: 212399
09 wrx 301hp/328tq
'00 miata blue
woah, woah, woah. who/what/where/why/when on this one? don't think it's the case.
some of the early buld dates (aug, sept '08) had spun rod bearings due to more environmentally friendly silver bearings, but that was quickly resolved. don't know if that's what you're talking about
Old 11-15-2012, 02:56 AM   #61
redrex009
Member#: 337456
2009 wrx
lightning red
What kind of power are you pushing drew?
Old 11-15-2012, 03:11 AM   #62
drewvdw
Member#: 255776
2010 LR WRX
MPS powered.
I was at 350whp and 350wtq. I should be good up to 450-500whp when done.
Old 11-15-2012, 03:31 AM   #63
ColeBerkenbile
Member#: 316278
2010 WRX Sedan
Keep the stock turbo, get a GOOD tune that's not pushing the limits, and stay on top of your service. Buying things like exhaust and intake are not going to hurt reliability if their tuned for and maintained correctly. When you go to adding a larger turbo, that to me is when a lot more stress is added due to the (usually) large jump in power
ColeBerkenbile is offline   Reply With Quote
Old 11-15-2012, 01:23 PM   #64
redrex009
Member#: 337456
2009 wrx
lightning red
The vf-52 is a bad *** turbo tho,am i wrong?
Old 11-15-2012, 01:58 PM   #65
ColeBerkenbile
Member#: 316278
2010 WRX Sedan
Yeah it makes good power. Anything bigger is taking everything else beyond what it was designed for though. Max out the 52 and you will be happy with it
Old 11-15-2012, 02:06 PM   #66
rexblake
Member#: 178426
2010 S4
Gray
That's a lot of power for a soobie. I still wouldn't go that high. Lots of little things go wrong once you start making serious power like that.
rexblake is offline   Reply With Quote
Old 11-15-2012, 04:51 PM   #67
drewvdw
Member#: 255776
2010 LR WRX
MPS powered.
I agree. Like I have said in my post stage 2 FAQ, I wouldn't recommend going much above 300whp on a stock block.
Old 11-15-2012, 06:25 PM   #68
Tarpley219
Member#: 297676
2009 360whp WRX
E85
I'm making 360 whp on my vf52 09 wrx. I have E85 and basic bolt ons. As far as reliability I haven't had any problems, knock on wood, but every car is different. There is no telling when a certain amount of power is too much for something to handle.
Tarpley219 is offline   Reply With Quote
Old 11-15-2012, 06:34 PM   #69
rexblake
Member#: 178426
2010 S4
Gray
I'm saying even on a built engine. It's asking for trouble to have a dd that high.
Old 11-15-2012, 07:04 PM   #70
Nimbus09
Member#: 212399
09 wrx 301hp/328tq
'00 miata blue
where did you hear pistons on 09's are weak?
Old 11-15-2012, 11:56 PM   #71
redrex009
Member#: 337456
2009 wrx
lightning red
It is a known fact that early 09 s had a habit of spinning rod bearings..... ive got 48000 on the odo.... most experiences ive heard of happens well before 50k... i suppose not all tho... thus the bumper to bumper warranty.
Old 11-16-2012, 12:07 AM   #72
Nimbus09
Member#: 212399
09 wrx 301hp/328tq
'00 miata blue
what do rod bearings have to do with pistons?
he said weak pistons (which i haven't heard anything about), not weak rod bearings (which i've heard plenty about).
Old 11-16-2012, 12:29 AM   #73
redrex009
Member#: 337456
2009 wrx
lightning red
LolJust talking weaknesses ive heard about ... i know nothing about weak pistons.... except that theyre not forged sti pistons
Old 11-16-2012, 03:53 AM   #74
sc00by4life
Member#: 97135
sti pistons aren't forged.
Old 11-16-2012, 03:24 PM   #75
redrex009
Member#: 337456
2009 wrx
lightning red
[quote="sc00by4life"]
sti pistons aren't forged.[/QUOTE.
So what are the internal motor differences? Or is it all suspesion tranny brakes bigger intercooler etc.
