Old 05-17-2013, 12:02 AM   #1
Jubert69
Member#: 167739
04 WRX
ej207 spec C 18g
Default Swapped Downpipes, Screwed up my AFR?
Hey guys,
I recently switch downpipes both catless because of fitment issues with the first one. No size difference.
The only thing that really changed was the location of the Wideband. It went from the side of the downpipe (4-6 inches from the turbo) to the top of the stream. So it went from the actual sensor catching the stream from the side to top of the pipe so in essence it's pointing to the ground.
The idling AFR went from 14.7-15.0 to 16.2-16.8. Normal driving it's the same stoich 14.7-15.0. I went into open loop fueling, and it was originally tuned for 11.2, and it was hitting 11.8-12.
I don't have a problem tuning it to the correct AFRs, I'm just worried my sensor is giving wrong readings. Or can a downpipe that is very similar really throw off AFR?
Jubert69 is offline   Reply With Quote
Old 05-20-2013, 03:54 PM   #2
Jubert69
Member#: 167739
04 WRX
ej207 spec C 18g
Bump. Going to compare the stock wideband vs. the aftermarket wideband tomorrow when I get my tactrix cable back
Old 05-20-2013, 07:39 PM   #3
wgr73
Member#: 232458
2005 & 2008 STi
Cobb 20g & EFR 7670
You will be comparing the stock narrowband to aftermarket wideband. Log your fuel trims.
wgr73 is offline   Reply With Quote
Old 05-20-2013, 07:43 PM   #4
the suicidal eggroll
Member#: 51961
2005 STi
2012 WRX
The downpipe won't affect AFR, my guess is you introduced a leak while doing the swap.
Old 05-21-2013, 11:24 AM   #5
Jubert69
Member#: 167739
04 WRX
ej207 spec C 18g
Stock wideband in the header for idle.
That's what I thought, but I didn't even touch anything else. I didn't remove my IC to do the swap.
Old 05-21-2013, 01:04 PM   #6
nmlittlebigman
Member#: 321409
2003 Big Effing Van
7.3L powerstroke diesel
You could have an exhaust leak especially if you reused a gasket.
Old 05-23-2013, 10:03 AM   #7
Jubert69
Member#: 167739
04 WRX
ej207 spec C 18g
^^ Gonna check for leaks.
I did plug in my tactrix cable and saw the stock WB was reading stoich at idle while the aftermarket WB was reading 16.2-16.8ish.. hmmm
Old 05-23-2013, 04:01 PM   #8
projektdotnet
Member#: 315556
2004 WRX Wagon
Stock O2 sensor is a narrowband, not a wideband sensor. It's common for manufacturers to use narrowband sensors since they're cheaper on average.
projektdotnet is offline   Reply With Quote
Old 05-23-2013, 06:19 PM   #9
Member#: 51961
2005 STi
2012 WRX
The stock O2 is, and always has been a wideband sensor on our cars. Its measurements can't be trusted in boost because of the pressure in the uppipe, but that's not the sensor's fault.
Old 05-23-2013, 06:40 PM   #10
nmlittlebigman
Member#: 321409
2003 Big Effing Van
I knew you would be along shortly to set the record straight Eggroll
Not too many folks on here can explain fueling any better than you.
Old 05-23-2013, 07:17 PM   #11
projektdotnet
Member#: 315556
2004 WRX Wagon
My apologies, after your post I double checked and sure enough I was wrong, kudos. Is the rear O2 also a wideband or is that a narrowband? (I didn't realize there was one in the uppipe/header as well, I only knew of the one in the downpipe) It's been too long since I've been on the underside of the car.
Old 05-23-2013, 10:06 PM   #12
Jubert69
Member#: 167739
04 WRX
ej207 spec C 18g
Downpipe = Narrowband
Header = Wideband
Old 05-24-2013, 02:17 AM   #13
projektdotnet
Member#: 315556
2004 WRX Wagon
Header = Wideband
Learning new things about Subarus all the time, thanks to you and suicidal eggroll for the info.
Old 05-24-2013, 07:09 AM   #14
666stars
Member#: 221364
2002 Wrx EJ207 Ver 8
Wrb Dccd 5 speed now!
So if you have a jdm twinscroll motor with the stock front o2 in the downpipe you can go by that?
666stars is offline   Reply With Quote
Old 05-24-2013, 08:24 AM   #15
endrswrd
Member#: 323908
2013 BRZ ltd
ISM
It will be more accurate then the one in the header on USDM cars. But for better accuracy aftermarket is needed.
endrswrd is offline   Reply With Quote
Old 05-24-2013, 09:08 AM   #16
Member#: 51961
2005 STi
2012 WRX
^ this
Many people have moved the front O2 into the downpipe with good results. This does allow the sensor's readings to maintain accuracy into boost, however the sensor's rich limit of ~11.0 will still cause problems when trying to use it to tune.
Old 05-24-2013, 10:47 AM   #17
666stars
Member#: 221364
I have a aem uego wideband installed in the downpipe as well as stock, just wondering how close the stock one was to the Aem
Old 05-25-2013, 01:48 AM   #18
Jubert69
Member#: 167739
04 WRX
ej207 spec C 18g
Just did a WOT pull, and my AFRs are rock solid since the last time I tuned it 11.0. Still scratching my head for the "lean" values during idle
Old 05-25-2013, 09:51 AM   #19
nmlittlebigman
Member#: 321409
2003 Big Effing Van
I still think you have a minor exhaust leak (most likely at the downpipe). At idle or low cruise your wideband has less gas to measure and the leak would affect what makes it to your wideband . When you go into boost the volume of exhaust gas increases enough to overcome this.
