Old 12-24-2012, 09:42 PM   #1
waxsta
Member#: 328078
2008 Impreza 2.5i
Default Looking put in a new head unit!
I was wandering if this setup would work in my 2008 subaru impreza 2008 2.5i hatchback. Everything is stock right now, other than that I have sub hooked up, but its not running to the head unit at all. I am looking to put in a Clarion cx501 or cx201. Would this fit in my car, and would it make any difference if I bough the cx201 (4 channel) vs the cx501 (6 channel)?
Here are links to everything im looking to buy to make this work.
Clarion Head UnitClarion Head Unit
Wire HarnessWire Harness
Mount KitMount Kit
Is this everything I will need and will it all work out? If not can someone help me out and point me in the right direction? Thanks everyone in advance!
waxsta is offline   Reply With Quote
Old 12-24-2012, 09:57 PM   #2
tibug
Member#: 273906
2006 VTECAccordVTEC
Also it has VTEC.
If you're only running an amplified subwoofer and no amplified speakers, then you're only going to be using one set of preamps (2 channels), so the 4 channel (CX201) will do everything you need, plus if you ever wanted to replace your front door speakers and amplify them, you could use the remaining 2 preamps to do that. IF you were going to, say, amplify your front and rear door speakers, you'd need the CX501 with the 6 preamps.
I can't really tell you anything about the wire harness or the mount kit because I don't know what stereo/nav setup your car has.
tibug is offline   Reply With Quote
Old 12-24-2012, 10:14 PM   #3
waxsta
Member#: 328078
2008 Impreza 2.5i
Not sure if this helpful or not, but here is a pic of my dash set up as of right now.
Old 12-25-2012, 08:52 AM   #4
CRAZYHAWK
Member#: 198067
2009 IMPREZA 2.5i 4d
WHITE Premium
CRAZYHAWK is offline   Reply With Quote
Old 12-25-2012, 04:32 PM   #5
Ralph47
Member#: 214774
2009 Impreza 2.5i
Dark Grey
Crutchfield is a great resource to see what you need for an install. Even if you order from a different site.
Thats the same HU I have, its on my list to replace lol
Ralph47 is offline   Reply With Quote
Old 12-26-2012, 01:05 PM   #6
Aaron'z 2.5RS
Member#: 1026
'00 RS/WRX Stg5
'98 RS Stock
I would personally buy the 501, if you want to expand later, you have F/R/S RCA outputs already..
The harness you need, the moutning kit you don't, you re-use the factory brackets...
Should be simple..
Old 12-26-2012, 01:29 PM   #7
waxsta
Member#: 328078
2008 Impreza 2.5i
So my factory brackets will fit on the 501 and 201?
Old 12-26-2012, 03:07 PM   #8
Aaron'z 2.5RS
Member#: 1026
'00 RS/WRX Stg5
'98 RS Stock
Theyll fit any stereo
Old 12-27-2012, 12:59 AM   #9
waxsta
Member#: 328078
2008 Impreza 2.5i
Alright, thanks for the help everyone!
Old 12-27-2012, 11:50 PM   #10
SkyeC
Member#: 94323
2016 STI
I have the 501 in my car. Sounds good! Get a harness for ae64.com and its simple.
SkyeC is online now   Reply With Quote
