Mid Atlantic Impreza Club
Old 11-11-2012, 11:09 PM   #1
BAouttaVA
Member#: 275424
I just installed an invidia catless downpipe on my bugeye and got a cel. Does anyone a tactrix cable that would be able to help me take the light off? I dont have much money, but I could come to you and bring a 6 pack I'm located in the Front Royal area next to Winchester, so if you're close, that'd be great.
BAouttaVA is offline   Reply With Quote
Old 11-12-2012, 09:13 AM   #2
DavC825
Member#: 201736
The 4 door goodluck
Charm
you can try one of those 02 spacers.
DavC825 is offline   Reply With Quote
Old 11-12-2012, 10:41 AM   #3
syn3rgyz
Member#: 290619
2011 WRX
i got a tactrix but not sure how to take the light off.
syn3rgyz is offline   Reply With Quote
Old 11-12-2012, 10:50 AM   #4
gaedikus
Member#: 310254
04 Forester XT
Silver?
its most likely a backpressure CEL because the car isnt configured for the lack of catalytic converter.
gaedikus is offline   Reply With Quote
Old 11-12-2012, 11:24 AM   #5
xXBISHOPXx
Member#: 304575
2002 WREX 303awhp
you need to get a program for it. if you take out the cat it will all ways throw a cel. im not an expert on it. i just dealt with the problem.
xXBISHOPXx is offline   Reply With Quote
Old 11-12-2012, 11:32 AM   #6
KONKILR
Member#: 3190
2000 Impreza RS and
the Suxass racing mobile!
No such thing.
We need to know what car this is on. Some subaru's can be tricked with just a rear o2 spacer. Some require the codes be deleted or a simulator be wired in.
jake
KONKILR is offline   Reply With Quote
Old 11-12-2012, 12:01 PM   #7
scooby_wooby
Member#: 79653
I don't own a
suby. I just lurk.
Originally Posted by KONKILR
No such thing.
jake
+1
Also, go to autozone and see what CEL you got. Save some money and get a proper tune. Do shortcuts and you are asking for more problems in the future.
scooby_wooby is offline   Reply With Quote
Old 11-12-2012, 12:59 PM   #8
Abnormal
Douchebag Moderator
Member#: 149626
2005 CGM FXT
Rocket Box! :D
You just need someone with a tactrix cable and some experience with Bugeyes to pull your map, check a couple boxes, and flash your ECU.
It's not hard... Just too far for me.
Abnormal is offline   Reply With Quote
Old 11-12-2012, 03:28 PM   #9
BAouttaVA
Member#: 275424
Where are you located? Might be worth the trip. I can bring beer and pizza
Old 11-12-2012, 03:31 PM   #10
BAouttaVA
Member#: 275424
Whoops, double post
Old 11-12-2012, 03:53 PM   #11
Abnormal
Douchebag Moderator
Member#: 149626
2005 CGM FXT
Rocket Box! :D
Come to the Clyde's meet, BRING A LIST OF YOUR CELs (I cannot stress this enough...), and buy me a beer - We're all square.
Pizza might not even cool off in the small amount of time it takes to do this.
Old 11-12-2012, 05:23 PM   #12
BAouttaVA
Member#: 275424
If I'm off work for this day, I certainly will! If I can go, what brew would ya like?
Old 11-12-2012, 05:43 PM   #13
gaedikus
Member#: 310254
04 Forester XT
Silver?
Originally Posted by KONKILR View Post
No such thing.
jake
Originally Posted by scooby_wooby View Post
+1
idk guys, IAG explained my CEL code was a result of a catless DP on an 04 STI without a proper tune. the car was rejecting cruise control and eventually threw a CEL/"Cruise" light blink at me. they explained that this was caused by a difference in backpressure that the car wasnt tuned for.
i doubt IAG lied to me to get extra $$, but theres always that possibility. anyway, after i swapped back to an OEM DP the code was cleared and there hasnt been a problem since.
Old 11-12-2012, 05:45 PM   #14
BAouttaVA
Member#: 275424
Just checked out the thread for the meet. I usually close on Thursday's since that's the night manager's day off. But we just got another team leader (almost manager that I get to make do things I don't care for) and he should be assuming the role of the backup night shift manager after a couple weeks of training. This is a weekly thing, correct?
Old 11-12-2012, 06:12 PM   #15
KONKILR
Member#: 3190
2000 Impreza RS and
There is no such DTC's for back pressure. The codes you had were likely due to the lack of the catalytic converter. It should have a stored code of P0420 catalyst efficiency below threshhold. IAG knows there stuff and I know just as much. Maybe you misunderstood what they were trying to explain?
jake
Old 11-12-2012, 06:42 PM   #16
02bugeye1
Member#: 270483
2005 impreza wrx sti
World rally blue
Ofcourse you cruise control light flashed all drive by wire does when the car gets a cel
02bugeye1 is offline   Reply With Quote
Old 11-12-2012, 10:10 PM   #17
Abnormal
Douchebag Moderator
Member#: 149626
2005 CGM FXT
Rocket Box! :D
Definitely a P0420 code, or maybe an overboost.
All good, there may be a wings meet in Ashburn next Monday!
jake
Bingo.
Old 11-12-2012, 10:11 PM   #18
Abnormal
Douchebag Moderator
Member#: 149626
2005 CGM FXT
Rocket Box! :D
Bugeyes are not DBW.
I'm not sure if flashing cruise happens with all CELs, honestly. That's a Jake question!
Old 11-13-2012, 06:28 AM   #19
KONKILR
Member#: 3190
2000 Impreza RS and
Yep. Any code on a DBW car will make the cruise light flash. Pretty much a worthless light to have.
I beleive he was refferring to his 04 STI.
jake
Old 11-13-2012, 10:03 AM   #20
BAouttaVA
Member#: 275424
I'm off on Mondays so that might work. Also just for the added info if you need it. Its an 03 with the catless invidia dp, magnaflow catback, turboxs 50/50 bov, snorkel has been removed, group n trans mount, kartboy subframe bushings, and the pitchstop is filled with silicone. Don't know if any of that helps or not.
Message Board Statistics All times are GMT -4. The time now is 07:39 AM.
