Old 11-12-2012, 01:31 PM   #1
OC_Nooby
Member#: 311781
2003 WRX w STI V8
Default Can I flash an 02 WRX map to my 03 WRX ECU? - YES + Extra MAPS!
As the title states, can this be done without bricking the ECU?
Here is the reason I want to do this
Just need more resolution to tune out a hesitation issue I have with my 04 STI motor.
I apologize if I put this in the wrong section. If I did just kindly let me know and i'll delete it and move it.
Thanks!
Ok WOW.
First off. the 02 map works
Second, this 02 map is way better then the 03 WRX map. LIKE WHAT THE HELL!
Benefits:
1 extra column in the Primary Open Loop Fuelling Map
Per Injector Primary Fuel Offset Compensation is bigger (8 spots compared to 1)
Tip-In Enrichment Compensation via RPM - new table!
Warm-Up Enrichment - Primary Base Enrichment Additive Compensation (Load) - new table!
1 extra row in the Base Timing Map
Engine Load Compensation (MP) is now 12x11 compared to a 2x2 (this was the main map I was interested in)
It's like better options on an older definition. Probably they weren't required on the stock 02 WRX so they removed it in the 03 WRX but let me tell you, when your heavily modified and changed to a 2.5L STI motor these tables are god sent. Heck just the extra timing/fuelling resolution is awesome!
My car ran way better just using this definition with my 03 WRX map swapped over.
OC_Nooby is offline   Reply With Quote
Old 11-14-2012, 06:07 PM   #2
Bamofo
Member#: 159743
07 STI Limited
TurboMike Tuned 2.35
less emissions crap in the 02 rom too :-) and if you really want more resolution the carberry rom is pretty cool on romraider...
Bamofo is offline   Reply With Quote
Old 11-14-2012, 07:41 PM   #3
BlazeRex
Member#: 268354
02 WRX 05 LGT
Slow Automatics
Yes, you can do it no problem. I found a ROM a while back off of a 2002 that was unlike anything I had seen before, a bit more resolution than any of the other 02-05 WRX's I had seen.
BlazeRex is offline   Reply With Quote
Old 11-15-2012, 11:58 PM   #4
OC_Nooby
Member#: 311781
2003 WRX w STI V8
I'll move to SD once I go with a FMIC that way I have room to put my temp sensors, meth nozzles eheheh
Share Plz I was pretty excited with the 02 map I randomly stumbled across
