Tire & Wheel Forum sponsored by The Tire Rack |
11-12-2012, 01:41 PM | #1 |
Member#: 120262
W. Canada
Vehicle:09 WRX Lightning Red |
Most concave fitment of Rota Grid??
I'm looking for the maximum concavity possible out of a set of Rota Grids with no clearance/rubbing issues.
I have an 09 WRX sedan at stock ride height. I want to keep it at 17" with stock tire diameter. So I'm wondering what width and offset to order...thanks.
11-12-2012, 01:55 PM | #2 | |
Member#: 97135
NWIC
all 9.5" grids have the same face..... the 17x9 +42 is going to be the easiest for you to fit, but you'll still need to roll fenders at the least. |
11-12-2012, 02:00 PM | #3 |
Member#: 16200
Vehicle:OK buy Nates beans westcoastroasting.com |
19x10 +10 is the best....ya know ya want 'em
11-12-2012, 02:34 PM | #4 |
Member#: 74211
Vehicle:2011 SSM WRX 4DR |
There is none
11-12-2012, 09:52 PM | #5 | |
Member#: 236952
Vehicle:2010 WRX (SSM) Stg 2+ 310/370, 6sp R180 |
He'll only need to roll the rears. Maybe not even if he stays at stock ride height. He said he wants to stay with stock tire size too. 225/45/17 will stretch a good amount on a 9" rim I ran/run 17x9 +44 Work CR-Kai with 245/40/17 tires. Lowered about an inch on epic springs, and then again on RCE blacks, I did not have to roll any fenders. It was VERY close but I did not have to roll for fitment and nothing rubbed. However, after I installed my white line rear subframe and differential bushings (solid poly, not inserts) it started to very slightly rub in the rear so I had them rolled. Hope this helps. |
11-12-2012, 10:24 PM | #6 |
Member#: 120262
W. Canada
Sounds like I should be going for 17x8...don't want to roll fenders either.
11-13-2012, 12:20 AM | #7 |
Member#: 16200
11-13-2012, 01:40 AM | #8 |
Member#: 120262
W. Canada
What's the big deal?
11-13-2012, 01:46 AM | #9 |
Member#: 16200
