![]() Mid Atlantic Impreza Club Forum sponsored by Annapolis Subaru |
#1 |
Member#: 250233
Vehicle:2002 WRX Wagon World Rally Blue |
Looks like I'll be needing to drop the trans in my '02 WRX I unfortunately do not have a garage to work in nor the tools or know how really to perform a job like this. I was hoping someone in the area wouldn't mind lending their knowledge, tools, and garage to a Subie owner in need.
I'm not sure but I think I need to replace the throw out bearing.
#2 |
Member#: 40424
Vehicle:Its a boat on jack stands |
I like in Philly by KOP if you want to make the drive.
#3 |
Member#: 250233
I'll keep you in mind, though I'm looking for something a bit closer to me. The car needs to be towed. Unless I can rent a roll on trailer.
PS I'm in Elkton, MD |
#4 |
Member#: 287000
Vehicle:05 LGT wagon 5mt |
I might be able to come down and help if you could throw me some gas money after I put my own trans back in
#5 |
Member#: 296277
Vehicle:2002 Impreza WRX Silver |
I've personally never dropped a subie trans but i wouldn't mind lending a hand if you guys end up doing this on a day I'm available. I could bring odds and ends tools, jacks/stands. Possibly a trans jack too. This is something I'm probably doing next summer myself anyways
#6 |
Member#: 270483
Vehicle:2005 impreza wrx sti World rally blue |
It's really easy to pull the transmission out of these things. If your doing throw out bearing makes sense to replace clutch since you have it down to that point
#7 |
Member#: 250233
The clutch was replaced not very long ago. I'd say it's less than 6 months old. for some reason something just gave out. Whether it's the throw out bearing or a clutch fork or something worse I don't know. All I know is the car isn't moving without a tow.
#8 |
Member#: 270483
Throw out bearing would make a noise when the clutch is pressed
#9 |
Member#: 287000
What do you mean that the car isn't moving? Will it start? Does it go into gear? What exactly is the problem?
#10 |
Member#: 250233
Car starts but will not go into gear. The shift fork moves freely by hand. I've been told this may be a clip that popped off the throw out bearing/bad throw out bearing/broken shift fork.
Link to the discussion. |
#11 |
Member#: 287000
Sounds like the clutch fork is broken
#12 |
Member#: 250233
Alright. Parts are on order. I picked up a new fork and T-out bearing. Who is available this weekend to do a parking lot trans drop with me? Will need tools jacks and jack stands. I will provide pizza and beer. I want to get this car back up and running ASAP my loner truck from work is a POS.
#13 |
Member#: 287000
I might be able to help. Did you order a new clutch while you've got the trans out?
#14 |
Member#: 250233
No I just put a new clutch in it a couple months go. I can't really afford ANOTHER clutch. The last clutch job nearly drained my funds. My problems all started after the new clutch was installed.
#15 |
Member#: 296277
I'll know my work schedule in 2 days
#16 |
Member#: 287000
You should check the tranny dip stick and make sure that a: there is fluid in the trans, and b: that the fluid doesn't look terrible. It should be reddish and somewhat translucent. I would also recommend getting at least a qt of trans fluid to compensate for any fluid that spills out when we drop the trans.
Is this parking lot anyplace that you could leave the car for awhile if the problem is in the trans itself? You are also going to need to get a 32 mm axle nut socket, they are usually a free rental at most auto parts stores unless someone else has one who is coming. |
#17 |
Member#: 156443
Vehicle:2006 WRX Wagon WRB 2001 Forester S, EJ205/5m |
The proper transmission fluid, for a MANUAL transmission (the clutch is the key word here) is NOT reddish. One can use a typical shallow well 32mm for a Subaru axle nut, although you don't HAVE to take the stub axles out of the hubs.
#18 |
Member#: 287000
I just drained /filled my trans fluid last week in my MT subaru last week and what came out and went in were both red. Maybe oem gear lube is a different color. My real point about the axle socket is that most people don't keep a 32 mm socket in their set whether it's deep or shallow, but a free rental keeps the costs down for someone who doesn't have much money nor much necessity for suc
#19 |
Member#: 287000
A rarely used socket. Taking the axles out makes removing and installing the trans mu
#20 |
Member#: 287000
Much easier... This nasioc app is a pita. Every time I try to type quickly, I accidentally hit the send button
#21 |
Member#: 250233
I have a 3/4" drive wrench with a 32mm socket. That's a big mama jama.
#22 |
Member#: 287000
I have a 1/2" drive electric impact gun that works very well for the job and it's very portable
#23 |
Member#: 250233
I have a 3/8 drive torque wrench also. I have basic hand tools. All of my air powered tools are at my in laws house. Along with my jack and jacks stands. So all I have is hand tools.
#24 |
Member#: 250233
Anyone who is willing able to come help me fix my car tomorrow shoot me a text @ 814 380 8584. I'll send you my address. I have the parts. This will be in Elkton, MD and I would like to get started as early as possible seeing as it gets dark out early now.
Thanks to all who respond. |
#25 |
Member#: 250233
I've got one person coming out today so far. THERE WILL BE BEER AND FOOD!
