Old 11-13-2012, 12:10 AM   #1
TUNERwRX
Member#: 61318
2005 STi
Aspen white
Default King Bearing Coming out with Redesigned Bearings
King Bearings will be introducing a newly redesigned and custom engineered Subaru EJ25 XPG race bearings at PRI and IMIS shows next month. King reps will be releasing the press release this week on the new design that will address oil issues and dreaded spun bearings that many Subaru engines have encountered over the years. Should be interesting!
TUNERwRX is offline   Reply With Quote
Old 11-13-2012, 12:47 AM   #2
ckyguy68
Member#: 316296
2006 STIROID
[email protected] on 29psi
awesome!
ckyguy68 is offline   Reply With Quote
Old 11-13-2012, 01:18 AM   #3
Turn in Concepts
Member#: 93646
Many Track Records
Let us help you go fast!
We're going to IMIS so I'll be sure to add it to my list to check out.
Old 11-13-2012, 09:14 AM   #4
rexworx
Member#: 103232
05GD 04XT11WRX2.5XTR
PPG,4.44,LSD,E85,6spdx2
Nice! In for future updates...
rexworx is offline   Reply With Quote
Old 11-13-2012, 10:06 AM   #5
Purpose_Built
Member#: 222879
2003 WRX 60-1/td06h
Hybrid/6spd
This is perfect timing since im putting together another motor. So....whos going to be first?
Purpose_Built is offline   Reply With Quote
Old 11-13-2012, 12:42 PM   #6
Crystal_Imprezav
Member#: 84105
2005 Super Slow STi
CGM
They are already out.
http://forums.nasioc.com/forums/show...2305338&page=4
Changes include full 360 circumference grooves and larger oval oil holes.
Crystal_Imprezav is offline   Reply With Quote
Old 11-13-2012, 12:43 PM   #7
Crystal_Imprezav
Member#: 84105
2005 Super Slow STi
CGM
oh and also new packaging:
Old 11-15-2012, 12:24 PM   #8
Paidfor
Member#: 267815
Be in awe
dont hate .)
360 degree groove? Really? Why not a 180? The mains arent gonna like that one bit.
Paidfor is offline   Reply With Quote
Old 11-15-2012, 01:37 PM   #9
spackyscooby
Member#: 169257
00 rsti & 04 fxt
millenium jade
So here is a question, from what the article linked in T.S.'s thread said a 360 is nice for the rod bearings but not so much for the mains, would it be adviseable for a first time builder that doesn't really want to do it again in 5k miles to use the king's for rods and stay with either the older design or something like acl/cosworth/clevite for the mains?
spackyscooby is offline   Reply With Quote
Old 11-15-2012, 01:54 PM   #10
Crystal_Imprezav
Member#: 84105
2005 Super Slow STi
CGM
OEM and other mains are around 280-300* grooved. The only spot not grooved on them are at the parting line between the shells.
Old 11-15-2012, 05:31 PM   #11
djdalaney
Member#: 301136
Probably because the engineers who developed these decided it was necessary. But what do they know, right?
djdalaney is offline   Reply With Quote
Old 11-16-2012, 09:03 AM   #12
Paidfor
Member#: 267815
Be in awe
dont hate .)
^^^^^Im sure.......but.......what clearance did they "engineer" these 360s to "perform" ? Is the question i guess. Do we still use the general factory tight mains and looser on the rod side? Of is it vice versa now? Im not im the market for a new set of engine bearings by any means (thank God) , but if i were......im not sure over oiling the rods is nessesary as well as sacrificing a good footprint for the mains. Id like to see definitive proof of why this companys new bearing design is better or even safe for that matter. Just sayin....theres a reason they went to this design and im sure its a good one id just like to hear it is all. It would be awsome to have a new design that allows more abuse thats for sure.
Old 11-16-2012, 11:52 AM   #13
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
Here are two cranks, one is an STi 257, one is a revised 205. Cylinder #1 at BDC (oil galley would be in the same position at TDC), and you can see where the oil galley of the main is positioned. does this make sense to you?
257
205
EDIT: sorry it's cylinder #1, not 2
FuJi K is offline   Reply With Quote
Old 11-16-2012, 01:23 PM   #14
Crystal_Imprezav
Member#: 84105
2005 Super Slow STi
CGM
Very nice observation
Old 11-16-2012, 02:35 PM   #15
EMS
Member#: 14116
I have modified the main bearings like those, in all my build engines for years... Too bad someone has found out.
EMS is offline   Reply With Quote
Old 11-16-2012, 02:43 PM   #16
Serkan
Member#: 180514
2004 Sti
So you have always ran 360 groove ? You should share your experience with us.
Serkan is offline   Reply With Quote
Old 11-16-2012, 02:54 PM   #17
EMS
Member#: 14116
Quite a few other oiling "secrets" are in them too... I won't tell, as I sell them to my customers and it took me years to develop it.
Old 11-16-2012, 04:48 PM   #18
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
I see you got secrets too!
I just post pictures, people can determine what they want to do.
Old 11-16-2012, 07:28 PM   #19
mboulton
Member#: 174433
Three cheers for Fuji.....
mboulton is offline   Reply With Quote
Old 12-01-2012, 09:09 AM   #20
GideonZ
Member#: 339388
Hi , I see some Questions about XPG bearings
I am the "inventor" of the XPG and this is the story about it:
We made research and found that Most of Bearing failure in Subaru EJ engines appear on CR #2 and #3.
We received few failed bearings for inspection and found similar symptoms of Oil starvation.
The question is why only CR#2 ,#3 and not CR #1 CR#4
Well, CR#1 get oil from MB#1, CR#4 get from MB#5, CR #2,#3 both get from MB #3
My conclusion was :the ability of single main (#3) to feed oil for 2 CR is limited
therefore, Oil In Feed from Block into MB#3
and
Oil Out Feed from MB#3 into CR#2,3 must improved.
In feed (to MB#3) can improved by adding more oil holes or changing oil to Slot
Out feed (to CR #2,3) can improved by changing oil grove to be folly 360 instead of partially 250 degrees.
explanation :In 250 the oil delivery from MB to CR are turned on-off-on-off while crank rotate ~66% on 33% off
In 360 degree it is 100% on
Oil Groove could not modify to be 360 without changing the inside geometry of the Locating Lug.
The oil will leak from oil Groove out trough the inside punched area of the Locating lug
So this is all about it
confused??
gideon
GideonZ is offline   Reply With Quote
Old 12-01-2012, 09:24 AM   #21
mboulton
Member#: 174433
is this a joke gideon?
Old 12-01-2012, 09:27 AM   #22
mboulton
Member#: 174433
so why 360 degrees on MB#1 and 5 then?
Old 12-01-2012, 09:32 AM   #23
GideonZ
Member#: 339388
1)NO IT IS NOT A JOKE
2) The issue of 360 is relevant mainly to #3 which feed double amount while #1 and #5 feed single rod each
Old 12-01-2012, 09:34 AM   #24
mboulton
Member#: 174433
How about sharing some data that a million dollar corp should have prior to little ol me buying unproven ideas on a $150 bearing set going into $20k engine rebuild?
Old 12-01-2012, 09:36 AM   #25
mboulton
Member#: 174433
fyi..... i purchased a full set normal and oversized. My normal ones are your redesign (which I never asked for) and the oversized are the previous design. Makes it more difficult to swap bearings to get proper tolerances.
feel a bit cheated to be honest.
