Old 11-13-2012, 01:50 PM   #1
JoeyS07sti
Member#: 218475
2007 CGM STI
Default Differential or axle problem???
Hey it's been a while since I been on this site. My 07 STI has a problem up front, basically at low speeds it feels quite wobbley and it pulls hard to the right at full throttle. If I put my DCCD all the way to the rear it goes away. Does anyone know what this could be? Pm me or email me at j.saa.engratgmail.com
JoeyS07sti is offline   Reply With Quote
Old 11-13-2012, 02:11 PM   #2
RoadKillDMD
Member#: 284792
2011 STI
Blurple
Snip.
RoadKillDMD is offline   Reply With Quote
Old 11-13-2012, 04:34 PM   #3
EROCS04SBRUSTI
Member#: 234397
2004 WRX STI WRB
15 DGM FXT
axle sounds like to me up front.
EROCS04SBRUSTI is offline   Reply With Quote
Old 11-16-2012, 09:45 AM   #4
sackytar
Member#: 149262
03WR Rally/XTDD/98SJ
PrimerGrey
Whatever it is be careful not to make it worse by hammering the throttle
sackytar is offline   Reply With Quote
Old 11-25-2012, 01:30 PM   #5
JoeyS07sti
Member#: 218475
2007 CGM STI
Thanks for the advice y'all. I appreciate any more info on things I can look for while under the car or things like that...
Old 11-26-2012, 02:20 AM   #6
dictoresno
Member#: 139816
2002 WRX, VF34 swap
sounds like there may be something wrong with the front diff. sounds like its trying to send power to the other wheel but its having trouble.
dictoresno is offline   Reply With Quote
Old 11-26-2012, 03:12 AM   #7
some dude
Member#: 100300
06 WRX
CGM
Sounds like torque steer up front. Is one of the front half shafts disconnected or broken?
some dude is offline   Reply With Quote
Old 11-26-2012, 11:07 AM   #8
JoeyS07sti
Member#: 218475
2007 CGM STI
Thanks for the info I'm gonna take a look at it this weekend.
Old 11-26-2012, 03:38 PM   #9
wrxsubaru
Member#: 65133
Also check for play in the steering system and ball joint. Having the right front wheel with extra play could cause the wheel torque off in a direction when power or torque is pushed through it. Have you hit anything recently with the right side?
wrxsubaru is offline   Reply With Quote
Old 11-29-2012, 09:40 AM   #10
JoeyS07sti
Member#: 218475
2007 CGM STI
Thanks ill look into it, and no I haven't hit anythin..
Old 03-26-2013, 10:06 PM   #11
JoeyS07sti
Member#: 218475
2007 CGM STI
Bump need advice!
Old 03-26-2013, 10:29 PM   #12
trev762
Member#: 280572
2011 sti sedan
plasma blue pearl
If u have checked everything over and everything is good when was the last time u had an alignment done. Toe could be out which can cause pulling to one side or the other.
Have a look at your tires to see if there is uneven or excessive tire wear.
trev762 is offline   Reply With Quote
Old 03-26-2013, 10:42 PM   #13
JoeyS07sti
Member#: 218475
2007 CGM STI
If it was an alignment issue, would it make a slapping sound, and wobbly feeling at low speed, when the torque is evenly split?
Old 03-26-2013, 11:17 PM   #14
trev762
Member#: 280572
2011 sti sedan
plasma blue pearl
If its bad enough except for the slapping sound which u didn't mention until now.
How old is your suby plus mileage. Have u checked your bushings also. Is the slapping sound feel like metal on metal??
Could be an axle if its making a clicking sound if that's what you mean by slapping sound
Old 03-27-2013, 07:09 AM   #15
JoeyS07sti
Member#: 218475
2007 CGM STI
My Subie is an 07 w like 40,000 miles. I recently replaced the clutch to a Exedy heavy duty racing clutch (which I hate for daily driving). I haven't checked the bushings, what bushings would you be referring to? The slapping sound is kind of a (bump bump bump) hard to explain, definitely sounds like metal on metal. Clicking? It's more extreme than clicking. I've had it lifted to hear it and it makes a weird sound like excess play in the differential/tranny area. Thanks for any info BTW!
Old 03-27-2013, 07:10 AM   #16
JoeyS07sti
Member#: 218475
2007 CGM STI
Another piece of info is that firestone(where I take my car for lifetime alignment told me sometime ago I need to replace my camber bolts in order to properly align it anymore, which I never did).
Old 03-27-2013, 07:29 AM   #17
trev762
Member#: 280572
2011 sti sedan
plasma blue pearl
Sounds to me u have issues with your center diff but take it to a specialist that knows subys well for proper diagnoses.
There's bushings all over in your suspension, have a look where every part meets one another take a bar and pry in between to see if there excessive movement and deep cracks in the rubber.
Old 03-27-2013, 07:34 AM   #18
trev762
Member#: 280572
2011 sti sedan
plasma blue pearl
Ummm!! R u lowered and if so how low cuz there's a good chance u could of popped an axle out, its usually an easy fix by puting it back in but in your case if its been like this for a while most likely will need to replace.
If this is the case u need to raise your suby up a little higher.
Old 03-27-2013, 01:00 PM   #19
JoeyS07sti
Member#: 218475
2007 CGM STI
No I'm not lowered
Old 03-27-2013, 02:32 PM   #20
Counterfit
Member#: 124254
2006 06 SGM Slowbaru
"The Scoobinator"
could of popped and axle out, [...] if its bin [...] to rase your
English mother****er, do you type it?
Counterfit is online now   Reply With Quote
Old 03-27-2013, 03:00 PM   #21
trev762
Member#: 280572
2011 sti sedan
plasma blue pearl
Hey everybody this is my bitch spell checker/
Old 03-27-2013, 05:54 PM   #22
JoeyS07sti
Member#: 218475
2007 CGM STI
Wow counterfit, no need for that Bs. I just need some advice.
Old 05-30-2013, 02:42 PM   #23
JoeyS07sti
Member#: 218475
2007 CGM STI
Cool
For anyone who cared, or has the same problem, it was the passenger side front differential roller bearing. Some how it warped, and it looks like it is due to someone bottoming out pretty bad. Car is fixed now, and drives perfectly again. Hope this helps!
