Old 11-13-2012, 05:55 PM   #1
redblack
Member#: 96866
Default Adjusting valve lash during HG replacement
Hello
I was wondering if it is better to adjust the valve lash with the heads bolted to the engine or if it's alright to do them off the car? I have searched but i only see threads on adjusting them with the timing belt on.
thanks
redblack is offline   Reply With Quote
Old 11-13-2012, 06:30 PM   #2
cal_look_zero
Member#: 294461
2006 San Remo Wagon
Under construction
Do it with the heads on the car. You have to be able to rotate the engine and keep the cams stationary while you do it.
cal_look_zero is offline   Reply With Quote
Old 11-13-2012, 07:31 PM   #3
subaru-tech
Member#: 335402
Its definately better to do it with the heads installed
subaru-tech is offline   Reply With Quote
Old 11-13-2012, 07:38 PM   #4
05-rsx
Member#: 101188
MY07 WRX Wagon
I did it with the heads off the car whilst doing HG replacement. Reinstalled them and was getting irritating valvetrain noise (sewing machine style).
After a month it got the better of me and I rechecked tolerances - nearly every valve was out (loose), presumably from torquing down the heads.
Lesson learnt - do it once the heads are installed and torqued down.
05-rsx is offline   Reply With Quote
Old 11-20-2012, 02:47 PM   #5
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
I'm having a hard time visualizing why it would make any difference. Can anyone spell it out for me?
I ask because I have a set of DOHC heads and cams sitting in my garage and was planning to measure lash and get the valves tipped as necessary. But if my methodology wouldn't give me valid results then I'll have to figure something else out.
Thanks,
Pat Olsen
Old 11-21-2012, 02:30 PM   #6
Bacon117
Member#: 118500
02 Silver Wagon
"Stage 2"
Thanks,
Pat Olsen
It's easier to hold/rotate the cams as needed when everything is installed. I've never done the wrx, but that's been my experience on other cars/bikes.
Bacon117 is offline   Reply With Quote
Old 11-21-2012, 11:58 PM   #7
oem
Member#: 330
It is ideal to set the lash with the heads on the engine but it is not necessary.
The heads will distort after they are torqued to the short block but it will not effect your valve lash by much
Just screw in a cam bolt, without the cam gear, into the cam and use a wrench to turn the cam.
oem is offline   Reply With Quote
Old 11-27-2012, 02:05 AM   #8
Charlie-III
Member#: 30669
1998 Legacy 2.5GT
Silver Sleeper Wagon
I've done lash type & shim type on the bench, no issues. The heads & cams are so short, no real distortion when torqued up (unless the heads/block are warped).
I believe Subaru suggests to set the clearance when the engine (heads) are ~75*F. Hotter or colder may make a slight difference.
Old 11-27-2012, 10:19 AM   #9
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
Thanks. I was talking to Ken @ Delta Cam yesterday about something else and asked him the same question. Ken said the same thing you did - unless the heads are warped, torquing them down should not measurably affect the valve lash.
