Old 10-28-2012, 09:56 PM   #1
Nighthawkra
Member#: 292655
2012 WRX limited
WRB pearl
Default flashing cruise control light?
I've been running torque performance stage 1 for the past 3000 miles.. it's a 2012 WRX no other mods. when I turned on my car my check engine light was on, ABS light was on ,and my cruise control light was flashing. I turn the car back off turned it back on, and the ABS light was off but now my traction control light was on check engine light was still on and my cruise control light was still flashing. With my access port I checked for codes and there was nothing there !I reset my ECU and uninstalled my flash and my car seems to be back to normal. drove home with no reoccurring lights coming on should I get this checked out have you guys ever had this happen? Thank you
Nighthawkra is offline   Reply With Quote
Old 10-29-2012, 02:52 AM   #2
NSFW
Member#: 140444
05 Stage Free LGT
ATP 3076, 6MT, AVO FMIC
A flashing cruise control light just means that your check-engine light is on.
I'm guessing that you made a mistake with the AP when you checked for codes, because I no of no other reason for the CEL to light up.
If the problem was the tune, then you've fixed it. If you don't see the problem for a few weeks, try putting the tune back on, and see if it happens again.
But if the problem was a failing sensor or some other electrical or mechanical problem, then the light show will return when the ECU rediscovers the problem. When it does, double-check for codes. Triple-check if that's what it takes. Without the codes we can only guess.
Old 10-29-2012, 03:22 AM   #3
Nighthawkra
Member#: 292655
2012 WRX limited
WRB pearl
I know ... freaked me out... coldest night since I bought the car.. tune has been checked twice with logs periodically by Torque performance over the last 3k.. car ran fine.. and it occurred after coming out of a store and restarting... I'm so frustrated I love my car... but latly I find myself worrying more about it then enjoying a nice spirited drive.. then this happened lol
Ands when I saw no codes I was actually kind of pissed because I was hopping it was something stupid like a gas cap.
Old 10-29-2012, 01:06 PM   #4
Nighthawkra
Member#: 292655
2012 WRX limited
WRB pearl
Made a appt with my dealer for Thursday to take it in... they said may have just been the gas cap and they have retunes for that programming...now to catch crap for the reflashing
Old 10-30-2012, 08:22 PM   #5
sidock
Member#: 304606
2012 STi
I had the same issue. I was driving on a damp day and my reasoning for the light coming on was condensation on my MAF. cleaned, pulled negative battery cable to make the CEL go away. No since issues (~5000km).
Post back with how you make out at the dealer.
sidock is offline   Reply With Quote
Old 11-01-2012, 03:39 AM   #6
NSFW
Member#: 140444
05 Stage Free LGT
If the problem was caused by the tune, the problem is now gone, and you're asking the dealer to look for a problem that is no longer present.
Old 11-01-2012, 03:42 AM   #7
NSFW
Member#: 140444
05 Stage Free LGT
Do damp days normally cause CELs for Subarus? I had no idea.
He doesn't know what code caused his CEL, you don't know what code caused your CEL. I think it's a mistake to assume that you've both got the same issue. It could be, maybe. But there are hundreds of codes that could cause the CEL to light up.
It's like he missed a phone call last week, and you missed a phone call last week, and you're assuming that the same person called both of you... because both of your phones rang.
Old 11-01-2012, 10:45 AM   #8
Tripintaz
Member#: 245218
2013 STI Limited
The ECU does not turn on those lights without a code being stored in the ECU.
Old 11-20-2012, 10:02 PM   #9
Nighthawkra
Member#: 292655
2012 WRX limited
WRB pearl
It never occurred again... No prob found lol
Old 11-21-2012, 09:16 PM   #10
fushnica2
Member#: 248151
2013 STI
Ice Silver Metallic
Curious if you told the dealer about your tune and if they gave you hell about it?
fushnica2 is offline   Reply With Quote
Old 11-23-2012, 02:35 AM   #11
Nighthawkra
Member#: 292655
2012 WRX limited
WRB pearl
I detuned ... they never asked so I never told
But since I tuned back with no problems.... stock is surprisingly spongy and frustrating compared to TP stage 1..
