Old 11-13-2012, 08:59 PM   #1
CreSTI
Member#: 337796
Default CEL P0304, Help please.
Had my turbo replaced 3-4 weeks ago, replaced with another stock. Today I've got CEL P0304, got it while driving and while boosting lightly. The car has a rough idle, with windows down at idle I could get a hint of a gas smell. I think it's multiple cylinders because there was another CEL but it was the same code. Any suggestions? Thank you.
CEL will flash, and sometimes stay on.
CreSTI is offline   Reply With Quote
Old 11-14-2012, 09:30 AM   #2
some dude
Member#: 100300
06 WRX
CGM
Can u tell us what that code means?
some dude is offline   Reply With Quote
Old 11-14-2012, 09:34 AM   #3
04ScoobyWtf
Member#: 287974
Misfire on cylinder 4. Swap coil from 4 to 2 and if it moved to 2 you got your culprit and erase code. If that doesn't wrk ten try plugs. Then injectors if if still no Beuno you might have a cracked ringlands maybe
04ScoobyWtf is offline   Reply With Quote
Old 11-29-2012, 05:59 PM   #4
SlipperyPanda
Member#: 296180
any updates on this?
SlipperyPanda is offline   Reply With Quote
