Old 11-14-2012, 12:30 AM   #1
MrHankey
Member#: 90968
2003 WRX
Default Are These Camshaft Journals OK
JDM WRX EJ205 head (driver's side .. er ... passenger's side in Japan)
Exhaust (head side):
Exhaust (Cap):
Intake (head side):
I forgot to take a photo of the intake cap (includes AVCS solenoid) but it looks the same as the exhaust. It seems like the journal would have to be out of round and misaligned with the cap for it to not wear the cap the same as the journal in the head. Cams looked perfect.
Thanks!
MrHankey is offline   Reply With Quote
Old 11-14-2012, 10:30 AM   #2
UK-Wagon
Member#: 232430
555 XTi
1 AW & 1 CGM
Yes that is typical of higher mileage.... you can smooth that area out if you want. You need a purple/red scotch brite pad and softly rub that area to take away the sharp edges. Or some 2000 grit sand paper. Dont do too much, just enough to smooth it out a little.
UK-Wagon is offline   Reply With Quote
Old 11-14-2012, 10:38 AM   #3
MrHankey
Member#: 90968
2003 WRX
Any theories on what causes this? The only thing that comes to mind is a cold start, where the oil film that would normally separate the cam from the journal has been displaced due to the tension in the timing belt. Still does not explain why the matting cap is not similarly worn.
Old 11-14-2012, 11:57 AM   #4
bako
Member#: 226211
2002 impreza WRX JDM
blue
do not worry about it. yes, it's from frequent starting, low distance travel...
bako is offline   Reply With Quote
Old 11-14-2012, 03:21 PM   #5
MrHankey
Member#: 90968
2003 WRX
Both heads are headed to a machine shop to have the valves seated, guides replaced etc. thanks to a bent set of exhaust valves in #3 (accident stalled the camshaft). I'll see what they say about it.
Old 11-15-2012, 07:48 AM   #6
bako
Member#: 226211
blue
do not waste money on those journals, just reuse them without remachinenig and line boring
