Welcome to the North American Subaru Impreza Owners Club Tuesday May 31, 2016
Old 11-13-2012, 09:10 PM   #1
RallyBot 6.0
Member#: 337195
Maroon/black
Default klickidy klank and high idle - i am a turbo noob.
like the title says, im a turbo noob. just got the whip, 02'wrx, ran into issues getting my oil change, and now noticing a couple other. first off, my idle is at like 1300 after its warmed up. also, ill rev the throttle cable.. vrrrrrrmmmmmm.. let off.. clak clak clah. sounds near the bottom of block.. pass side maybe. i know its got an exhaust leak right after the cat (farthest back one) looks like it was high centered. besides that it doesnt seem to have any other problems. i was told that if the knocking sound is coming from the block after your rev it, it could be a bearing?
edit - i have noticed a couple other knocks/ticks but they were temporary. also, i cut two coolant lines shorter that go from radiator and coolant resivor to the other resivor that sits on top of the motor. also re-routed them so they go down along side of motor and then strait up to top resivor. (to make room for custom air box) i figured it would be fine because there pressurized, but having second thoughts on kind of ristricting flow. here's a pic of the the two hoses im talking about (left two in blue color) not my car.
RallyBot 6.0 is offline   Reply With Quote
Old 11-13-2012, 11:11 PM   #2
RallyBot 6.0
Member#: 337195
Maroon/black
i was told these motors are suppose to idle at 800rpm's. my buddy also said he thinks it might be a 2.5 block so maybe thats why. but i really have no idea. i got a good deal on the rig and have only built vr6 jetta's and gti's. never played with a turbo motor. also id like to know if shortening and rerouting the coolant hoses would cause me any trouble. thanks.
