Old 11-12-2012, 06:28 PM   #1
ecsubi
Member#: 255473
02 WRX
Default Rattling is driving me crazy, help.
So here's the issue. I own a 2002 WRX, over the past month I have been hearing some rattling which sounds like it is coming from the passenger side rear door and B Column. The noise only happens when I come off the throttle around 2800 to 3300 rpm. I pulled the whole door apart and B column and I can't seem to find the sound. Any ideas would be greatly appreciated.
Additionally I though maybe the exhaust was tapping against the rear diff. I swapped the exhaust out with my brothers exhaust which has plenty of clearance, didn't help.
ecsubi is offline   Reply With Quote
Old 11-12-2012, 07:41 PM   #2
Francois_
Member#: 284101
2004 STI
world rally blue
Look under your car and see if the "outrigger" bushing is still in tact. It's part of the diff mount. I have the same issue and I've narrowed it down to that.
Francois_ is offline   Reply With Quote
Old 11-13-2012, 09:37 AM   #3
Danthrax
Member#: 299368
2014 Impreza 2.0i
Same issue here, don't let off around those rpms and happy day (:
Danthrax is offline   Reply With Quote
Old 11-13-2012, 09:46 AM   #4
M.HASSAN
Member#: 328270
2004 wrx sti
blue
i had a rattling noise and it was the shocks !!!!
M.HASSAN is offline   Reply With Quote
Old 11-13-2012, 09:50 AM   #5
EvileyeZ88
Member#: 233501
07AD 337/335SAXWAGON
99 outback sport
These "outriggers" don't like weight, If you have jacked your car up by them (a lot of people do) that may be your problem.
When bent they make contact with the chassis of the car and transfer vibrations from the transmission to the vehicle cabin.
~Evil
EvileyeZ88 is offline   Reply With Quote
Old 11-19-2012, 02:40 PM   #6
ecsubi
Member#: 255473
02 WRX
I took a look and you guys were right. I narrowed it down to the subframe "outrigger" bushing. I just had the transmission services and I am thinking that when they lifted the vehicle they may have been exerting some force on those outriggers. The subframe itself looks fine but I get a resonating sound if I tap on it.
How hard is it to replace those bushings, or is it something I should get done at a shop?
Old 11-19-2012, 07:07 PM   #7
super_usdm
Member#: 286211
2003 WRX
1993 Legacy SS
Very easy to replace the bushings.
super_usdm is offline   Reply With Quote
