Old 11-14-2012, 10:38 AM   #1
subbiegal
Member#: 293833
Default White smoke
At a stop light I noticed white smoke coming out from under the hood. I pulled over and noticed that it was coming from the radiator. I just had that replaced a few years ago & never noticed any smoke from there before. Just recently had a new tranny put in and now I notice the smoke. My temp gauge is at normal. What else could it be?
subbiegal is offline   Reply With Quote
Old 11-14-2012, 10:44 AM   #2
IA Performance
Member#: 25194
2008 Forester XT 5mt
Dark Gray
If the clutch was just done (20 miles or less) there is a chance penetration spray is burning off. If it has been longer than ~20 miles then there may be a leak somewhere, none related to the clutch job. Assuming the car has over 20 miles then I would be proactive with sorting it out, before it has a chance to possibly damage the motor.
Radiator Pressure Testing equipment should be able to find a coolant leak
White smoke could also be an oil leak, often common after an oil change since oil can get on the exhaust manifold heat shields.
Let us know what you end up finding.
[email protected]
IA Performance is offline   Reply With Quote
Old 11-14-2012, 10:45 AM   #3
CrashBandit
Member#: 329543
2003 WRX Wagon
Sonic Yellow
Could be excess coolant burning off? Does it smell sweet?
CrashBandit is offline   Reply With Quote
Old 11-14-2012, 12:32 PM   #4
dacib
Member#: 307828
Check power steering pump for leaks.
dacib is offline   Reply With Quote
Old 11-14-2012, 01:18 PM   #5
danger1138
Member#: 279525
04 rex luger!
Yea might also have a tiny pinhole sized leak coming from top coolant hose. You might not notice while its idleing but when under pressure the coolant might drip off that tiny hole and fall directly on the exhaust mani causing smoke. It happened to me, so just replaced with a sam o hose. Does it smell sweet?
danger1138 is offline   Reply With Quote
Old 11-14-2012, 01:38 PM   #6
ScoobySubyDoo
Member#: 329311
2003 WRX
Satin Black
Check coolant and power steering levels. Check for holes in the upper radiator hose also.
ScoobySubyDoo is offline   Reply With Quote
