Welcome to the North American Subaru Impreza Owners Club Saturday February 13, 2016
Old 03-25-2013, 01:34 PM   #1
BeastianSTI
Member#: 310506
2005 WRX STi
Silver, Sexy 'n Raspy
Default BOV bolt broke through TMIC tank
So... I had my clutch changed at a "reputable
shop in my area, and the shop broke my top mount intercooler, and denies ever taking the BOV off. I knew that they put different bolts on the BPV, but anyways...
Once I took the bolts out, after observing a leak through the bolt holes when doing a pressure test, I realized that not only are the threads stripped out, but they impacted too long of bolts into the bolts, which ruptured through the back of the bolt hole, into the tank. This is my daily, and I can't really take off of work due to having accepted a new job.
Any ideas for ways to seal this up?? Thanks guys!
BeastianSTI is offline   Reply With Quote
Old 03-25-2013, 04:24 PM   #2
Cois32
Member#: 294755
2004 Impreza WRX
WRB vf39'd
i think those ebay godspeed intercooler bpv holes pass though. it did in my case and i used teflon tape arond the bolts for a better seal but i wouldn't recommend doing that since its so close to the throttle body.. unfortunately i just replaced my tmic with a sti.. i really dont know what kind of advice to tell you. anyone else?
Cois32 is offline   Reply With Quote
Old 03-25-2013, 04:59 PM   #3
jayman4312
Member#: 228784
2004 wrx
black, stage 2+
pick up a used sti tmic locally, or even a stock wrx one for cheap/free for now until you can get it figured out if you really have to drive the car right away
jayman4312 is offline   Reply With Quote
Old 03-25-2013, 05:33 PM   #4
BeastianSTI
Member#: 310506
2005 WRX STi
Yeah, it's a Turbo XS TMIC. My pops was suggesting that I re-tap it a size bigger, and put some longer bolts in, with RTV or something on the threads, with a rubber washer on the outside. Do you guys think that might hold? I'm running 18 PSI with stock STI turbo.
Old 03-25-2013, 05:41 PM   #5
mechatricity
Member#: 290592
15 Outback,
15 WRX 6MT CWP
That would definitely hold for a while, just pressure test it again. Even if it leaks at 10 or 15psi, it will at least let you drive around for a while.
mechatricity is offline   Reply With Quote
Old 03-25-2013, 05:41 PM   #6
jayman4312
Member#: 228784
2004 wrx
black, stage 2+
Well, you can do that and find out, but i don't think that's a permanent solution.
Old 03-25-2013, 06:00 PM   #7
BeastianSTI
Member#: 310506
2005 WRX STi
Yeah, it's shooting straight 10 AFR when I hit 1 PSI, as it stands currently haha.
Old 03-25-2013, 06:26 PM   #8
wrxlaunch
Member#: 181298
2015 WRX Limited
Lightning Red
Rtv and bigger and longer bolt. No need for new tmic
wrxlaunch is offline   Reply With Quote
Old 03-26-2013, 10:10 AM   #9
BeastianSTI
Member#: 310506
2005 WRX STi
Still ended up leaking through, after changing that out.. Dang. Any other ideas guys, aside from getting it re-tapped?
Old 03-26-2013, 10:26 AM   #10
xevets
Member#: 177481
2003 WRX
Default Heli coil
Just helicoil it? As long if you have enough room and material thickness...
This should work?
Try to post a pic of the problem you are having, perhaps we could help out more if we can visualize what is going on.
xevets is offline   Reply With Quote
Old 03-26-2013, 02:38 PM   #11
BeastianSTI
Member#: 310506
2005 WRX STi
https://docs.google.com/file/d/0B0i3...it?usp=sharing
Here is a picture of the hole, and the back of it sheared through.
Last edited by BeastianSTI; 03-26-2013 at 02:40 PM. Reason: Looks like you can't link to gdrives lol
Old 03-26-2013, 05:08 PM   #12
wrxlaunch
Member#: 181298
2015 WRX Limited
Lightning Red
Just tap it. Dont know how its still leaking with a bigger and longer bolt than stock with rtv on threads.
Old 03-26-2013, 05:15 PM   #13
xluben
Member#: 261612
2002 WRX - 800HP
9.5s @ 150mph
Re-tap it in a larger size. Clean out the TMIC for any metal shavings. Then put the bolt on with blue Loctite on the threads.
Old 03-27-2013, 09:56 AM   #14
fastnoypi
Member#: 6886
MY01 EJ207 HTA35r
AVCS ON!
might be able to get some aluminum rod, thread it and seal the hole with loctite...then drill and re-tap to the proper depth.
