Old 11-14-2012, 03:43 PM   #1
83roothm
Member#: 317673
2004 wrx
wrb
Default Low idle, LOTS of smoke
Okay, So I bout my first 2004 wrx in the best color in the world (wrb) and Everytime the car is cold, especially on start up, there is A LOT of smoke coming from the exhaust. as it warms up there is less and less, and after about 5 minutes of driving it warm, it stops. I also noticed when it is warm, it idles low, at about 500 rpm, sounds like the timing of the idle is off. I did use the Accessport to adjust the idle, so it idles at about 750-800. If anybody could help me out, or give me some suggestions, let me know. If you have any questions to help you make a diagnosis, let me know. Also shoots water out of the exhaust.
Here's a video I took... http://www.youtube.com/watchv=ATXroAUB6iA&feature=plcp
Thanks for any help.
83roothm is offline   Reply With Quote
Old 11-14-2012, 05:03 PM   #2
ocellaris
Member#: 302559
Is it smoke or steam? You should be able to tell pretty easily based on the smell. Big difference in how you approach this if its burning oil when the engine is cold...
ocellaris is offline   Reply With Quote
Old 11-14-2012, 09:41 PM   #3
stock4shock
Member#: 337718
Sounds like a leaking head gasket. Have you been keeping an eye on your coolant level? Or engine temp gauge? If the steam/smoke smells like a dogwood/fish/dirty lady parts then its definitely antifreeze.
The leak completely slows or stops when the engine is warm due to thermal expansion. Your head, block and head gasket expand ever so slightly and fill the void as the engine reaches operating temp. Also the water molecules in your coolant expand as the engine heats up and are less likely to leak through to your cylinder from the water jacket. This is why you have an over flow reservoir in your coolant system.
My '92 legacy blew the passenger side head gasket and it still drove around for over a week. Granted I did leave a long trail of smoke. I suggest NOT attempting to replace your gaskets on your own unless you have the ability to pull your engine and have a second car to drive for a while.
Good luck!
stock4shock is offline   Reply With Quote
Old 11-14-2012, 10:32 PM   #4
auskip07
Member#: 315643
2012 Impreza Sedan
DGM 5mt
pull the plugs and see if they look very clean. Guessing its the HG
you can also smell coolant in the exhaust
auskip07 is offline   Reply With Quote
Old 11-14-2012, 10:44 PM   #5
stock4shock
Member#: 337718
By the way a 500rpm idle is standard. Every subie I've driven sits solid at 500.
Old 09-29-2013, 08:27 PM   #6
83roothm
Member#: 317673
2004 wrx
wrb
Issue is long fixed. Thanks guys.
