Old 11-14-2012, 04:25 PM   #1
eronenris
Member#: 262992
2009 WRX - Stage 2
Satin White Pearl
Default 09 wrx banjo bolt screen?
does the 09 wrx have a screen in the oil feed banjo bolt? i was told i am supposed to clean this every other oil change and i did my oil change today and i took out the banjo bolt, but i could not tell if it had a screen in there or not so i cleaned it out at least but i did not replace any screen.
eronenris is offline   Reply With Quote
Old 11-14-2012, 04:32 PM   #2
tazswing
Member#: 63767
2009 OXT 5-spd
2011 STi hatch
who told you that? also, how much searching did you do about this topic?
tazswing is offline   Reply With Quote
Old 11-14-2012, 05:17 PM   #3
JrC
Member#: 299403
2009 Impreza WRX
World Rally Blue Pearl
The screen is in the banjo bolt on the passenger side head feeding to the turbo, I'm not sure about cleaning that often I just completely removed mine.
JrC is offline   Reply With Quote
Old 11-14-2012, 05:45 PM   #4
eronenris
Member#: 262992
2009 WRX - Stage 2
Satin White Pearl
some dude at the subie dealership. one of the techs. i didn't do much searching...don't have much time for that, i usually have time to post a topic and then check it every few hours.
Old 11-14-2012, 05:46 PM   #5
eronenris
Member#: 262992
2009 WRX - Stage 2
Satin White Pearl
that's the one i checked, but i could not see anything in there.
Old 11-14-2012, 05:53 PM   #6
tazswing
Member#: 63767
2009 OXT 5-spd
2011 STi hatch
http://forums.nasioc.com/forums/show....php?t=2347881
In case you don't know what to look for.
I just did a general search and found about 15 threads on the topic.
Old 11-14-2012, 08:02 PM   #7
eronenris
Member#: 262992
2009 WRX - Stage 2
Satin White Pearl
i didn't see anything like that in my banjo bolt, that pic on your link looks bigger than my banjo bolt alone, i can't imagine that filter fitting in it.
Old 05-22-2013, 10:08 AM   #8
EricInHoodRiver
Member#: 299737
2011 WRX Hatch
Cobb Stage 2 Protune
I will keep searching, but foes 2011 Wrx have a screen in banjo bolt?
EricInHoodRiver is offline   Reply With Quote
Old 05-22-2013, 12:33 PM   #9
dpenn
Member#: 141201
2008 WRX
yes, it is the banjo bolt on the cylinder head - the line then goes to the smaller turbo banjo bolt...
http://store.forcedperformance.net/m.../02-103-07.pdf
dpenn is offline   Reply With Quote
Old 05-22-2013, 01:45 PM   #10
EricInHoodRiver
Member#: 299737
2011 WRX Hatch
Thanks much. I'll call my mechanic and see if he suggests inspection intervals. I use synthetic oil and oem filters which I change far too often so maybe not, but I'd like to hear it from an expert.
Eric
