Old 11-14-2012, 09:27 PM   #1
Android287
Member#: 180861
2005 cammed Hybrid
2.5xtr E85
Default Aftermarket uppipe removal questions
Hello, I have a 2005 wrx with an invidia uppipe. I was thinking about removing it for heat wrapping. Can it be removed without removing the turbo? Does the turbo just sit on a bracket? Will i still need to jack up the motor?
thanks
Android287 is offline   Reply With Quote
Old 11-14-2012, 09:32 PM   #2
NW Rex02
Member#: 314030
2002 wrx
yes you will still need to jack up the motor. and no i dont believe you need to remove the turbo. only other option tho is to drop the headers
NW Rex02 is offline   Reply With Quote
Old 11-14-2012, 10:11 PM   #3
drewvdw
Member#: 255776
2010 LR WRX
MPS powered.
I took mine off without removing the headers or jacking up the motor...or completely removing the downpipe for that matter...But they're different years with different motors.
drewvdw is offline   Reply With Quote
Old 11-15-2012, 07:06 AM   #4
Android287
Member#: 180861
2005 cammed Hybrid
2.5xtr E85
I will be dropping the header and downpipe as well for wrapping. Do u still think it will be necessary to jack the motor up?
Old 11-15-2012, 07:26 AM   #5
HinshawWRX
Medium Frank
Member#: 140114
2014 Porsche
GT3 (Currently on Fire)
No, should not have to jack up the motor.
Old 11-15-2012, 09:57 AM   #6
2.5L Monster
Member#: 307177
2k4 WRX/WRB
Shuckin' & Drivin'
Installed mine with the car up on stands and from underneath. No, the motor does not need to be jacked up.
2.5L Monster is offline   Reply With Quote
Old 11-15-2012, 10:04 AM   #7
NoGraffix
Member#: 276209
I am Rub
Function>Form
No need to remove the turbo, but the exhaust manifold out of the way does help as does unbolting the downpipe to give you some wiggle room.
NoGraffix is offline   Reply With Quote
Old 11-15-2012, 02:33 PM   #8
Android287
Member#: 180861
2005 cammed Hybrid
2.5xtr E85
Ok before I get into it. When I take off the downpipe and unbolt the uppipe, how is the turbo still held in place?
Old 11-15-2012, 02:35 PM   #9
Mr Wrex
Member#: 332887
2012 WRX stage 2+
DGM (sedan)
It's still attached to the inlet
Mr Wrex is offline   Reply With Quote
