Welcome to the North American Subaru Impreza Owners Club Friday July 3, 2015
Old 03-22-2015, 08:10 PM   #1
jpgriffin94
Member#: 345207
2005 Impreza WRX
Rally Blue Pearl
Angry Rattle Paint Can Noise 2005 WRX
I have a 2005 WRX. Right around 3000 rpm I hear a sound a lot like when your shaking up a spray paint can. It is only under light load and the sound will go away as soon as I let off the throttle or get too much on it. I also here it a little when I start the car.I can also make it happen at idle with light throttle. Sounds like it is coming from around the uppipe or under intercooler area. It is very hard to hear because of my loud exhaust. Anyone have any ideas about this?
jpgriffin94 is offline   Reply With Quote
Old 03-22-2015, 08:13 PM   #2
Uncle Scotty
Visiting NASIOC Timeout
OK buy Nates beans
westcoastroasting.com
ya just joined the spun bearing club...its blowed up
congrats...you will need about $4k to get it going again
don't drive it anymore as it will kill all sorts of other things
what oil have you been using?
Old 03-22-2015, 08:17 PM   #3
jpgriffin94
Member#: 345207
2005 Impreza WRX
Rally Blue Pearl
I have been running Rotella T6.
Old 03-22-2015, 09:03 PM   #4
Uncle Scotty
OK buy Nates beans
well.....y most likely blew it up
drain the oil into a CLEAN container...strain it through an old white tee shirt or white fine weave cloth and see if ya got sparkelies in it
if it looks like yer gf put her glitter in it
stick a fork in 'er....the motor.....its all done.
Old 03-22-2015, 09:53 PM   #5
jpgriffin94
Member#: 345207
2005 Impreza WRX
Rally Blue Pearl
Yeah its just strange i maintain everything and dont beat on it. The thing is flawless then all the sudden bam. I was going to drain the oil in a bit and run it through a coffee filter see if i got some rod bearing in there. Guess ill find out.
Old 03-22-2015, 10:28 PM   #6
Uncle Scotty
OK buy Nates beans
OR....MAYBE....if the gods are on your side.....
its a loose heat shield or some stupid **** like that and ya got lucky
MAYBE.....and I do hope that;s all it is
Old 03-22-2015, 10:32 PM   #7
jpgriffin94
Member#: 345207
2005 Impreza WRX
Rally Blue Pearl
Yeah id hope so. Ill find out soon enough. Havent touched tbe car in a while. Dont even want to deal with it right now.
Old 03-22-2015, 11:06 PM   #8
Uncle Scotty
OK buy Nates beans
yeah...I know the feeling....yeah
well....checking the oil would tell ya in a minit.....and the up pipe heat shields can DO that noise sometimes when the spot welds break
Old 03-22-2015, 11:15 PM   #9
bdubblu
Member#: 251046
Did you experience a loss of performance or change in the way the engine was running? If you did serious damage to the motor there'd be more than just noise.
I had small rocks in my heat shield once. I had to open up some holes to get them out. Anther time I had the heat shields rattling.... Used some large 3" hose clamps screw type. Another time the heat shield for my turbo had rusted just enough that the 8mm screw wasn't making contact anymore... And it was rattleriffic. Put a washer on that to fix until I got a different shield. Ather time the spot weld on the heat shield broke, so I took some pliers and bent that area over itself.
bdubblu is offline   Reply With Quote
Old 03-22-2015, 11:56 PM   #10
Uncle Scotty
OK buy Nates beans
d00000000000d...spun bearings usually don't cause any change in performance......until the motor seizes or the rod comes through the block
or both
Old 03-23-2015, 09:15 AM   #11
jpgriffin94
Member#: 345207
2005 Impreza WRX
Rally Blue Pearl
There is no change in performance. However i avoided driving the car any more to avoid more damage. So it could very well be rod bearings starting to go or it could be something a lot easier on the wallet. At this point ive had enough problems with it so i have an appointment on saturday to get it checked out. Ill let you guys know what it ends uo being. Also i work on Infiniti as a tech so its not like i am not cabable i just dint feel like dealing with it. Besides if its gonna end uo needing a shortblock I might as well get her built anyway.
Old 03-23-2015, 09:49 AM   #12
Uncle Scotty
OK buy Nates beans
yeah....not running the engine if ya think ya got a bearing issue is key...make as little work on a rebuild as possible
Old 03-24-2015, 01:05 PM   #13
dub1080
Member#: 331260
2002 wrx
Possibly the stock cat in the up-pipe. If oil is fine when you drain it, then next step is to remove the up-pipe to see if the cat has broken apart. If it did then next step is getting a catless up-pipe and you're going to have to replace the turbo.
dub1080 is offline   Reply With Quote
Old 03-24-2015, 09:53 PM   #14
Uncle Scotty
OK buy Nates beans
no
if the cat in the up were disintegrating...it would cause noticeable issues...the whole thing would get REAL hot and glow cherry red and then the turbo would stop spinning and make no boost....
this almost certainly isn't the cat in the up pipe issue
Old 03-29-2015, 08:46 AM   #15
chemtek
Member#: 310710
2008 Impreza WRX
I recently found my rattle noise and can confirm it was my Grimmspeed heat shield that broke apart where the lower bolt holds to up pipe. The whole corner of shield around bolt broke away.
Maybe I should send them an email, although I bought it a few years ago.....
chemtek is offline   Reply With Quote
Old 03-29-2015, 11:24 PM   #16
bdubblu
Member#: 251046
Well that was anticlimactic and typical.
Old 03-30-2015, 03:33 PM   #17
tebriel
Member#: 244190
2004 WRB WRXes
Sedan and Wagon
That wasn't the OP ^^
tebriel is offline   Reply With Quote
Old 03-30-2015, 05:10 PM   #18
86Dreams
Member#: 385256
can you post a video? 30s would do, open the hood turn on the car, pull the throttle?
86Dreams is offline   Reply With Quote
Old 03-31-2015, 07:32 AM   #19
bdubblu
Member#: 251046
Ha! Well that's a twist to the plot!
