Old 11-15-2012, 05:55 PM   #1
zoltan
Member#: 135502
Default Strange symptoms - bad battery?
My car is having some strange symptoms and I hope you can help diagnose it. This morning the car wouldn't turn over and it needed a jump. After that it drove fine.
This evening I cleaned the terminals and battery posts. The first time I tried to start the car just cranked for a couple seconds. The second time it started up. I took it for a test drive, and several times after driving 35+ mph the engine died as I was coming to a stop. Several more times the engine almost died, but caught and stayed running.
I have a 2008 Impreza which still has its original battery (4.5 years old), so I suspect it's a bad battery. However, these aren't the symptoms I've seen for a dying battery in the past.
Any ideas?
zoltan is offline   Reply With Quote
Old 11-15-2012, 07:20 PM   #2
Duvanator
Member#: 217257
2008 2.5i hatch
Satin White Wrap
sounds like the battery, my factory battery went out last winter on me (also own a 2008)
the car almost dieing on you is because the batter didn't have enough juice to turn the car over, and died, it probably caused the ecu to reset. the car can have sporadic idling and wanting to die when you drive it right away after reseting the computer. which it sounds like is what happened. it is the computer trying to adjust all it's ratio's and re-learn different things related to your driving and the surrounding atmospheric conditions
Duvanator is offline   Reply With Quote
Old 11-15-2012, 07:50 PM   #3
cal_look_zero
Member#: 294461
2006 San Remo Wagon
Under construction
Keep it simple, go to autozone/napa/oreillys and have them test it. Even with a bad battery, the alt should keep the car running while driving. You may have more issues.
cal_look_zero is offline   Reply With Quote
Old 11-15-2012, 11:02 PM   #4
zoltan
Member#: 135502
Autozone tested the battery and said it was bad. I've installed a new battery but it's still having some idle issues. The engine hasn't died, but it's still letting the idle drop too low when I put in the clutch after driving 35+ mph. Hopefully it's just the ECU relearning the car. I figure if it's not running normally after I get home from work tomorrow then I'll take it to my mechanic.
Old 11-15-2012, 11:07 PM   #5
Duvanator
Member#: 217257
2008 2.5i hatch
Satin White Wrap
what i've been told is that after the ecu is reset (new battery) it is best to start the car and let it idle for 10-15 minutes to learn/ set up what it needs to.
I to had the crazy low idle, and stall once or twice when i depressed the clutch while driving. happened after i had the battery disconnected for a period of time. just keep driving it and it should correct itself. those issues only ever happened during the first 100 miles?
Old 11-16-2012, 07:16 AM   #6
zoltan
Member#: 135502
So I found the idle reset procedure Duvanator mentioned in another thread and tried it. I turned the key to on for 30 seconds, turned it off, and then started the engine and let it idle for 10+ minutes without touching anything.
After that it was good to go.
EDIT: Before I did that, though, I disconnected the battery again for several minutes to reset the ECU again.
Old 11-16-2012, 07:28 AM   #7
Duvanator
Member#: 217257
2008 2.5i hatch
Satin White Wrap
thats good to hear! I know it scared me and I though it was something major when it happened
Old 11-16-2012, 09:24 AM   #8
treksofar
Member#: 208070
2006 Impreza 2.5i
Regal Pearl Blue
Another thing to check is to see if you have gunk built up around the butterfly valve in the throttle body. For a while, whenever I reset the ECU or did a battery pull the car would have issues returning to idle for a few days. If there's excess gunk in there the ECU needs more time to learn how much to crack open the valve for a smooth idle.
treksofar is offline   Reply With Quote
Old 11-16-2012, 11:26 AM   #9
gdoggmoney
Member#: 158150
2007 Impreza 2.5i
Newport Blue pearl
Clean all of your ground cables, and replace them with copper ended cables that are proper sized. The factory grounds are horrible, worse than a VW.
gdoggmoney is offline   Reply With Quote
Old 11-22-2012, 09:42 PM   #10
Ralph47
Member#: 214774
2009 Impreza 2.5i
Dark Grey
Is there a DYI for removing the throttle body or is it self explanatory? I have some rough idle issues and cleaning the TB in my old dakota helped a ton, I have other things I am going to do first but figured I could add this to the list if those do not work.
Ralph47 is offline   Reply With Quote
Old 11-22-2012, 10:55 PM   #11
rhino6303
Member#: 181314
2005 Impreza OBS SRR
05 Legacy GT RBP
Pretty self explanatory. Remove coolant hoses, disconnect electrical connections and remove the 4 bolts. You should replace the gasket upon re-install.
rhino6303 is offline   Reply With Quote
Old 11-23-2012, 12:39 AM   #12
Ralph47
Member#: 214774
2009 Impreza 2.5i
Dark Grey
Fair enough, more work than my truck but still sounds easy enough. Thanks
